Data sheet | Item number: 731-140/048-000
Feedthrough terminal block; Plate thickness: 1.5 mm; 2.5 mm²; Pin spacing 5
mm; 10-pole; CAGE CLAMP®; 2,50 mm²; gray
www.wago.com/731-140_048-000
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
13.07.2020 Page 1/10
L = (pole no. x pin spacing) + 3 mm
L1 = L + 5.8 mm
L2 = L1 + 6.4 mm
for mounting plate thickness up to 1.5 mm
Item description
Hansastr. 27
32423 Minden
13.07.2020 Page 2/10
Feedthrough PCB terminal strips with screwdriver-actuated CAGE CLAMP®
With flanges for PCB or front-panel mounting – either flush with enclosure or protruding
Data
Electrical data
Ratings per IEC/EN 60664-1
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
320 V
Rated surge voltage (III/3)
4 kV
Rated voltage (III/2)
320 V
Rated surge voltage (III/2)
4 kV
Nominal voltage (II/2)
630 V
Rated surge voltage (II/2)
4 kV
Rated current
5 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Approvals per UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
5 A
Rated voltage UL (Use Group C)
150 V
Rated current UL (Use Group C)
5 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
5 A
Approvals per CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
5 A
Connection data
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Solid conductor
0,08 … 2,5 mm² / 28 … 14 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0,25 … 1,5 mm²
Fine-stranded conductor; with uninsulated ferrule
0,25 … 2,5 mm²
Strip length
Subject
to changes. Please also observe the further product documentation!8 … 9 mm / 0.31 … 0.35 inch
Hansastr. 27
32423 Minden
13.07.2020 Page 3/10
0,25 … 2,5 mm²
Strip length
Pole No.
10
Connection technology 2
Wire-wrap pin
Total number of connection points
10
Total number of potentials
10
Number of connection types
1
Number of levels
1
Geometrical Data
Pin spacing
5 mm / 0.197 inch
Width
65,2 mm / 2.567 inch
Height
14,3 mm / 0.563 inch
Depth
15,5 mm / 0.61 inch
Mechanical data
Housing sheet thickness
1,5 … 1,5 mm / 0.059 … 0.059 inch
Mounting type
Mounting flange
Mounting type
Feed-through mounting
Panel mounting
Material Data
Color
gray
Material group
I
Insulation material
Polyamide 66 (PA 66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.254 MJ
Weight
16.1 g
Environmental Requirements
Limit temperature range
-60 … +105 °C
Commercial data
Product Group
3 (Multi Conn. System)
Packaging type
BOX
Hansastr. 27
32423 Minden
13.07.2020 Page 4/10
Packaging type
BOX
Country of origin
DE
GTIN
4044918269865
Customs tariff number
85366990990
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CB
DEKRA Certification B.V.
IEC 61984
NL-39756
CSA
C22.2
1466354
KEMA/KEUR
EN 61984
2190761.01
Approval
Certificate
name
UL
Underwriters Laboratories Inc.
UL 1977
E45171
UL
UL 1059
20190731E45172
UL-Approvals
Logo
Counterpart
Compatible products
tools
Item no.: 210-657
Hansastr. 27
32423 Minden
www.wago.com/210-657
13.07.2020 Page 5/10
Item no.: 210-657
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short
Item no.: 210-720
www.wago.com/210-720
Item no.: 209-147
Self-tapping screw
www.wago.com/209-147
Item no.: 231-194
Self-tapping screw; B 2.2x13, fixing hole 1.8 mm Ø
www.wago.com/231-194
Item no.: 231-195
Screw with nut; M2x12; for fixing element
www.wago.com/231-195
Item no.: 231-295
Screw with nut
www.wago.com/231-295
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated
www.wago.com/216-101
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated
www.wago.com/216-104
Item no.: 216-106
Ferrule; Sleeve for 2.5 mm² / AWG 14; uninsulated; electro-tin plated
www.wago.com/216-106
Item no.: 216-121
www.wago.com/216-121
Item no.: 216-122
www.wago.com/216-122
Item no.: 216-123
www.wago.com/216-123
Item no.: 216-124
www.wago.com/216-124
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-131
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
assembling
ferrule
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
Hansastr. 27
32423 Minden
www.wago.com/216-141
13.07.2020 Page 6/10
crimped; acc. to DIN 46228, Part 1/08.92
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-142
Item no.: 216-143
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-143
Item no.: 216-144
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-144
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-224
www.wago.com/216-224
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
Hansastr. 27
32423 Minden
www.wago.com/216-244
13.07.2020 Page 7/10
crimped; acc. to DIN 46228, Part 4/09.90; black
Item no.: 216-262
www.wago.com/216-262
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
Item no.: 216-264
www.wago.com/216-264
Item no.: 216-284
www.wago.com/216-284
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-302
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-302
Item no.: 216-321
www.wago.com/216-321
Item no.: 216-322
www.wago.com/216-322
Marking accessories
Item no.: 210-332/500-202
www.wago.com/210-332
Marking strips; as a DIN A4 sheet; MARKED; 1-16 (160x); Height of marker strip: 3 mm; Strip length 182
/500-202
mm; Horizontal marking; Self-adhesive; white
Item no.: 210-332/500-204
Marking strips; as a DIN A4 sheet; MARKED; 17-32 (160x); Height of marker strip: 3 mm; Strip length
182 mm; Horizontal marking; Self-adhesive; white
/500-204
Item no.: 210-332/500-205
Marking strips; as a DIN A4 sheet; MARKED; 1-32 (80x); Height of marker strip: 3 mm; Strip length 182
/500-205
Item no.: 210-332/500-206
Marking strips; as a DIN A4 sheet; MARKED; 33-48 (160x); Height of marker strip: 3 mm; Strip length
/500-206
Downloads
CAD/CAE-Data
CAD data
2D/3D Models 731-140/048-000
URL
Download
Hansastr. 27
32423 Minden
13.07.2020 Page 8/10
CAE data
EPLAN Data Portal 731-140/048-000
URL
Download
ZUKEN Portal 731-140/048-000
URL
Download
Installation Notes
Feedthrough PCB terminal strips – frontentry conductor termination
Feedthrough PCB terminal strips can be
used as front-panel feedthrough for external
conductor termination.
Hansastr. 27
32423 Minden
13.07.2020 Page 9/10
protruding
Hansastr. 27
32423 Minden
13.07.2020 Page 10/10
很抱歉,暂时无法提供与“731-140/048-000”相匹配的价格&库存,您可以联系我们找货
