2-CONDUCTOR FUSE TERMINAL
BLOCK FORMINI-AUTOMOTIVE
BLADE-TYPE FUSES CENTRE
MARKING WITH TESTING FACILITY
PDF Datasheet
© 1992 - 2011 CADENAS GmbH
282-696
PDF Datasheet
ITEM-NO. (ITEM-NO.)
282-696
Cross section1 (Cross section / mm²)
0.2 - 6
Cross section2 (Cross section / AWG)
24 - 10
Strip length (Strip length / mm)
12 - 13
Measured voltage (Measured voltage / V)
400
Measured shock voltage (Measured shock voltage / kV)
6
Pollution degree (Pollution degree)
3
Current intensity (Current intensity / A)
25
Height (Height / mm)
33.5
Width (Width / mm)
8
Depth (Depth / mm)
85
No. of connection Points (No. of connection Points)
2
No. of potentials (No. of potentials)
2
COLOR (COLOR)
grau
WEIGHT (WEIGHT / g)
17.22
很抱歉,暂时无法提供与“282-696”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+177.513331+23.07138
- 10+126.7847210+16.47819
- 25+113.1023925+14.69990
- 50+104.9462550+13.63985
- 100+98.41033100+12.79038
- 250+91.82034250+11.93388
- 500+88.07593500+11.44722
- 1000+85.167471000+11.06921
