Data sheet from 04.02.2009
Item no.:
232-166
Product description:
FEMALE PLUG; WITH STRAIGHT SOLDER PIN; 6 POLE; PIN
SPACING 5.08 MM / 0.2 IN; SOLDER PIN 0.6x1 MM; WITH
CODIG FINGERS
Packing unit 50 pieces
Product group
3 (Multi Conn. System)
Pin spacing from
5,08 mm
Pin spacing from
0,2 in
pole count
6
Measured voltage EN
250 V
Measured shock voltage
4 kV
Pollution degree
3
Current intensity EN
12 A
Weight
5,45 g
Color
orange
No. of connection Points
6
No. of potentials
6
Height
18,25 mm
Height
0,719 in
Width
31,98 mm
Width
1,259 in
Depth
11,6 mm
Depth
0,457 in
1 von 2
Item number
Admission office
Approval no.
Voltage [V]
Current [A]
Cross section [ mm² ]
232-166
ABS
04-HG469925-PDA
250
12
0,8-2,5
232-166
BV
11915/A0
400
16
2,5
232-166
CCA
5764
250
12
0,6x1
232-166
CSA
154112-1466354
300
15
0,6x1
232-166
DEMKO
88126
250
232-166
GL
17296-00HH
250
12
0,8-2,5
232-166
KEMA
2083746.02
250
12
0,6x1
232-166
KR
HMB05880-EL003
250/400
12/16
2,5
232-166
LR
96/20035
250
12
0,8-2,5
232-166
NEMKO
P94101840
250
232-166
RMR
11130002
250
12
232-166
UR
E45172
300
15
Sorting criteria: admission office - approval number
© WAGO Kontakttechnik GmbH & Co. KG
Specifications are subject to changes and errors may be expected
2 von 2
2,5
2,5
0,8-2,5
很抱歉,暂时无法提供与“232-166”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+79.7234510+10.36211
- 50+57.8945650+7.52488
- 100+55.76523100+7.24812
- 250+54.16401250+7.04000
- 500+51.81888500+6.73519
