4
282
Female Connectors, Double-Row
Pin Spacing: 3.5 mm
MCS MINI HD
Universal connection for all conductor types
nique, compact, double-row connector system for conductor cross
U
sections up to 1.5 mm2
High-density, “wire-to-board” connectors for use in very confined spaces
entered strain relief plate anchors conductors, while acting as
C
convenient connection and disconnection handle. It also provides easy
access to operating slots — even when wired.
ptional dual-purpose lever doubles as a lock and disconnection aid,
O
while preventing accidental disconnection in closed position
100% protected against mismating, available with coding fingers
Technical data:
Pin Spacing
Ratings per
Overvoltage category
Pollution degree
Rated voltage
Rated surge voltage
Nominal current
Approvals per
Use group UL 1059
Rated voltage
Nominal current UL
Nominal current CSA
3.5 mm
0.138 in.
IEC/EN 60664-1
III
III
II
3
2
2
80 V 160 V 250 V
2.5 kV 2.5 kV 2.5 kV
10 A
10 A
10 A
UL/CSA
B
C
D
150 V
10 A
10 A
Derating Curve
713-1103 female connector with 713-1403 male header
Pin spacing: 3.5 mm / Conductor size: 1.5 mm2”f-st”
Based on: EN 60512-5-2 / Reduction factor: 0.8
Current in A
10
5
Conductor data:
Connection technology
Conductor size: solid
Conductor size: fine-stranded
AWG
Strip length
CAGE CLAMP®
0.08–1.5 mm2
0.08–1.5 mm2
0.25–1.0 mm2
(with insulated ferrule)
0.25–1.0 mm2
(with uninsulated ferrule)
28–16
6–7 mm / 0.24–0.28 in.
Material data:
50
60
70
80
90 100 105
Ambient operating temperature in °C
6-, 16-, 24-, 36-pole
MCS MINI HD accessories:
Material group
II
Insulating material
Glass fiber-reinforced polyamide 6.6 (PA 6.6-GF)
Flammability rating per UL 94
0V
Lower/Upper limit temperature
-60 °C / +100 °C
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Copper alloy
Contact plating
tin-plated
MCS connectors are also available upon request with gold-plated or partially gold-plated contact surfaces.
Depending on the version requested, “item no. suffix . . . /010-000” is added to the “basic item no.”
Marking accessories
Operating tools
Direct marking
Strain relief plates
MCS — MULTI CONNECTION SYSTEM includes connectors without breaking capacity in accordance with
DIN EN 61984.
When used as intended, these connectors shall not be connected/disconnected when live or under load. The circuit
design should ensure header pins, which can be touched, are not live when unmated.
Additional approvals and corresponding ratings can be found at www.wago.com.
30
For additional technical information, see Section 13.
Conductor rated current
Pages:
570 – 573
296
297
296
"4
MCS MINI HD
283
With levers
Pin spacing: 3.5 mm / 0.138 in.
0.08–1.5 mm2
160 V/2.5 kV/2 10 A
28–16 AWG
150 V/10 A
0.08–1.5 mm2
160 V/2.5 kV/2 10 A
With screw flanges
28–16 AWG
150 V/10 A
0.08–1.5 mm2
160 V/2.5 kV/2 10 A
28–16 AWG
150 V/10 A
4
L = [(pole no./2) – 1] x pin spacing + 5.2 mm
Coding finger
Pole No.
Item No.
Pack. Unit
Female connector, double-row,
black
6 (3x2)
8 (4x2)
10 (5x2)
12 (6x2)
14 (7x2)
16 (8x2)
18 (9x2)
20 (10x2)
22 (11x2)
24 (12x2)
26 (13x2)
28 (14x2)
30 (15x2)
32 (16x2)
34 (17x2)
36 (18x2)
713-1103
713-1104
713-1105
713-1106
713-1107
713-1108
713-1109
713-1110
713-1111
713-1112
713-1113
713-1114
713-1115
713-1116
713-1117
713-1118
L = [(pole no./2) – 1] x pin spacing + 12.2 mm
L = [(pole no./2) – 1] x pin spacing + 13.6 mm
Pole No.
Pole No.
Item No.
Pack. Unit
Female connector with levers, double-row,
black
100
50
50
50
50
25
25
25
25
25
25
6 (3x2)
8 (4x2)
10 (5x2)
12 (6x2)
14 (7x2)
16 (8x2)
18 (9x2)
20 (10x2)
22 (11x2)
24 (12x2)
26 (13x2)
28 (14x2)
30 (15x2)
32 (16x2)
34 (17x2)
36 (18x2)
713-1103/037-000
713-1104/037-000
713-1105/037-000
713-1106/037-000
713-1107/037-000
713-1108/037-000
713-1109/037-000
713-1110/037-000
713-1111/037-000
713-1112/037-000
713-1113/037-000
713-1114/037-000
713-1115/037-000
713-1116/037-000
713-1117/037-000
713-1118/037-000
Item No.
