231-336/001-000/RN01-0000 数据手册
Printview: Male connector; with straight solder pins; 6-pole; pin spacing 5.08 mm / 0.2 in; Vertical PCB
mounting; with closed end - Item No.: 231-336/001-000
mm / 0.2 in; Vertical PCB mounting; with closed end
Male connector; with straight solder pins; 6-pole; pin spacing 5.08 mm / 0.2 in; Vertical PCB mounting; with closed
end
Marking
Business data
Supplier
WAGO
Item no.
231-336/001-000
GTIN / EAN
4044918865395
Content
1
Order amount
100
Customer item number
Notes
1.2 x 1.2mm solder pins allow nominal current up to 16A, enhancing stability of shorter headers Enclosed on each
side, the pin housing design prevents mismatingCoding option available
Technical data
Miscellaneous
No. of poles
6
Pin Spacing
5.08 mm / 0.2 in %
Color
orange
Ratings according to 1
IEC/EN 60664-1
Overvoltage category EN 1
III
Pollution degree (1)
2
Rated voltage EN (1) [V]
320 [V]
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Rated surge voltage (1) [kV]
4 [kV]
Nominal current [A]
12 [A]
Overvoltage category EN 2
II
Degree of pollution (2)
2
Rated voltage EN (2) [V]
630 [V]
Rated surge voltage (2) [kV]
4 [kV]
Nominal current (2) [A]
12 [A]
Overvoltage category EN 3
III
Degree of pollution (3)
3
Rated voltage EN (3) [V]
320 [V]
Rated surge voltage (3) [kV]
4 [kV]
Nominal current (3) [A]
12 [A]
Solder pin length [mm]
5 [mm]
Solder pin width A [mm]
1 [mm]
Solder pin width B [mm]
1 [mm]
Tolerance of drilled hole [mm]
1.4(+ 0.1) [mm]
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability rating per UL 94
V0
Limit temperature range
-60 C … 100 C
Contact material
Electrolytic copper (Ecu)
Contact plating
tin-plated
Fire load [MJ]
0.036 [MJ]
Weight [g]
1.978 [g]
Width
33.68 mm / 1.326 in
Height
17 mm / 0.669 in
Height from the surface
12 mm / 0.472 in
Length
8.4 mm / 0.331 in
2
Images & drawings
3
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
4
231-336/001-000/RN01-0000 价格&库存
很抱歉,暂时无法提供与“231-336/001-000/RN01-0000”相匹配的价格&库存,您可以联系我们找货
