Printview: 2-conductor through terminal block; suitable for Ex e II applications; suitable for Ex i applications
- Item No.: 2000-1204
Item No.: 2000-1204
Marking
Business data
Supplier
WAGO
Item no.
2000-1204
GTIN / EAN
4045454966799
Content
1
Order amount
100
Customer item number
Notes
Technical data
Miscellaneous
Total number of connection points
2
Total number of potentials
1
Color
blue
Ratings according to 1
IEC/EN 60947-7-1
Pollution degree (1)
3
Rated voltage EN (1) [V]
800 [V]
Rated surge voltage (1) [kV]
8 [kV]
Nominal current [A]
13.5 [A]
Nominal current (2) [A]
18 [A]
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Rated voltage EN (Ex e II) [V]
550 [V]
Nominal current (Ex e II) [A]
13 [A]
Nominal current (Ex e II) with jumper [A]
12 [A]
Connection technology (1)
Push-in CAGE CLAMP®
Nominal cross section 1
1 mm²
Solid sizes 1
0.14 … 1.5 mm² / 24 … 16 AWG
solid, directly pluggable 1
0.5 … 1.5 mm² / 20 … 16 AWG
Fine-stranded wires 1
min. fine-stranded with insulated ferrule, push-in terminati 0.5 mm² / 20 AWG
Strip length 1
9 … 11 mm / 0.35 … 0.43 in
Type of wiring
Front-entry wiring
Design
horizontal
Marking level
Center/Side marking
Insulating material
Polyamide 66 (PA 66)
Fire load [MJ]
0.079 [MJ]
Weight [g]
3.58 [g]
Width
3.5 mm / 0.138 in
Height from upper-edge of DIN-rail [mm]
32.9 [mm]
32.9 mm / 1.295 in
Length
48.5 mm / 1.909 in
Type of mounting
DIN 35 rail
2
Images & drawings
3
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
4
很抱歉,暂时无法提供与“2000-1204”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+20.3954250+2.65134
- 100+18.83742100+2.44881
- 250+12.96087250+1.68487
- 500+12.18154500+1.58356
- 1000+11.541831000+1.50040
- 5000+10.600045000+1.37797
- 国内价格 香港价格
- 4+32.183674+4.18378
- 10+24.8673610+3.23268
- 25+22.1981125+2.88569
