2002-1611/1000-836
2002-1611/1000-836
    WAGO(万可电子)
    端子块连接器 2 位置 断连 灰色 12-18 AWG
2002-1611/1000-836 数据手册
Data sheet | Item number: 2002-1611/1000-836 2-conductor fuse terminal block; with pivoting fuse holder; with end plate; for 5 x 20 mm miniature metric fuse; with blown fuse indication by LED; 230 V; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; Push-in CAGE CLAMP®; 2,50 mm²; gray www.wago.com/2002-1611/1000-836 Color: Item description Safety information 1: Electrical ratings are given by the fuse and blown fuse indication. Safety information 2: Leakage current in case of a blown fuse: LED 2 mA Data Electrical data Power loss (max.) Pl (max.) (note) When selecting glass cartridge fuses, make sure that the maximum power loss listed below is not exceeded. The power loss is determined according to IEC or EN 60947-7-3/VDE 0611-6 at 23°C. The temperature rise of the terminal block must be checked according to their application and mounting. Higher ambient temperatures represent an additional impact on miniature fuses. Therefore, in such applications, the rated current must be reduced if necessary. More details are available from the manufacturers. Power loss Pl (max.) 1.6 W Power loss Pl (note) Overload and short circuit protection (Individual arrangement) Power loss Pl 2 (max.) 1.6 W Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 1/18 Data sheet | Item number: 2002-1611/1000-836 www.wago.com/2002-1611/1000-836 Power loss Pl 2 (max.) 1.6 W Power loss Pl 2 (note) Overload and short circuit protection (Group arrangement) Power loss Pl 3 (max.) 2.5 W Power loss Pl 3 (note) Short circuit protection only (Individual arrangement) Power loss Pl 4 (max.) 2.5 W Power loss Pl 4 (note) Short circuit protection only (Group arrangement) Ratings per IEC/EN Ratings per IEC/EN 60947-7-3 Nominal voltage (III/3) 250 V Rated surge voltage (III/3) 6 kV Rated current 6.3 A Operation status indicator 230 V Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Ratings per UL Approvals per UL 1059 Rated voltage UL (Use Group B) 250 V Rated current UL (Use Group B) 10 A Rated voltage UL (Use Group C) 250 V Rated current UL (Use Group C) 10 A Rated voltage UL (Use Group D) 250 V Rated current UL (Use Group D) 10 A Ratings per CSA Approvals per C22.2 No 158 Rated current CSA (Use Group B) 10 A Rated current CSA (Use Group C) 10 A Ex information Ratings per ATEX: KIWA 17 ATEX 0030 U / IECEx: KIWA 17.0014U (Ex ec IIC Gc) Rated voltage EN (Ex e II) 230 V Rated current (Ex e II) 6.3 A Connection data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 2/18 Data sheet | Item number: 2002-1611/1000-836 www.wago.com/2002-1611/1000-836 Connection data Connection technology Push-in CAGE CLAMP® Actuation type Push-in Open Tool Slot Connectable conductor materials Copper Nominal cross-section 2.5 mm² Solid conductor 0.25 … 4 mm² / 22 … 12 AWG Solid conductor; push-in termination 0.75 … 4 mm² / 18 … 12 AWG Fine-stranded conductor 0.25 … 4 mm² / 22 … 12 AWG Fine-stranded conductor; with insulated ferrule 0.25 … 2.5 mm² / 22 … 14 AWG Fine-stranded conductor; with ferrule; push-in termination 1 … 2.5 mm² / 18 … 14 AWG Note (conductor cross-section) Depending on the conductor characteristic, a conductor with a smaller cross-section can also be inserted via push-in termination. Strip length 10 … 12 mm / 0.39 … 0.47 inch Total number of connection points 2 Total number of potentials 1 Number of levels 1 Wiring direction Front-entry wiring Number of jumper slots 2 Physical data Width 6.2 mm / 0.244 inch Height 66.1 mm / 2.602 inch Depth from upper edge of DIN-rail 57.2 mm / 2.252 inch Mechanical data Design horizontal type Mounting type DIN-35 rail Marking level Center/side marking Art der Sicherung Cylindrical fuse 5 x 20 mm Material data Color gray Insulation material Polyamide (PA66) Flammability class per UL94 V0 Fire load 0.282 MJ Weight 13.7 g Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 3/18 Data sheet | Item number: 2002-1611/1000-836 www.wago.com/2002-1611/1000-836 Weight 13.7 g Commercial data Product Group 22 (TOPJOB S) PU (SPU) 50 Stück Packaging type box Country of origin CN GTIN 4045454790042 Customs tariff number 85369095000 Approvals / Certificates Ex-Approvals Logo Approval Additional Approval Text Certificate name AEx Underwriters Laboratories Inc. UL 60079 20190704-E185892 ATEX KIWA Netherlands B.V. EN 60079 KIWA 17ATEX0030 U CCCEx CQST/CNEx CNCA-C23-01 2020312313000180 IECEx KIWA Netherlands B.V. EN 60079 IECEx KIWA 17.0014 U (Ex ec IIC Gc) Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 NTR NL 7730 KEMA/KEUR DEKRA Certification B.V. EN 60947 71107687 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 4/18 Data sheet | Item number: 2002-1611/1000-836 www.wago.com/2002-1611/1000-836 Ship Approvals Logo Certificate name Approval Additional Approval Text ABS American Bureau of Shipping EN 60947 20HG1941090PDA DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001V2 UL-Approvals Logo Approval Additional Approval Text Certificate name UL Underwriters Laboratories Inc. UL 1059 E45172 Optional accessories Carrier rail Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; www.wago.com/210-112 