Data sheet from 17.02.2012
Item no.:
282-698/281-429
Product description:
2-conductor fuse terminal block formini-automotive blade-type
fuses with testing facility 12 V with blown fuse indication by led
Produkt kann von Bild abweichen / product may differ
Packing unit 25 pieces
RoHS compliant
Product group
1 (Rail Mounted Terminal Blocks)
Power consumption LED
4.8 mA
Cross section [mm²]
0.2 - 6 mm²
Cross section [AWG]
24 - 10 AWG
Connection method
CAGE CLAMP®CONNECTION
Measured voltage EN
400 V
Measured shock voltage
6 kV
Pollution degree
3
Current intensity EN
25 A
30 A
Weight
17.95 g
Color
grey
Wiring type
Angled Type
No. of connection Points
2
No. of potentials
2
Height
33.5 mm
Height
1.32 in
Width
8 mm
Width
1 von 4
0.315 in
Depth
85 mm
Depth
3.35 in
Strip length from
12 mm
2 von 4
Strip length to
13 mm
Strip length
0.49 in
Safety information 1
The nominal voltage and nominal current are
defined by the indicator lamp or the fuse.
Mounting
TS 35
Safety information 2
Blade-type fuses, please note touchproof protection
from 42 V
3 von 4
Item number
Admission office
Approval no.
Voltage [V]
Current [A]
Cross section [ mm² ]
282-698/281-429
CSA
154112-1505033
24
12
24-10
282-698/281-429
UR
E45172
12
30
24-10
Sorting criteria: admission office - approval number
© WAGO Kontakttechnik GmbH & Co. KG
Specifications are subject to changes and errors may be expected
4 von 4
很抱歉,暂时无法提供与“282-698/281-429”相匹配的价格&库存,您可以联系我们找货
