Printview: PUSH WIRE® connector for junction boxes; 6-conductor terminal block; transparent housing;
black cover - Item No.: 773-166
block; transparent housing; black cover
Item No.: 773-166
PUSH WIRE® connector for junction boxes; 6-conductor terminal block; transparent housing; black cover
Marking
Business data
Supplier
WAGO
Item no.
773-166
GTIN / EAN
4044918398060
Content
1
Order amount
50
Customer item number
Notes
Technical data
Miscellaneous
Total number of connection points
6
Total number of potentials
1
Color
transparent
Pollution degree (1)
2
Rated voltage EN (1) [V]
400 [V]
Rated surge voltage (1) [kV]
4 [kV]
Nominal current [A]
24 [A]
Connection technology (1)
PUSH WIRE®
Solid sizes 1
0.75 … 2.5 mm² / 18 … 12 AWG
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Strip length 1
12 mm / 0.47 in
Type of wiring
Side-entry wiring
Weight [g]
4.25 [g]
Width
18.8 mm / 0.74 in
Height
13.1 mm / 0.516 in
Length
19.5 mm / 0.768 in
Safety information 1
In grounded power lines
2
Images & drawings
3
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
4
很抱歉,暂时无法提供与“773-166”相匹配的价格&库存,您可以联系我们找货
