773-104/VE00-0500
773-104/VE00-0500
    WAGO(万可电子)
    PUSHWIRE SPLICING CONNECTOR; 4-
773-104/VE00-0500 数据手册
Connect Stranded and u Solid Wire File: E69654 WALL-NUTS™ 600 V building wiring 1000 V fixtures and signs Current rating: Largest conductor used 105° C rated (221° F) Fast - Safe - Easy Clear housing allows visual confirmation of connection Test port for easy continuity testing 2 File: LR46759 Yellow 2-conductor, 100 pc/box For 500 piece bag, order: Ground 2-conductor, 100 pc/bx: For 2500 piece bag, order: · 12-16 AWG Stranded Copper (stranding pattern less than or equal to 19) · 12-18 AWG Solid Copper 773-102/VE00-0500 773-102/VE00-2500 773-162 · 12-16 AWG Stranded Copper (stranding pattern less than or equal to 19) · 12-18 AWG Solid Copper 773-112 Orange 4-conductor, 100 pc/box For 500 piece bag, order: Ground 4-conductor, 100 pc/bx: For 2500 piece bag, order: · 12-16 AWG Stranded Copper (stranding pattern less than or equal to19) · 12-18 AWG Solid Copper 773-104/VE00-0500 773-104/VE00-2500 773-164 · 12-16 AWG Stranded Copper (stranding pattern less than or equal to19) · 12-18 AWG Solid Copper 773-114 Lt. Gry Special 4-cond. 100pc/box For 2500 piece bag, order: (Special opening) · 12-16 AWG Stranded Copper (stranding pattern less than or equal to 19) · 12-18 AWG Solid Copper · 18 AWG Stranded Copper (Stranding pattern less than or equal to 16) · 18 AWG Solid Copper 773-124/VE01-0000 773-124 Black 6-conductor, 50pc/box For 500 piece bag, order: Ground 6-conductor, 50 pc/box: For 2500 piece bag, order: · 12-16 AWG Stranded Copper (stranding pattern less than or equal to 19) · 12-18 AWG Solid Copper 773-166/VE00-0500 773-166/VE00-2500 773-166 · 12-16 AWG Stranded Copper (stranding pattern less than or equal to 19) · 12-18 AWG Solid Copper 773-116 Dark Grey 8-conductor, 50pc/bg For 2500 piece bag, order: Ground 8-conductor, 50 pc/bg · 12-16 AWG Stranded Copper (stranding pattern less than or equal to 19) · 12-18 AWG Solid Copper · 12-16 AWG Stranded Copper (stranding pattern less than or equal to 19) · 12-18 AWG Solid Copper 773-108/VE00-2500 773-168 773-118 WAGO Corporation N120 W19129 Freistadt Rd., P.O. Box 1015, Germantown, WI 53022 Tel.: 262 / 255-6222 Fax: 262 / 255-3232 Toll Free: 1-800-DIN RAIL (346-7245) www.wago.com info.us@wago.com WALL-NUTS™ Pushwire Connectors for solid and stranded copper wire Introducing WALL-NUTS™ WALL-NUTS™ are the first push-in connectors that connect both stranded and solid copper wires. Now you can use the speed and dependability of push-wire technology in every application. See The Safety WALL-NUTS™ clear housing means you can see the firm connection of solid or stranded conductors. No more guessing whether the wires are twisted together or are pushed in far enough.  Visual inspection allows you to see that WALLNUTS™ make reliable connections. Fast, Easy Installation The new WALL-NUTS™ push-in connectors makes the job of wire connecting easier. No more twisting and taping required. Simply strip the wire; insert the conductor and you’re finished. The integrated test port allows for continuity testing without reinsertion. Toll Free: 1-800-DIN RAIL (346-7245) Safe WALL-NUTS™ hold each wire individually, eliminating loose connections. WALL-NUTS™ are touch-proof and rated to 105° C. WALL-NUTS™ are UL Listed/CSA certified for 600 volts (1000 volts for fixtures and signs) and current rated to the largest conductor used. are perfect for new construction and retrofit work. WALL-NUTS™ Save Time WALL-NUTS™ provide up to 50% time savings on installation. Secure connections reduce expensive trouble shooting and warranty work. work with solid and stranded wire making main, branch and fixture hookup fast, easy and safe. WALL-NUTS™ 18 AWG Stranded Range The 773-124 has a special opening that accepts 18 AWG stranded copper wire. This makes the connection of incandescent light fixtures, dimmer switches, ceiling fans and other accessories to branch and main circuits a breeze. Toll Free: 1-800-DIN RAIL (346-7245) WALL-NUTS™ The 773-124’s special opening wire range 18 stranded or solid; 18-22 tinned stranded copper.
773-104/VE00-0500 价格&库存
很抱歉,暂时无法提供与“773-104/VE00-0500”相匹配的价格&库存,您可以联系我们找货
