236-404
236-404
    WAGO(万可电子)
    插件,P=5.08mm
    接线端子 间距:5.08mm 每排针脚数:4 排数:单排
236-404 数据手册
Data sheet  |  Item number: 236-404 PCB terminal block; 2.5 mm²; Pin spacing 5/5.08 mm; 4-pole; CAGE CLAMP®; commoning option www.wago.com/236-404 Color: L = (pole no. x pin spacing) + 2.3 mm Item description 29.03.2019    Page 1/8 Data sheet  |  Item number: 236-404 www.wago.com/236-404 PCB terminal strips with CAGE CLAMP® connection and screwdriver actuation parallel or perpendicular to conductor entry Versions with Ex approval Mixed-color PCB terminal strips from factory Operating tools for factory wiring 45° conductor entry angle permits a wide range of applications and wiring options Set to metric or inch pin spacing by compressing PCB terminal strips or pulling them apart Data Electrical data Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 250 V Rated impulse voltage (III / 3) 4 kV Rated voltage (III / 2) 320 V Rated impulse voltage (III / 2) 4 kV Rated voltage (II / 2) 630 V Rated impulse voltage (II / 2) 4 kV Rated current 24 A Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 15 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 15 A Rated voltage CSA (Use Group D) 300 V Rated current CSA (Use Group D) 10 A Connection data Connection technology CAGE CLAMP® Actuation type Operating tool Solid conductor 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded conductor 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded conductor with ferrule with plastic collar 0.25 … 1.5 mm² Fine-stranded conductor with ferrule without plastic collar 0.25 … 1.5 mm² Strip length 5 … 6 mm / 0.2 … 0.24 inch 29.03.2019    Page 2/8 Data sheet  |  Item number: 236-404 www.wago.com/236-404 Strip length 5 … 6 mm / 0.2 … 0.24 inch Conductor entry angle to the PCB 45 ° Note (conductor cross-section) 12 AWG: THHN, THWN No. of poles 4 Total number of connection points 4 Total number of potentials 4 Number of connection types 1 Number of levels 1 Leiterquerschnitte eindrähtig 0.08 mm² Geometrical Data Pin spacing 5/5.08 mm / 0.197/0.2 inch Width 22.3 mm / 0.878 inch Height 17 mm / 0.669 inch Height from the surface 13 mm / 0.512 inch Depth 14 mm / 0.551 inch Plug width 22.3 mm / 0.878 inch Solder pin length 4 mm Solder pin dimensions 0.7 x 0.7 mm Drilled hole diameter (tolerance) 1.1(- … +0.1) mm PCB contact PCB contact THT Solder pin arrangement over the entire terminal strip, in line Number of solder pins per potential 2 Material Data Color gray Material group I Insulating material Polyamide 66 (PA 66) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Electrolytic copper (Ecu) Contact plating tin-plated Fire load 0.052 MJ Weight 3.656 g Environmental Requirements Limit temperature range -60 … +105 °C Commercial data 29.03.2019    Page 3/8 Data sheet  |  Item number: 236-404 www.wago.com/236-404 Commercial data Product Group 4 (Printed Circuit) Country of origin CH GTIN 4044918894593 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 NTR NL7109 CCA DEKRA Certification B.V. EN 60998 NTR NL7195 CCA DEKRA Certification B.V. EN 60947 2168090.01 CSA DEKRA Certification B.V. C22.2 No. 158 1673957 UL-Approvals Logo Approval Additional Approval Text UR Underwriters Laboratories Inc. UL 1059 Certificate name E45172, sec. 6 Compatible products check Item no.: 231-127 Testing plug module with contact stud; for 236 Series; Pin spacing 5 mm / 0.197 in www.wago.com/231-127 Item no.: 231-128 Testing plug module with contact stud; Pin spacing 5.08 mm / 0.2 in www.wago.com/231-128 ferrule 29.03.2019    Page 4/8 Data sheet  |  Item number: 236-404 www.wago.com/236-404 ferrule Item no.: 216-101 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated www.wago.com/216-101 Item no.: 216-102 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated www.wago.com/216-102 Item no.: 216-103 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated www.wago.com/216-103 Item no.: 216-104 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated www.wago.com/216-104 Item no.: 216-121 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated www.wago.com/216-121 Item no.: 216-122 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated www.wago.com/216-122 Item no.: 216-123 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated www.wago.com/216-123 Item no.: 216-124 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated www.wago.com/216-124 Item no.: 216-131 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-131 Item no.: 216-132 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-132 Item no.: 216-141 Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-141 Item no.: 216-142 Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-142 Item no.: 216-143 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-143 Item no.: 216-144 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-144 Item no.: 216-151 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-151 Item no.: 216-152 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-152 