750-8206
PFC200 CS 2ETH RS CAN DPS
Fieldbus connection Fieldbus connection Serial
PROFIBUS
CAN, CANopen
interface
Marking area
X3 RS232/485
01 02
X4 CAN
SYS RST
RUN
I/O
MS
NS
CAN
BF
DIA
U4
U3
U2
U1
A
B
24V 0V
750-8206
SD
ACT X2 LNK ETH ACT X1 LNK
52
PLC – PFC200 Controller
X5 PROFIBUS
3
Status
voltage supply
-System
-Power jumper
contacts
Data contacts
Supply
24 V
0V
Supply via
power jumper
contacts
24 V
0V
RUN
STOP
RESET
Power jumper
contacts
Fieldbus connection
RJ-45
The PFC200 Controller is a compact PLC for the modular WAGO-I/O-SYSTEM.
Besides network and fieldbus interfaces, the controller supports all digital,
analog and specialty modules found within the 750/753 Series.
Two ETHERNET interfaces and integrated switch enable line topology wiring.
An integrated Web server provides the user with configuration options and
status information from the PFC200.
Besides the processing industry and building automation, typical markets for
the PFC200 include the standard machine and plant industries (e.g.,
packaging, bottling, textiles, production and metal & wood processing).
Fieldbus connection
RJ-45
Programmable to IEC 61131-3
• Programmable via WAGO-I/O-PRO V2.3
• Direct connection of WAGO I/O modules
• 2 x ETHERNET (configurable), RS-232/-485, CAN, CANopen,
PROFIBUS DP Slave
• Linux operating system with RT-Preemption patch
• Configuration via CODESYS, e!COCKPIT or Web-based management
interface
• Maintenance-free
Pack.
Unit
System Data
750-8206
PFC200 CS 2ETH RS CAN DPS/T
750-8206/025-000
Extended temperature range: -20 °C ... +60 °C
PFC200 CS 2ETH RS CAN DPS TELE/T
750-8206/025-001
1
1
1
CPU
Operating system
Main memory (RAM)
Internal memory (flash)
Retain memory
ETHERNET
Transmission medium
Accessories
Item No.
Pack.
Unit
WAGO-I/O-PRO V2.3, RS-232 kit
SD memory card, 2 GB
Miniature WSB Quick marking system
plain
with marking
759-333
758-879/000-001
1
1
Baud rate
Interface (serial)
Fieldbus
Protocols
248-501
see Section 11
5
Description
Item No.
750-8206/025-001
Programming
IEC 61131-3
SD card slot
Type of memory card
Approvals
Conformity marking
Korea Certification
Marine applications (versions upon request)
r UL 508
r ANSI/ISA 12.12.01
4 TÜV 14 ATEX 148929 X
IECEx TUN 14.0035 X
WAGO Kontakttechnik GmbH & Co. KG
Subject to design changes
Configuration and
programming interface
1
Cortex A8, 600 MHz
Real-time Linux (with RT-Preemption patch)
256 Mbytes
256 Mbytes
128 Kbytes
2 x RJ-45 (switched)
Twisted Pair S-UTP
100 Ω, Cat 5;
Max. line length: 100 m
10/100 Mbit/s; 10Base-T/100Base-TX
RS-232/-485 (switchable)
PROFIBUS DP Slave, CAN, CANopen
DHCP, DNS, NTP, FTP, FTPS, SNMP, HTTP,
HTTPS, SSH, MODBUS (TCP, UDP, RTU)
IEC 60870-5-101/-103/-104,
IEC 61850-7-4, IEC 61400-25, DNP3
WAGO-I/O-PRO V2.3, e!COCKPIT
IL, LD, FBD (CFC), ST, FC
Push-push mechanism, sealable cover lid
SD and SDHC up to 32 GB (All
guaranteed properties are only valid in
connection with the WAGO 758-879/
000-001 memory card.)
(750-8206)
GL
Class I, Div. 2, Grp. ABCD, T4
II 3 G Ex nA IIC T4 Gc (750-8206)
31.05.2016
Postfach 2880 - D-32385 Minden
Hansastr. 27 - D-32423 Minden
Tel.: +49(0)571/887-0
E-Mail: info@wago.com
Fax: +49(0)571/887-169
www.wago.com
3
53
1
1
5
10 nF
0V
2
6
24 V
DC
DC
5
2/6
I/O modules
24 V
ELECTRONICS
Bob Smith
Termination
47 nF
Bob Smith
Termination
47 nF
ELECTRONICS
3
ETHERNET
Interface RS-232/-485
Interface CAN
Interface PROFIBUS
10 nF
7
0V
3/7
Interface
CAN
10 nF
4
8
Interface
RS-232/-485
Interface
PROFIBUS
10 nF
4/8
750-8206
Technical Data
Number of I/O modules (per node)
with bus extension
Input and output process image (max.)
Internal data bus
MODBUS
PROFIBUS
CAN
I/O interfaces (serial)
Diagnostic LEDs
User LEDs
Memory configuration CODESYS 2.3
Program memory
Data memory
Non-volatile memory (retain)
Memory configuration e!RUNTIME
Program and data memory
Power supply
Max. input current (24 V)
Total current for I/O modules (5 V)
Isolation
General Specifications
64
250
1000 words
1000 words
244 bytes in 80 slots
2000 words
1 x serial interface per TIA/EIA 232 and
TIA/EIA 485 (switchable), 9-pole D-sub
female connector
Power supply;
SYS; RUN;
FIELDBUS (MS, NS, CAN, DIA, BF);
USER (U1 ... U4);
Internal data bus
via CODESYS library
16 MB
64 MB
128 KB
60 MB (dynamically distributed)
128 KB
24 V DC (-25 % ... +30 %)
550 mA
1700 mA
500 V system/supply
Dimensions (mm) W x H x L
Weight
EMC immunity of interference
EMC emission of interference
Degree of protection
Type of mounting
Housing material
Ambient conditions
Operating temperature
Storage temperature
Relative air humidity (no condensation)
Wire connection
Cross sections
Strip lengths
112 x 65 x 100
Height from upper-edge of DIN 35 rail
256 g
acc. to EN 61000-6-2, marine applications
acc. to EN 61000-6-3, marine applications
IP20 acc. to DIN 60529
DIN 35 rail
PC
0 °C ... +55 °C
-25 °C ... +85 °C
95 %
CAGE CLAMP®
0.08 mm² ... 2.5 mm² / AWG 28 ... 14
8 ... 9 mm / 0.33 in
3.1
