734-263
734-263
    WAGO(万可电子)
    插件,P=3.81mm
    接线端子 1x3P 间距:3.81mm 排数:1 每排Pin数:3
734-263 数据手册
Data sheet from 01.06.2011 Item no.: 734-263 Product description: HEADER RIGHT ANGLE SOLDER PIN, 1 X 1 MM / 0.039 X 0.039 IN 3 POLE PIN SPACING 3.81 MM / 0.15 IN 100% PROTECTED AGAINST MISMATING WITH CLOSED END MATING DIRECTION PARALLEL TO PCB Produkt kann von Bild abweichen / product may differ Packing unit 200 pieces Product group 3 (Multi Conn. System) Weight 0.893 g Color orange pole count 3 Height 8.5 mm Height 0.335 in Width 13.52 mm Width 0.532 in Depth 10.3 mm Depth 0.406 in Pin spacing from 3.81 mm Pin spacing from 0.15 in Pollution degree 2 Measured voltage EN 160 V Measured shock voltage 2.5 kV Current intensity EN 10 A Pollution degree 2 Measured voltage EN 320 V 1 von 3 Measured shock voltage 2.5 kV Current intensity EN 10 A Material group I Contact material Electrolytic copper (Ecu) Contact surface tin-plated 2 von 3 Data sheet from 01.06.2011 Item no. Admission office Approval no. Voltage [V] Current [A] Cross section [ mm² ] 734-263 BV 11915/A0 250 10 0,5-1,5 734-263 CCA NL5641 250 10 0,5-1,5 734-263 CSA 154112-1465035 300 10 28-14 734-263 DNV E-9218 250 10 0,5-1,5 734-263 GL 17296-00HH 250 10 0,5-1,5 734-263 KEMA 2077592.02 250 10 0,5-1,5 734-263 LR 96/20035 250 10 0,5-1,5 734-263 RMR 11130002 250 10 0,5-1,5 734-263 UR E45171 250 10 28-14 734-263 UR E45172 300 10 Sorting criteria: admission office - approval number © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 3 von 3
734-263 价格&库存
很抱歉,暂时无法提供与“734-263”相匹配的价格&库存,您可以联系我们找货
