224-201
224-201
    WAGO(万可电子)
    中间连接器,双侧带推压键,适用于不同类型导线
224-201 数据手册
Printview: Service connector - Item No.: 224-201 . Service connector Item No.: 224-201 . Service connector . Marking . Business data Supplier WAGO Item no. 224-201 GTIN / EAN 4044918818407 Content 1 Order amount 50 Customer item number . Notes Technical data Miscellaneous Total number of connection points 2 Total number of potentials 1 Color gray Pollution degree (1) 2 Rated voltage EN (1) [V] 400 [V] Rated surge voltage (1) [kV] 4 [kV] Nominal current [A] 24 [A] Connection technology (1) CAGE CLAMP® Solid sizes 1 0.5 … 2.5 mm² / 20 … 16 AWG Fine-stranded wires 1 0.5 … 2.5 mm² / 20 … 16 AWG WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Service connector - Item No.: 224-201 Technical data Strip length 1 9 … 11 mm / 0.35 … 0.43 in Type of wiring Side-entry wiring Fire load [MJ] 0.099 [MJ] Weight [g] 5 [g] Width 8 mm / 0.315 in Height 15.5 mm / 0.61 in Length 42 mm / 1.654 in Safety information 1 In grounded power lines WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Service connector - Item No.: 224-201 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 3 Printview: Service connector - Item No.: 224-201 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
224-201 价格&库存
很抱歉,暂时无法提供与“224-201”相匹配的价格&库存,您可以联系我们找货
    • 2+5.84864
    库存:3
    224-201
      • 10+7.81975
      • 500+7.65313
      • 1000+7.46881
      库存:1650
