Printview: Terminal strips with operating levers; 2 solder pins/pole; 5-pole; pin spacing 7.5 mm / 0.295 in;
without jumper slot - Item No.: 2706-105
pin spacing 7.5 mm / 0.295 in; without jumper slot
Item No.: 2706-105
Terminal strips with operating levers; 2 solder pins/pole; 5-pole; pin spacing 7.5 mm / 0.295 in; without jumper slot
Marking
Business data
Supplier
WAGO
Item no.
2706-105
GTIN / EAN
4050821093015
Content
1
Order amount
30
Customer item number
Notes
High-current terminal strips with lever-actuated CAGE CLAMP®Tool-free opening and closing – fingers open/close
leversSeveral clamping units can be held open simultaneously – convenient for terminating multi-core cablesTwo
solder pins per contact point for high mechanical stability600V UL for 12.5mm pin spacing
Technical data
Miscellaneous
No. of poles
5
Pin Spacing
7.5 mm (0.295 in %)
Total number of connection points
5
Total number of potentials
5
Color
gray
Ratings according to 1
IEC/EN 60664-1
Overvoltage category EN 1
III
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Pollution degree (1)
2
Rated voltage EN (1) [V]
630 [V]
Rated surge voltage (1) [kV]
6 [kV]
Nominal current [A]
41 [A]
Overvoltage category EN 2
II
Degree of pollution (2)
2
Rated voltage EN (2) [V]
1000 [V]
Rated surge voltage (2) [kV]
6 [kV]
Nominal current (2) [A]
41 [A]
Overvoltage category EN 3
III
Degree of pollution (3)
3
Rated voltage EN (3) [V]
500 [V]
Rated surge voltage (3) [kV]
6 [kV]
Nominal current (3) [A]
41 [A]
Number of individual connection objects at the product
1
Connection technology (1)
CAGE CLAMP®
Solid sizes 1
0.5 … 6 mm² / 20 … 10 AWG
Fine-stranded wires 1
Fine-stranded wires with insulated ferrule 1
0.5 … 6 mm² / …
Fine-stranded wires with uninsulated ferrule 1
0.5 … 6 mm² / …
Strip length 1
11 … 12 mm / 0.43 … 0.47 in
Conductor entry angle to the PCB 1 [°]
30 [°]
Solder pin arrangement
in-line solder pin
Solder pin length [mm]
4.5 [mm]
Solder pin width A [mm]
1 [mm]
Solder pin width B [mm]
1.4 [mm]
Tolerance of drilled hole [mm]
1.8(+ 0.1) [mm]
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability rating per UL 94
V0
Limit temperature range
-60 C … 105 C
Clamping spring material
Chrome-nickel spring steel (CrNi)
Contact material
Electrolytic copper (Ecu)
Contact plating
tin-plated
2
Technical data
Fire load [MJ]
0.475 [MJ]
Weight [g]
25.717 [g]
Width
37.5 mm / 1.476 in
Height
30 mm / 1.181 in
Height from the surface
25.5 mm / 1.004 in
Length
26 mm / 1.024 in
3
Images & drawings
4
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
5
很抱歉,暂时无法提供与“2706-105”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+128.820081+16.74620
