750-402, 750-403 / 753-402, 753-403
4
4-Channel Digital Input Module 24 V DC
2- to 3-conductor connection; high-side switching
13 14
Status
DI 1
DI 3
A
189
Status
DI 2
DI 4
C
B
D
13 14
Data contacts
5
1
DI 1
DI 1
DI 2
DI 2
DI
6
2
24 V
24 V
24 V
10nF
DI
7
3
0V
0V
15 16
0V
10 nF
8
4
DI 4
DI 3
DI 4
DI 3
10nF
750-402
750-402
Power jumper contacts
Fig. 750 Series
Delivered without miniature WSB markers
The digital input module receives control signal from the digital field devices
(sensors, etc.).
Each input module has a noise-rejection filter. This filter is available with
different time constants.
Field and system levels are electrically isolated.
Description
Item No.
Pack.
Unit
Technical Data
4DI 24V DC 3.0ms
4DI 24V DC 0.2ms
4DI 24V DC 3.0ms/T
Extended temperature range: -20 °C ... +60 °C
4DI 24V DC 3.0ms (without connector)
4DI 24V DC 0.2ms (without connector)
750-402
750-403
750-402/025-000
1
1
1
753-402
753-403
1
1
Number of inputs
Current consumption (internal)
Voltage via power jumper contacts
Signal voltage (0)
Signal voltage (1)
Input filter
Item No.
Pack.
Unit
753-110
753-150
25
100
Accessories
753 Series Connectors
Coding elements
Miniature WSB Quick marking system
plain
248-501
with marking
see Section 11
5
Approvals
Conformity marking
Korea Certification
Marine applications (versions upon request)
r UL 508
r ANSI/ISA 12.12.01
4 TÜV 07 ATEX 554086 X
IECEx TUN 09.0001 X
WAGO Kontakttechnik GmbH & Co. KG
Subject to design changes
Input current (typ.)
Isolation
Internal bit width
Wire connection
Cross sections
Strip lengths, 750/753 Series
Width
Weight
EMC immunity of interference
EMC emission of interference
4
7.5 mA
24 V DC (-25 % ... +30 %)
-3 V ... +5 V DC
15 V ... 30 V DC
3.0 ms (750-402 / 753-402)
0.2 ms (750-403 / 753-403)
4.5 mA
500 V system/supply
4 bits
CAGE CLAMP®
0.08 mm² ... 2.5 mm² / AWG 28 ... 14
8 ... 9 mm / 0.33 in
9 ... 10 mm / 0.37 in
12 mm
48.5 g
acc. to EN 61000-6-2, marine applications
acc. to EN 61000-6-4, marine applications
1
(75x-402, 750-402/025-000)
ABS, BV, DNV, GL, KR, LR, NKK, PRS, RINA
Class I, Div. 2, Grp. ABCD, T4
I M2 Ex d I Mb,
II 3 G Ex nA IIC T4 Gc,
II 3 D Ex tc IIIC T135°C Dc
Ex d I Mb,
Ex nA IIC T4 Gc,
26.01.2016
Postfach 2880 - D-32385 Minden
Hansastr. 27 - D-32423 Minden
Tel.: +49(0)571/887-0
E-Mail: info@wago.com
Fax: +49(0)571/887-169
www.wago.com
4.2
很抱歉,暂时无法提供与“750-402”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1373.908321+177.73602