silver-colored Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-113 Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored www.wago.com/210-114 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115 silver-colored Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-118 Item no.: 210-196 www.wago.com/210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; copper- www.wago.com/210-197 www.wago.com/210-198 colored Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 5/18 Data sheet | Item number: 2002-1611/1000-836 www.wago.com/2002-1611/1000-836 colored Item no.: 210-504 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715; silvercolored www.wago.com/210-504 Item no.: 210-505 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715; silver-colored www.wago.com/210-505 Item no.: 210-506 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715; silvercolored www.wago.com/210-506 Item no.: 210-508 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715; silvercolored www.wago.com/210-508 Protective warning marker Item no.: 2002-115 Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow www.wago.com/2002-115 Item no.: 210-658 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short; multicoloured www.wago.com/210-658 Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured www.wago.com/210-720 Tool Testing and measuring Item no.: 210-136 Test plug; 2 mm Ø; with 500 mm cable; red www.wago.com/210-136 Item no.: 2002-991 End plate for fuse terminal blocks; 2 mm thick; gray www.wago.com/2002-991 Item no.: 2002-992 End plate for fuse terminal blocks; 2 mm thick; orange www.wago.com/2002-992 Item no.: 209-191 Separator for Ex e/Ex i applications; 3 mm thick; 120 mm wide; orange www.wago.com/209-191 Item no.: 2004-402 Jumper; 2-way; insulated; light gray www.wago.com/2004-402 Item no.: 2004-403 Jumper; 3-way; insulated; light gray www.wago.com/2004-403 Item no.: 2004-404 Jumper; 4-way; insulated; light gray www.wago.com/2004-404 Item no.: 2004-405 Jumper; 5-way; insulated; light gray www.wago.com/2004-405 End plate Jumpers Item no.: 2004-405/011-000 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2004-405 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 6/18 Data sheet | Item number: 2002-1611/1000-836 www.wago.com/2002-1611/1000-836 Item no.: 2004-405/011-000 Star point jumper; 3-way; insulated; light gray www.wago.com/2004-405 /011-000 Item no.: 2004-406 Jumper; 6-way; insulated; light gray www.wago.com/2004-406 Item no.: 2004-406/020-000 Delta jumper; insulated; light gray www.wago.com/2004-406 /020-000 Item no.: 2004-407 Jumper; 7-way; insulated; light gray www.wago.com/2004-407 Item no.: 2004-408 Jumper; 8-way; insulated; light gray www.wago.com/2004-408 Item no.: 2004-409 Jumper; 9-way; insulated; light gray www.wago.com/2004-409 Item no.: 2004-410 Jumper; 10-way; insulated; light gray www.wago.com/2004-410 Item no.: 2004-433 Jumper; from 1 to 3; insulated; light gray www.wago.com/2004-433 Item no.: 2004-434 Jumper; from 1 to 4; insulated; light gray www.wago.com/2004-434 Item no.: 2004-435 Jumper; from 1 to 5; insulated; light gray www.wago.com/2004-435 Item no.: 2004-436 Jumper; from 1 to 6; insulated; light gray www.wago.com/2004-436 Item no.: 2004-437 Jumper; from 1 to 7; insulated; light gray www.wago.com/2004-437 Item no.: 2004-438 Jumper; from 1 to 8; insulated; light gray www.wago.com/2004-438 Item no.: 2004-439 Jumper; from 1 to 9; insulated; light gray www.wago.com/2004-439 Item no.: 2004-440 Jumper; from 1 to 10; insulated; light gray www.wago.com/2004-440 Item no.: 210-103 Wire commoning chain; insulated; black www.wago.com/210-103 Item no.: 210-123 Wire commoning chain; insulated; blue www.wago.com/210-123 Insulation stop Item no.: 2002-171 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2002-171 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 7/18 Data sheet | Item number: 2002-1611/1000-836 www.wago.com/2002-1611/1000-836 Item no.: 2002-171 Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray www.wago.com/2002-171 Item no.: 2002-172 Insulation stop; 0.75 - 1 mm²; 5 pieces/strip; dark gray www.wago.com/2002-172 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Ferrule Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-244 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-244 Item no.: 216-246 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-246 Item no.: 216-262 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-262 Item no.: 216-263 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-264 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-264 Item no.: 216-266 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-266 Locking levers Item no.: 210-254 Interlocking link; mechanically locks multiple links; 1 m long; transparent www.wago.com/210-254 Marking accessories Item no.: 2009-110 Marking strips; for Smart Printer; on reel; not stretchable; plain; snap-on type; white www.wago.com/2009-110 Item no.: 2009-115 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-115 Item no.: 2009-115/000-002 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-115 /000-002 Item no.: 2009-115/000-005 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2009-115 