Item no.: 216-201 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated www.wago.com/216-201 Item no.: 216-202 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated www.wago.com/216-202 Item no.: 216-203 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated www.wago.com/216-203 Item no.: 216-204 29.03.2019    Page 5/8 Data sheet  |  Item number: 236-404 www.wago.com/236-404 Item no.: 216-204 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated www.wago.com/216-204 Item no.: 216-221 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated www.wago.com/216-221 Item no.: 216-222 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated www.wago.com/216-222 Item no.: 216-223 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated www.wago.com/216-223 Item no.: 216-224 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated www.wago.com/216-224 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90 www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90 www.wago.com/216-242 Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243 acc. to DIN 46228, Part 4/09.90 Item no.: 216-244 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90 www.wago.com/216-244 Item no.: 216-262 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90 www.wago.com/216-262 Item no.: 216-263 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263 acc. to DIN 46228, Part 4/09.90 Item no.: 216-264 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90 www.wago.com/216-264 Item no.: 216-284 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90 www.wago.com/216-284 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated www.wago.com/216-301 Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated www.wago.com/216-302 Item no.: 216-321 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated www.wago.com/216-321 Item no.: 216-322 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated www.wago.com/216-322 Item no.: 210-657 Operating tool with partially insulated shaft; Blade (3.5 x 0.5) mm; short www.wago.com/210-657 Item no.: 210-658 www.wago.com/210-658 tools 29.03.2019    Page 6/8 Data sheet  |  Item number: 236-404 www.wago.com/236-404 Item no.: 210-658 Operating tool with partially insulated shaft; Blade (3.5 x 0.5) mm; short; angled www.wago.com/210-658 Item no.: 210-720 Operating tool with partially insulated shaft; Type 2, blade (3.5 x 0.5) mm www.wago.com/210-720 Item no.: 236-332 Operating tool; plastic www.wago.com/236-332 Item no.: 236-335 Operating tool; metal www.wago.com/236-335 Marking accessories Item no.: 210-332/500-202 www.wago.com/210-332 Marking strips; as a DIN A4 sheet; MARKED; 1-16 (160x); Height of marker strip: 3 mm; Strip length 182 /500-202 mm; Horizontal marking; Self-adhesive Item no.: 210-332/500-204 Marking strips; as a DIN A4 sheet; MARKED; 17-32 (160x); Height of marker strip: 3 mm; Strip length 182 mm; Horizontal marking; Self-adhesive www.wago.com/210-332 /500-204 Item no.: 210-332/500-205 Marking strips; as a DIN A4 sheet; MARKED; 1-32 (80x); Height of marker strip: 3 mm; Strip length 182 mm; Horizontal marking; Self-adhesive www.wago.com/210-332 /500-205 Item no.: 210-332/500-206 Marking strips; as a DIN A4 sheet; MARKED; 33-48 (160x); Height of marker strip: 3 mm; Strip length 182 mm; Horizontal marking; Self-adhesive www.wago.com/210-332 /500-206 Item no.: 210-332/508-202 www.wago.com/210-332 Marking strips; as a DIN A4 sheet; MARKED; 1-16 (160x); Height of marker strip: 3 mm; Strip length 182 /508-202 mm; Horizontal marking; Self-adhesive Item no.: 210-332/508-204 Marking strips; as a DIN A4 sheet; MARKED; 17-32 (160x); Height of marker strip: 3 mm; Strip length 182 mm; Horizontal marking; Self-adhesive www.wago.com/210-332 /508-204 Item no.: 210-332/508-205 Marking strips; as a DIN A4 sheet; MARKED; 1-32 (80x); Height of marker strip: 3 mm; Strip length 182 mm; Horizontal marking; Self-adhesive www.wago.com/210-332 /508-205 Item no.: 210-332/508-206 Marking strips; as a DIN A4 sheet; MARKED; 33-48 (160x); Height of marker strip: 3 mm; Strip length 182 mm; Horizontal marking; Self-adhesive www.wago.com/210-332 /508-206 Downloads CAD files CAD data 3D Download 236-404 URL Download zip 27.1 MB Download PCB libraries TARGET Library for WAGO PCB Terminal Blocks Compatible with TARGET PCB Design Software Version 17.x 1.1.0 Oct 6, 2014 29.03.2019    Page 7/8 Data sheet  |  Item number: 236-404 www.wago.com/236-404 Compatible with TARGET PCB Design Software Version 17.x DesignSpark Library for WAGO PCB Terminal Blocks Compatible with DesignSpark PCB Version 4.x or higher EAGLE Library for WAGO PCB Terminal Blocks Compatible with EAGLE PCB Design Software Version 6.x or higher 2.1 Oct 6, 2014 zip 22.5 MB Download 2.1 Sep 21, 2017 zip 23.9 MB Download   Subject to changes. WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at {0}. 29.03.2019    Page 8/8
236-404 价格&库存
很抱歉,暂时无法提供与“236-404”相匹配的价格&库存,您可以联系我们找货
    • 1+672.21319
    库存:385
