231-342/001-000
231-342/001-000
    WAGO(万可电子)
    插件,P=5.08mm
    接线端子 间距:5.08mm 1x12P 直插
231-342/001-000 数据手册
Data sheet  |  Item number: 231-342/001-000 THT male header; 1.0 x 1.0 mm solder pin; straight; Pin spacing 5.08 mm; 12pole; orange www.wago.com/231-342_001-000 Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.05.2020    Page 1/8 Data sheet  |  Item number: 231-342/001-000 www.wago.com/231-342_001-000 L = (pole no. – 1) x pin spacing + 8.2 mm Item description Horizontal or vertical PCB mounting via straight or angled solder pins Pin cross-section: 1 x 1 mm With coding fingers Safety information 1: The MULTI CONNECTION SYSTEM (MCS) is designed without breaking capacity for compliance with DIN EN 61984. When used as intended, MCS Connectors shall not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Data Electrical data Ratings per IEC/EN 60664-1 Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 320 V Rated surge voltage (III/3) 4 kV Rated voltage (III/2) 320 V Rated surge voltage (III/2) 4 kV Nominal voltage (II/2) 630 V Rated surge voltage (II/2) 4 kV Rated current 12 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.05.2020    Page 2/8 Data sheet  |  Item number: 231-342/001-000 www.wago.com/231-342_001-000 Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 10 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Approvals per UL 1059 Approvals per UL 1977 Rated voltage UL 1977 600 V Rated current UL 1977 10 A Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 10 A Rated voltage CSA (Use Group D) 300 V Rated current CSA (Use Group D) 10 A Connection data Pole No. 12 Total number of potentials 12 Number of connection types 1 Number of levels 1 Geometrical Data Pin spacing 5.08 mm / 0.2 inch Width 64.08 mm / 2.523 inch Height 17 mm / 0.669 inch Height from the surface 12 mm / 0.472 inch Depth 8.4 mm / 0.331 inch Solder pin length 5 mm Solder pin dimensions 1 x 1 mm Drilled hole diameter with tolerance 1.4 (+0.1) mm Plug connection Contact type (pluggable connector) Male connector/plug Connector (connection type) for PCB Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.05.2020    Page 3/8 Data sheet  |  Item number: 231-342/001-000 www.wago.com/231-342_001-000 Connector (connection type) for PCB Mismating protection No Mating direction to the PCB 90 ° PCB contact PCB contact THT Solder pin arrangement over the entire male connector (in-line) Number of solder pins per potential 1 Material Data Color orange Material group I Insulation material Polyamide 66 (PA 66) Flammability class per UL94 V0 Contact material Electrolytic copper (ECu) Contact plating tin-plated Fire load 0.069 MJ Weight 3.8 g Environmental Requirements Limit temperature range -60 … +100 °C Commercial data Product Group 3 (Multi Conn. System) Packaging type BOX Country of origin PL GTIN 4044918865623 Customs tariff number 85366990990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CSA DEKRA Certification B.V. C22.2 1466354 KEMA/KEUR EN 61984 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com 2190761.01 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.05.2020    Page 4/8 Data sheet  |  Item number: 231-342/001-000 www.wago.com/231-342_001-000 KEMA/KEUR DEKRA Certification B.V. EN 61984 2190761.01 Ship Approvals Logo Approval Additional Approval Text ABS American Bureau of Shipping - Certificate name 19HG1869876PDA UL-Approvals Logo Approval Additional Approval Text Certificate name UL UL International Germany GmbH UL 1977 E45171 UR Underwriters Laboratories Inc. UL 1059 E45172 Counterpart Item no.231-312/026-000 1-conductor female plug; 2.5 mm²; Pin spacing 5.08 mm; 12-pole; 2,50 mm²; orange www.wago.com/231-312 /026-000 Item no.231-2312/026-000 2-conductor female connector; 2.5 mm²; Pin spacing 5.08 mm; 12-pole; 2,50 mm²; orange www.wago.com/231-2312 /026-000 Item no.231-2312/037-000 2-conductor female connector; Locking lever; 2.5 mm²; Pin spacing 5.08 mm; 12-pole; 2,50 mm²; orange www.wago.com/231-2312 /037-000 Item no.2231-312/026-000 1-conductor female plug; push-button; 2.5 mm²; Pin spacing 5.08 mm; 12-pole; 2,50 mm²; orange www.wago.com/2231-312 /026-000 Item no.2231-312/031-000 1-conductor female plug; push-button; clamping collar; 2.5 mm²; Pin spacing 5.08 mm; 12-pole; 2,50 mm²; orange www.wago.com/2231-312 /031-000 Item no.2231-312/102-000 1-conductor female plug; push-button; with integrated end plate; 2.5 mm²; Pin spacing 5.08 mm; 12pole; 2,50 mm²; orange www.wago.com/2231-312 /102-000 Item no.2231-312/037-000 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.05.2020    Page 5/8 Data sheet  |  Item number: 231-342/001-000 www.wago.com/231-342_001-000 Item no.2231-312/037-000 1-conductor female plug; push-button; Locking lever; 2.5 mm²; Pin spacing 5.08 mm; 12-pole; 2,50 mm²; orange www.wago.com/2231-312 /037-000 Item no.231-312/027-000 1-conductor female plug; clamping collar; 2.5 mm²; Pin spacing 5.08 mm; 12-pole; 2,50 mm²; orange www.wago.com/231-312 /027-000 Item no.231-312/031-000 1-conductor female plug; clamping collar; 2.5 mm²; Pin spacing 5.08 mm; 12-pole; 2,50 mm²; orange www.wago.com/231-312 /031-000 Item no.231-312/037-000 1-conductor female plug; Locking lever; 2.5 mm²; Pin spacing 5.08 mm; 12-pole; 2,50 mm²; orange www.wago.com/231-312 /037-000 Item no.231-312/102-000 1-conductor female plug; with integrated end plate; 2.5 mm²; Pin spacing 5.08 mm; 12-pole; 2,50 mm²; orange www.wago.com/231-312 /102-000 Item no.232-312/026-000 1-conductor female plug; angled; 2.5 mm²; Pin spacing 5.08 mm; 12-pole; 2,50 mm²; orange www.wago.com/232-312 /026-000 Item no.232-412/026-000 1-conductor female plug; angled; 2.5 mm²; Pin spacing 5.08 mm; 12-pole; 2,50 mm²; orange www.wago.com/232-412 /026-000 Compatible products Marking accessories Item no.: 210-833 Marking strips; on reel; 6 mm wide; plain; Self-adhesive; white www.wago.com/210-833 Item no.: 210-834 Marking strips; on reel; 5 mm wide; plain; Self-adhesive; white www.wago.com/210-834 Item no.: 231-129 Coding key; snap-on type; light gray www.wago.com/231-129 Item no.: 231-500 Spacer; for formation of groups; light gray www.wago.com/231-500 Coding Downloads Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.05.2020    Page 6/8 Data sheet  |  Item number: 231-342/001-000 www.wago.com/231-342_001-000 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 3.6 MB Download URL Download URL Download URL Download CAD/CAE-Data CAD data 2D/3D Models 231-342/001-000 CAE data EPLAN Data Portal 231-342/001-000 PCB Design Symbol and Footprint 231-342/001-000 CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! View Logic ViewDraw Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.05.2020    Page 7/8 Data sheet  |  Item number: 231-342/001-000 www.wago.com/231-342_001-000 View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian Handling Instructions Coding Coding a male header – fitting coding key(s). Product family MCS MIDI Classic Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.05.2020    Page 8/8
