Data sheet | Item number: 734-204
1-conductor female plug; 100% protected against mismating; 1.5 mm²; Pin
spacing 3.81 mm; 4-pole; 1,50 mm²; orange
www.wago.com/734-204
Color:
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
29.12.2019 Page 1/11
L = (pole no. x pin spacing) + 2.2 mm
Item description
Universal connection for all conductor types
Easy cable pre-assembly and on-unit wiring via vertical and horizontal CAGE CLAMP® actuation
Strain relief plates and housings for field assembly
Coding via coding fingers
Safety information 1:
The MULTI CONNECTION SYSTEM (MCS) is designed without breaking capacity for compliance with DIN EN 61984. When used as intended, MCS
Connectors shall not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are
not live when unmated.
Data
Electrical data
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
160 V
Rated impulse voltage (III / 3)
2.5 kV
Rated voltage (III / 2)
160 V
Rated impulse voltage (III / 2)
2.5 kV
Rated voltage (II / 2)
320 V
Rated impulse voltage (II / 2)
Subject to changes.
Hansastr. 27
32423 Minden
2.5 kV
29.12.2019 Page 2/11
2.5 kV
Rated current
10 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Approvals per UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
10 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Approvals per CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
10 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Connection data
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Solid conductor
0.08 … 1.5 mm² / 28 … 14 AWG
Fine-stranded conductor
Fine-stranded conductor with ferrule with plastic collar
0.25 … 1.5 mm²
Fine-stranded conductor with ferrule without plastic collar
0.25 … 1.5 mm²
Strip length
6 … 7 mm / 0.24 … 0.28 inch
No. of poles
4
Total number of connection points
4
Total number of potentials
4
Number of connection types
1
Number of levels
1
Note (conductor cross-section)
Terminating 1.5 mm² conductors is possible; however insulation
diameter does not allow clamping units to be terminated in a row.
Conductor entry direction to mating direction
0 °
Geometrical Data
Pin spacing
3.81 mm / 0.15 inch
Width
17.44 mm / 0.687 inch
Height
Subject to changes.
Hansastr. 27
32423 Minden
13.4 mm / 0.528 inch
29.12.2019 Page 3/11
Height
Depth
18.6 mm / 0.732 inch
Plug connection
Contact type (pluggable connector)
Female connector/socket
Connector connection type
for conductors
Mismating protection
Yes
Material Data
Color
orange
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Copper alloy
Contact plating
tin-plated
Fire load
0.062 MJ
Weight
3.5 g
Environmental Requirements
Limit temperature range
-60 … +100 °C
Commercial data
Product Group
3 (Multi Conn. System)
Packaging type
BOX
Country of origin
DE
GTIN
4044918494120
Customs Tariff No.
85366990990
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CB
DEKRA Certification B.V.
EN 61984
NL-54190
CSA
C22.2
1465035
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 4/11
KEMA/KEUR
EN 61984
71105522
Ship Approvals
Logo
Approval
Certificate
name
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE000016Z
LR
Lloyds Register
IEC 61984
96/20035
(E5)
UL-Approvals
Logo
Certificate
name
Approval
UL
Underwriters Laboratories Inc.
UL 1977
20150318E45171
UR
UL 1059
20190122E45172
Compatible products
Marking accessories
Item no.: 210-332/350-202
www.wago.com/210-332
Marking strips; as a DIN A4 sheet; MARKED; 1-16 (240x); Height of marker strip: 3 mm; Strip length 182
/350-202
mm; Horizontal marking; Self-adhesive; white
Item no.: 210-332/350-204
Marking strips; as a DIN A4 sheet; MARKED; 17-32 (240x); Height of marker strip: 3 mm; Strip length
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 5/11
182 mm; Horizontal marking; Self-adhesive; white
/350-204
Item no.: 210-332/350-206
Marking strips; as a DIN A4 sheet; MARKED; 33-48 (240x); Height of marker strip: 3 mm; Strip length
/350-206
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated
www.wago.com/216-101
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated
www.wago.com/216-104
Item no.: 216-121
www.wago.com/216-121
Item no.: 216-122
www.wago.com/216-122
Item no.: 216-123
www.wago.com/216-123
Item no.: 216-124
www.wago.com/216-124
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-131
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-141
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-142
Item no.: 216-143
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-143
Item no.: 216-144
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-144
Item no.: 216-151
www.wago.com/216-151
ferrule
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 6/11
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-224
www.wago.com/216-224
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Item no.: 216-262
www.wago.com/216-262
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
Item no.: 216-264
Item no.: 216-284
Subject to changes.
Hansastr. 27
32423 Minden
www.wago.com/216-264
www.wago.com/216-284
29.12.2019 Page 7/11
Item no.: 216-284
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-302
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-302
Item no.: 216-321
www.wago.com/216-321
Item no.: 216-322
www.wago.com/216-322
Item no.: 735-500
Test pin; 1 mm Ø; with solder connection for test wire
www.wago.com/735-500
check
Strain relief plate
Item no.: 734-227
Strain relief plate; orange
www.wago.com/734-227
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
3.6 MB
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 734-204
CAE data
EPLAN Data Portal 734-204
Download
Installation Notes
Inserting a conductor
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 8/11
Inserting a conductor via (2.5 x 0.4) mm
screwdriver – CAGE CLAMP® actuation
perpendicular to conductor entry.
parallel to conductor entry.
Inserting a conductor into CAGE CLAMP®
unit via operating lever (734-191).
unit via operating tool (210-251 or 210-250).
Coding
Coding a female connector – removing
coding finger(s).
Testing
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 9/11
Testing via 1 mm Ø test pin (735-500) –
CAGE CLAMP® connection – touch contact.
Marking
Labeling via direct marking or self-adhesive
strips.
Assembly
Strain relief housing for 734 Series Male and
Female Connectors with CAGE CLAMP®
connection.
Product family
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 10/11
MCS MINI
Show all products from the family
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 11/11
很抱歉,暂时无法提供与“734-204”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+12.59610
- 100+11.33649
- 国内价格 香港价格
- 3+30.628093+3.66300
- 15+29.9784115+3.58530
- 40+29.5143440+3.52980
- 125+29.14309125+3.48540
- 300+28.30778300+3.38550
