236-403
236-403
    WAGO(万可电子)
    插件,P=5.08mm
    接线端子 间距:5.08mm 每排针脚数:3 排数:双排
236-403 数据手册
Printview: PCB terminal strip; 2 solder pins/pole; 3-pole; pin spacing 5/5.08 mm / 0.2 in - Item No.: 236-403 . PCB terminal strip; 2 solder pins/pole; 3-pole; pin spacing 5/5.08 mm / 0.2 in Item No.: 236-403 . PCB terminal strip; 2 solder pins/pole; 3-pole; pin spacing 5/5.08 mm / 0.2 in . Marking . Business data Supplier WAGO Item no. 236-403 GTIN / EAN 4044918768993 Content 1 Order amount 70 Customer item number . Notes Terminal strips with CAGE CLAMP® connection, screwdriver actuation parallel or perpendicular to conductor entryAlso available with Ex e approvalFor custom terminal strip assembliesOperating tools for factory wiring45° connection angle permits a wide range of uses and wiring optionsSet to metric or inch pin spacing by compressing terminal strips together or pulling them apart Technical data Miscellaneous No. of poles 3 Pin Spacing 5/5.08 mm / 0.2 in Total number of connection points 3 Total number of potentials 3 Color gray Ratings according to 1 IEC/EN 60664-1 Overvoltage category EN 1 III WAGO Kontakttechnik GmbH & Co. KG 1 Printview: PCB terminal strip; 2 solder pins/pole; 3-pole; pin spacing 5/5.08 mm / 0.2 in - Item No.: 236-403 Technical data Pollution degree (1) 2 Rated voltage EN (1) [V] 320 [V] Rated surge voltage (1) [kV] 4 [kV] Nominal current [A] 24 [A] Overvoltage category EN 2 II Degree of pollution (2) 2 Rated voltage EN (2) [V] 630 [V] Rated surge voltage (2) [kV] 4 [kV] Nominal current (2) [A] 24 [A] Overvoltage category EN 3 III Degree of pollution (3) 3 Rated voltage EN (3) [V] 250 [V] Rated surge voltage (3) [kV] 4 [kV] Nominal current (3) [A] 24 [A] Number of individual connection objects at the product 1 Connection technology (1) CAGE CLAMP® Solid sizes 1 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded wires 1 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded wires with insulated ferrule 1 0.25 … 1.5 mm² / … Fine-stranded wires with uninsulated ferrule 1 0.25 … 1.5 mm² / … Strip length 1 5 … 6 mm / 0.2 … 0.24 in Conductor entry angle to the PCB 1 [°] 45 [°] Type of wiring Front-/Side-entry wiring Solder pin arrangement in-line solder pin Solder pin length [mm] 4 [mm] Solder pin width A [mm] 0.7 [mm] Solder pin width B [mm] 0.7 [mm] Tolerance of drilled hole [mm] 1.1(+ 0.1) [mm] Material group I Insulating material Polyamide 66 (PA 66) Flammability rating per UL 94 V0 Limit temperature range -60 C … 105 C Clamping spring material Chrome-nickel spring steel (CrNi) Contact material Electrolytic copper (Ecu) Contact plating tin-plated WAGO Kontakttechnik GmbH & Co. KG 2 Printview: PCB terminal strip; 2 solder pins/pole; 3-pole; pin spacing 5/5.08 mm / 0.2 in - Item No.: 236-403 Technical data Fire load [MJ] 0.04 [MJ] Weight [g] 2.779 [g] Width 17.3 mm / 0.681 in Height 17 mm / 0.669 in Height from the surface 13 mm / 0.512 in Length 14 mm / 0.551 in WAGO Kontakttechnik GmbH & Co. KG 3 Printview: PCB terminal strip; 2 solder pins/pole; 3-pole; pin spacing 5/5.08 mm / 0.2 in - Item No.: 236-403 Images & drawings . WAGO Kontakttechnik GmbH & Co. KG 4 Printview: PCB terminal strip; 2 solder pins/pole; 3-pole; pin spacing 5/5.08 mm / 0.2 in - Item No.: 236-403 Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 5
236-403 价格&库存
很抱歉,暂时无法提供与“236-403”相匹配的价格&库存,您可以联系我们找货
  • 1+21.909401+2.83804
  • 10+17.2075110+2.22898
  • 25+15.0906525+1.95477
  • 50+13.0953350+1.69631
  • 100+12.96534100+1.67947
  • 250+9.67508250+1.25326
  • 500+9.57868500+1.24078
  • 1000+9.349231000+1.21106
  • 5000+8.994705000+1.16513
库存:3625
236-403
  • 10+5.7281010+0.74210
  • 500+5.55580500+0.71980
  • 2000+5.389402000+0.69820
库存:40