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 8/18 Data sheet | Item number: 2002-1611/1000-836 www.wago.com/2002-1611/1000-836 Item no.: 2009-115/000-005 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/2009-115 /000-005 Item no.: 2009-115/000-006 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/2009-115 /000-006 Item no.: 2009-115/000-007 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/2009-115 /000-007 Item no.: 2009-115/000-012 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-115 /000-012 Item no.: 2009-115/000-017 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light green www.wago.com/2009-115 /000-017 Item no.: 2009-115/000-023 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-115 /000-023 Item no.: 2009-115/000-024 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-115 /000-024 Item no.: 2009-145 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white Item no.: 2009-145/000-002 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-145 /000-002 Item no.: 2009-145/000-005 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/2009-145 /000-005 Item no.: 2009-145/000-006 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue /000-006 Item no.: 2009-145/000-007 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray /000-007 Item no.: 2009-145/000-012 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-145 /000-012 Item no.: 2009-145/000-023 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-145 /000-023 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 9/18 Data sheet | Item number: 2002-1611/1000-836 www.wago.com/2002-1611/1000-836 Item no.: 2009-145/000-024 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-145 /000-024 Item no.: 248-501 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 Item no.: 248-501/000-002 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/248-501 /000-002 Item no.: 248-501/000-005 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/248-501 /000-005 Item no.: 248-501/000-006 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/248-501 /000-006 Item no.: 248-501/000-007 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/248-501 /000-007 Item no.: 248-501/000-012 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/248-501 /000-012 Item no.: 248-501/000-017 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/248-501 /000-017 Item no.: 248-501/000-023 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/248-501 /000-023 Item no.: 248-501/000-024 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/248-501 /000-024 Item no.: 793-501 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 Item no.: 793-501/000-002 WMB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/793-501 /000-002 Item no.: 793-501/000-005 WMB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/793-501 /000-005 Item no.: 793-501/000-006 WMB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/793-501 /000-006 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 10/18 Data sheet | Item number: 2002-1611/1000-836 www.wago.com/2002-1611/1000-836 Item no.: 793-501/000-007 WMB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/793-501 /000-007 Item no.: 793-501/000-012 WMB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/793-501 /000-012 Item no.: 793-501/000-017 WMB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/793-501 /000-017 Item no.: 793-501/000-023 WMB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/793-501 /000-023 Item no.: 793-501/000-024 WMB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/793-501 /000-024 Item no.: 793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501 type; white Item no.: 793-5501/000-002 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-002 type; yellow Item no.: 793-5501/000-005 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-005 type; red Item no.: 793-5501/000-006 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-006 type; blue Item no.: 793-5501/000-007 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-007 type; gray Item no.: 793-5501/000-012 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-012 type; orange Item no.: 793-5501/000-014 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-014 type; brown Item no.: 793-5501/000-017 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-017 type; green Item no.: 793-5501/000-023 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 11/18 Data sheet | Item number: 2002-1611/1000-836 www.wago.com/2002-1611/1000-836 Item no.: 793-5501/000-023 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501 /000-023 type; light green Item no.: 793-5501/000-024 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-024 type; violet Downloads Documentation Bid Text 2002-1611/1000-836 23 Apr 2019 docx 16.0 kB Download 29 Apr 2019 xml 4.4 kB Download 3 Apr 2019 pdf 2.2 MB Download URL Download EPLAN Data Portal 2002-1611/1000-836 URL Download WSCAD Universe 2002-1611/1000-836 URL Download ZUKEN Portal 2002-1611/1000-836 URL Download EPLAN Data Portal 2002-1611/1000-836 URL Download WSCAD Universe 2002-1611/1000-836 URL Download docx - Datei 2002-1611/1000-836 X81 - Datei Additional Information