Item no.:
Product description:
Weight
Colour
No. of connection Points
No. of potentials
pole count
Height
Width
Depth
Pin spacing from
Pin spacing up to
Measured voltage EN
Measured shock voltage
Current intensity EN
Pollution degree
Measured voltage EN
Connection method
Cross section [mm²]
Wiring method
Cross section [mm²]
Cross section [mm²]
Cross section [mm²]
Cross section [AWG]
Strip length from
Strip length to
236-402
PCB TERMINAL STRIP 2 SOLDER PINS / POLE 2 POLE
PIN SPACING 5/5.08 MM / 0.2 IN
1.88 g
gray
2
2
2
13 mm / 0.512 in
12.3 mm / 0.484 in
14 mm / 0.551 in
5.08 mm
5.08 mm / 0.2 in
320 V
4 kV
24 A
2
630 V
4 kV
24 A
CAGE CLAMP® CONNECTION
0.08 - 2.5 mm²
solid
0.08 - 2.5 mm²
0.25 - 1.5 mm²
0.25 - 1.5 mm²
28 - 12 AWG
5 mm
6 mm
很抱歉,暂时无法提供与“0236-0402”相匹配的价格&库存,您可以联系我们找货
