890-1620
890-1620
    WAGO(万可电子)
    接线端子
890-1620 数据手册
1 Handling WINSTA ®  Preparation 1. 4USJQMFOHUI PVUFSJOTVMBUJPO  4USJQMFOHUI  3. &YUFOEFEHSPVOEDPOEVDUPS YNN1 NN NN MINI, 890 Series Termination via CAGE CLAMP® S Strain relief installation 5PUFSNJOBUFmOFTUSBOEFEDPOEVDUPST PQFODMBNQJOHVOJU WJBNNTDSFXESJWFSBOEJOTFSUTUSJQQFEDPOEVDUPSVOUJM it hits backstop. Solid conductors can be terminated by simply pushing them in. -BUDIXJSFEDPOOFDUPSPOUPUIFCBTFPGUIFTUSBJOSFMJFG housing. Apply the shield to the rubber cable. 4USJQMFOHUI PVUFSJOTVMBUJPONN 4IJFMEMFOHUINN Push the shield connecting plate into the connector until fully inserted. Conductor termination with . . . 5PUFSNJOBUFmOFTUSBOEFEDPOEVDUPST PQFODMBNQJOHVOJUT WJBPQFSBUJOHUPPMBOEJOTFSUTUSJQQFEDPOEVDUPST until they hit backstop. Solid conductors can be terminated by simply pushing them in. . . . Operating tool 5PUFSNJOBUFmOFTUSBOEFEDPOEVDUPST PQFODMBNQJOHVOJUT WJBPQFSBUJOHUPPMBOEJOTFSUTUSJQQFEDPOEVDUPST until they hit backstop. Solid conductors can be terminated by simply pushing them in. Shield termination $POOFDUPSXJUITIJFMEUFSNJOBUJPO 14USJQMFOHUI PVUFSJOTVMBUJPOQPMFNN QPMFNN BOEQPMFNN !1  1 1VTIEPXOTUSBJOSFMJFGDMBNQCZIBOE 1VTIEPXOTUSBJOSFMJFGDMBNQWJBNNTDSFXESJWFS alternately on both sides. Latch the top of the strain relief housing. Mounting plate installation 4FDVSJOHUIFNPVOUJOHQMBUFWJBmYJOHQJOT Snapping on distribution connector 5IFEJTUSJCVUJPODPOOFDUPSTTOBQUPHFUIFSXIFOBUUBDIFE to the mounting plate. 'JSTUJOTFSUXJSFEDPOOFDUPSJOUPTUSBJOSFMJFGIPVTJOH UIFO snap clamp and cover. Locking lever assembly Marking "MMDPOOFDUPST TOBQJOWFSTJPOT EJTUSJCVUJPODPOOFDUPST  GPSmYFEJOTUBMMBUJPOTBSFGBDUPSZFRVJQQFEXJUIMPDLJOH levers to ensure plugs and sockets are securely locked. AdEJUJPOBMMPDLJOHMFWFSTBSFPOMZSFRVJSFEGPSinZJOHMFBETw QMVHTPDLFU  The printed marking of the connector is clearly visible in the openings of the strain relief housing. WINSTA® - Perfectly plugged! 1 WINSTA® MINI Snap-In Sockets and Plugs, 2-Pole !  0.25 – 1.5 mm² 1 250 V/4 kV/3 IN 16 A Cutout dimensions Plate thickness: 0.5 – 2 mm Cutout tolerance: + 0.1 mm AWG 22 – 16 0.25 – 1.5 mm² 1 250 V/4 kV/3 IN 16 A L 9 mm / 0.35 in L 9 mm / 0.35 in 2 Approvals 2 Approvals AWG 22 – 16 Description Color Pluggable connectors, snap-in device connection, 2-pole, with CAGE CLAMP®S connection Socket  black XIJUF blue Item No. Pack. Unit Color Item No. Pack. Unit 890-712 890-732 890-2112       Plug 890-702 890-722 890-2102        black XIJUF blue Item-Specific Accessories Operating tool, insulated QPMF Operating tool, insulated QPMF 890-392   1 890-392   1 Accessories, 890 Series Lockout cap, GPSDVUPVU QPMF   black XIJUF 890-642  890-692  Coding A Coding A Coding I (L N) (L N) (+ –) For coding information, see pages 224 to 226. Fire load data available upon request. 1,5 > 4,7 WINSTA® - Perfectly plugged!
890-1620 价格&库存
很抱歉,暂时无法提供与“890-1620”相匹配的价格&库存,您可以联系我们找货
