Data sheet | Item number: 2002-409
TOPJOB®S jumper; for 2002 series; insulated; 9-way; light-gray
www.wago.com/2002-409
i
Picture differs from the item.
Color:
Data
Electrical data
IEC Approvals
Rated voltage (III / 3)
800 V
Rated current
25 A
Ex information
Rated current (Ex e II)
20 A
Subject to changes. Please also observe the further product documentation!
WAGO Corporation
Germantown, WI 53022
Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222
Email: info.us@wago.com | Web: www.wago.us
Do you have any questions about our products?
We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL.
02.08.2021 Page 1/5
Connection data
Jumper assignment
9-way
Physical data
Width
45.2 mm / 1.78 inch
Height
4.1 mm / 0.161 inch
Depth
19 mm / 0.748 inch
Jumper assignment
9-way
Material data
Color
light gray
Fire load
0.032 MJ
Weight
4.4 g
Commercial data
Product Group
22 (TOPJOB S)
Packaging type
bag
Country of origin
DE
GTIN
4017332999410
Customs tariff number
8536698000
Downloads
Documentation
Bid Text
2002-409
19 Feb 2019
xml
2.6 kB
Download
27 Apr 2017
doc
24.1 kB
Download
3 Apr 2019
pdf
2.2 MB
Download
X81 - Datei
2002-409
doc - Datei
Additional Information
Technical explanations
WAGO Corporation
02.08.2021 Page 2/5
CAD files
CAD data
2D/3D Models 2002-409
URL
Download
EPLAN Data Portal 2002-409
URL
Download
WSCAD Universe 2002-409
URL
Download
ZUKEN Portal 2002-409
URL
Download
URL
Download
CAE data
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2002-409
Jumper; 9-way; insulated; light gray
Installation Notes
Commoning
WAGO Corporation
02.08.2021 Page 3/5
The push-in type jumper bar system is based
on the common plug and socket principle.
Each terminal block is spring-loaded with a
double socket and a resilient CrNi steel
spring. The jumper contact material is pure
electrolytic copper, which allows for an
extremely small design capable of carrying
the full-rated current of the terminal block.
Ground terminal blocks can also be
commoned using the same jumper system.
Custom jumpers are created by breaking
and removing jumper contacts (2000, 2001,
2002, 2004 Series).
Removing a push-in type jumper bar:
Insert the operating tool between the jumper
and partition wall of the dual jumper slots,
then lift up the jumper.
Place the operating tool in the center of
jumpers for up to five contacts (see above),
or alternately on both sides for jumpers with
more than five contacts.
Commoning
Push-in type jumper bars
Custom push-in type jumper bars are
created by breaking off jumper contacts.
Marking with a felt-tip pen.
500 V
300 V
Commoning
WAGO Corporation
02.08.2021 Page 4/5
Stepping down via push-in type jumper bar.
Stepping down via push-in type jumper bar:
Commoning via closed terminal side with
end plate allows jumpering over two crosssection sizes, e.g., from 16 mm² (6 AWG) to 6
mm² (10 AWG) or from 6 mm² (10 AWG) to
2.5 mm² (14 AWG) (see illustration above).
Commoning via open terminal side with end
plate allows jumpering over two crosssection sizes for 16 mm² (6 AWG) and 10
mm² (8 AWG) and one cross-section size for
6/4/2.5 mm² (10/12/14 AWG). An example:
from 16 mm² (6 AWG) to 6 mm² (10 AWG)
(see illustration above) or from 10 mm² (8
AWG) to 4 mm² (12 AWG).
Note:
The total current of the outgoing circuits
must not exceed the nominal current of the
step-down jumper/push-in type jumper bar.
Product family
TOPJOB® S
TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections.
Show all products from the family
WAGO Corporation
02.08.2021 Page 5/5
很抱歉,暂时无法提供与“2002-409”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+33.8068025+4.20690
- 75+33.2716075+4.14030
- 125+33.09320125+4.11810
- 250+32.73640250+4.07370
- 500+32.20120500+4.00710