Technical explanations CAD/CAE-Data CAD data 2D/3D Models 2002-1611/1000-836 CAE data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 12/18 Data sheet | Item number: 2002-1611/1000-836 www.wago.com/2002-1611/1000-836 Environmental Product Compliance Compliance Search Environmental Product Compliance 2002-1611/1000-836 URL Download 2-conductor fuse terminal block; with pivoting fuse holder; with end plate; for 5 x 20 mm miniature metric fuse; with blown fuse indication by LED; 230 V; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; Push-in CAGE CLAMP®; 2,50 mm²; gray Installation Notes Inserting a conductor All conductor types at a glance Push-in termination of solid and ferruled conductors Inserting a conductor via push-in termination: Solid conductors with cross-sections from either one size above, or up to two sizes below, the rated cross-section can be simply pushed in – no tools needed. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 13/18 Data sheet | Item number: 2002-1611/1000-836 www.wago.com/2002-1611/1000-836 Inserting a conductor via operating tool: Conductor termination – insulation stop Connecting fine-stranded conductors without ferrules, or small cross-sectional conductors that cannot be pushed in, is performed similarly to the original CAGE CLAMP® – just use an operating tool. Advantage: To open the clamp, the operating tool is inserted vertically. The conductor entry is less than 15 degrees for easier wiring. Commoning Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 14/18 Data sheet | Item number: 2002-1611/1000-836 www.wago.com/2002-1611/1000-836 The push-in type jumper bar system is based on the common plug and socket principle. Each terminal block is spring-loaded with a double socket and a resilient CrNi steel spring. The jumper contact material is pure electrolytic copper, which allows for an extremely small design capable of carrying the full-rated current of the terminal block. Ground terminal blocks can also be commoned using the same jumper system. Custom jumpers are created by breaking and removing jumper contacts (2000, 2001, 2002, 2004 Series). Removing a push-in type jumper bar: Insert the operating tool between the jumper and partition wall of the dual jumper slots, then lift up the jumper. Place the operating tool in the center of jumpers for up to five contacts (see above), or alternately on both sides for jumpers with more than five contacts. Fuse terminal blocks with a width of 6.2 mm /0.244 in can be assembled adjacently. If there is no adjacent fuse terminal block at the end of the assembly, an end plate must be used. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 15/18 Data sheet | Item number: 2002-1611/1000-836 www.wago.com/2002-1611/1000-836 Fused Disconnect Terminal Block with a Pivoting Fuse Holder Fused disconnect terminal block with a pivoting fuse holder Pivot the fuse holder into the locked open position. Fuse replacement When selecting glass cartridge fuses, make sure that the maximum power loss listed below is not exceeded. The power loss is determined according to IEC or EN 60947-73/VDE 0611-6 at 23°C. The temperature rise of the terminal block must be checked according to their application and mounting. Higher ambient temperatures represent an additional impact on miniature fuses. Therefore, in such applications, the rated current must be reduced if necessary. More details are available from the manufacturers. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 16/18 Data sheet | Item number: 2002-1611/1000-836 www.wago.com/2002-1611/1000-836 Application Notes on Terminal Blocks for Glass Cartridge Fuses Application Notes on Terminal Blocks for Glass Cartridge Fuses Diagram: “Individual Arrangement” Diagram: “Block Arrangement” Application Notes on Terminal Blocks for Glass Cartridge Fuses Nominal current ratings for fuse cartridges are defined differently in international standards. This is why the recommended continuous current-carrying capacity of the fuses is a max. 80% of their nominal current according to DIN 72581/Part 3 (for a surrounding air temperature of 23°C). Selecting the correct fuse cartridge is important for product safety within applications, as well as for fuse cartridge service life and reliability. Fuse cartridges will only operate perfectly as protection components (break-off point) if they are properly selected and used as intended (i.e., according to the state of the technology and valid specifications, as well as data sheet characteristics), according to basic safety requirements (i.e., persons, animals and property must be protected against hazards). Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 17/18 Data sheet | Item number: 2002-1611/1000-836 www.wago.com/2002-1611/1000-836 Concerning product safety, fuse cartridges must generally be tested under both normal and faulty operating conditions within your application. Marking Snapping WMB Inline markers into marker slots. Product family TOPJOB® S TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections. Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 18/18
2002-1611/1000-836 价格&库存
很抱歉,暂时无法提供与“2002-1611/1000-836”相匹配的价格&库存,您可以联系我们找货
