Printview: Interface module; with D-subminiature male connector; 50-pole; for mating connectors with
solder connection; Vertical mounting - Item No.: 289-549
for mating connectors with solder connection; Vertical mounting
Item No.: 289-549
Interface module; with D-subminiature male connector; 50-pole; for mating connectors with solder connection;
Vertical mounting
Marking
Business data
Supplier
WAGO
Item no.
289-549
GTIN / EAN
4045454322779
Content
1
Order amount
1
Customer item number
Notes
Technical data
Miscellaneous
No. of poles
50
Pollution degree (1)
2
Rated voltage EN (1) [V]
125 [V]
Rated surge voltage (1) [kV]
0.8 [kV]
Wire connection 1
WAGO 236 Series
Operating voltage
125 V AC / DC
Nominal current [A]
2 [A]
Ambient operating temperature
-20 °C ... +50 °C
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Connector contact
Au over Ni
Contact resistance [m]
30 [m]
Performance level
2 / 200 mating cycles
Connection technology (1)
CAGE CLAMP®
Solid sizes 1
0.08 … 2.5 mm² / 28 … 12 AWG
Strip length 1
5 … 6 mm / 0.2 … 0.24 in
Weight [g]
122.954 [g]
Width
94 mm / 3.701 in
Height from upper-edge of DIN-rail [mm]
34 [mm]
34 mm / 1.339 in
Length
85 mm / 3.346 in
Storage temperature
-40 °C ... +70 °C
Type of mounting
DIN 35 rail
2
Images & drawings
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
3
很抱歉,暂时无法提供与“289-549”相匹配的价格&库存,您可以联系我们找货