Pack. Unit
Female connector with screw flanges, double-row,
black
50
50
50
25
25
25
25
10
6 (3x2)
8 (4x2)
10 (5x2)
12 (6x2)
14 (7x2)
16 (8x2)
18 (9x2)
20 (10x2)
22 (11x2)
24 (12x2)
26 (13x2)
28 (14x2)
30 (15x2)
32 (16x2)
34 (17x2)
36 (18x2)
713-1103/107-000
713-1104/107-000
713-1105/107-000
713-1106/107-000
713-1107/107-000
713-1108/107-000
713-1109/107-000
713-1110/107-000
713-1111/107-000
713-1112/107-000
713-1113/107-000
713-1114/107-000
713-1115/107-000
713-1116/107-000
713-1117/107-000
713-1118/107-000
50
50
25
25
25
25
25
10
10
4
284
Male Headers with Solder Pins, Double-Row
Pin Spacing: 3.5 mm
MCS MINI HD
ale headers may be mounted horizontally or vertically via straight or
M
angled solder pins
eader housing is molded of THR-compatible insulation material for
H
lead-free reflow soldering
eparated pin slots prevent damage and make the headers touch-proof
S
when unplugged
Coding pins available
Technical data:
Pin Spacing
Ratings per
Pollution degree
Rated voltage
Rated surge voltage
Nominal current
Approvals per
Use group UL 1059
Rated voltage
Nominal current UL
Nominal current CSA
3.5 mm
0.138 in.
IEC/EN 60664-1
III
III
II
3
2
2
80 V 160 V 250 V
10 A
10 A
10 A
UL/CSA
B
C
D
150 V
10 A
12 A
Derating Curve
Current in A
10
5
Solder pin data:
Solder pin: length/width
Solder pin: drilled hole diameter
3.8 mm / 0.8 x 0.8 mm
1.2+0.1 mm
10
40
50
60
70
80
90 100 105
For other pin lengths, please contact factory.
Material data:
MCS MINI HD accessory:
Material group
I
Insulating material
Glass-fiber-reinforced polyphthalamide (PPA-GF)
0V
-60 °C / +100 °C
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Coding pin carrier
DIN EN 61984.
Page:
297
MCS MINI HD
4
285
With straight solder pins
160 V/2.5 kV/2 10 A
With angled solder pins
150 V/10 A
160 V/2.5 kV/2 10 A
150 V/10 A
4
2,6
2,6
2,6
2,6
Pole No.
Item No.
Pack. Unit
Male header with straight solder pins, double-row,
black
6 (3x2)
8 (4x2)
10 (5x2)
12 (6x2)
14 (7x2)
16 (8x2)
18 (9x2)
20 (10x2)
22 (11x2)
24 (12x2)
26 (13x2)
28 (14x2)
30 (15x2)
32 (16x2)
34 (17x2)
36 (18x2)
713-1403
713-1404
713-1405
713-1406
713-1407
713-1408
713-1409
713-1410
713-1411
713-1412
713-1413
713-1414
713-1415
713-1416
713-1417
713-1418
100
50
50
50
50
25
25
25
25
25
25
Pole No.
Item No.
Pack. Unit
Male header with angled solder pins, double-row,
black
6 (3x2)
8 (4x2)
10 (5x2)
12 (6x2)
14 (7x2)
16 (8x2)
18 (9x2)
20 (10x2)
22 (11x2)
24 (12x2)
26 (13x2)
28 (14x2)
30 (15x2)
32 (16x2)
34 (17x2)
36 (18x2)
713-1423
713-1424
713-1425
713-1426
713-1427
713-1428
713-1429
713-1430
713-1431
713-1432
713-1433
713-1434
713-1435
713-1436
713-1437
713-1438
100
50
50
50
50
25
25
25
25
25
25
for in-the-field assembly
Strain relief plates,
factory-assembled
Operating tool
for female connectors with CAGE CLAMP®
with partially insulated shaft
Type 1
Width
Item No.
Pack. Unit
Strain relief plate,
black
11 mm
25 mm
39 mm
53 mm
Width
Pole No.
Item No. Suffix:
Strain relief plate, pre-assembled
713-126
713-127
713-128
713-129
100 (4 x 25)
100 (4 x 25)
100 (4 x 25)
100 (4 x 25)
11 mm
25 mm
39 mm
53 mm
Ordering example:
Female connector, 3.5 mm pin spacing, 20-pole, black
with strain relief plate: 713-1110/033-000
> D <
> 3,5<
The arrangement of the attachments for cable ties allows
single conductors or multi-core cables to be secured in
different ways.
The width of the cable tie must correspond to the hole
dimensions in the drawing for the strain relief plates.
WAGO does not offer the recommended cable ties and
cable binding tools; those are available from suppliers
such as Hellermann.
Strain Relief Housing Dimensions
Pole No.
B
H
D
6–12
14–20
22–28
30–36
11
25
39
53
38.7
43.7
48.7
54.2
3
4.2
4.2
4.9
An “item no. suffix”, referring to the width of the strain relief plate, is added to the “basic item no.” and determines
the type of female connector.
>3<
Item No.
210-719
. . . /032-000
. . . /033-000
. . . /034-000
. . . /035-000
6–12
14–20
22–28
30–36
Color
Pack. Unit
Operating tool with partially insulated shaft,
type 1, (2.5 x 0.4) mm blade
296
Accessories
Strain Relief Plates and Operating Tool
MCS MINI HD
4
1
Accessories
Coding Pin Carrier and Direct Marking
MCS MINI HD
Coding pin carrier
Direct marking
MCS MINI HD
Pack. Unit
Coding pin carrier with six coding pins
714-101
297
Direct marking
1 – pole no.
of female connectors
for conductor termination
for male headers
Item No.
4
Direct Marking MCS MINI HD
713 Series female connectors can be marked with
“1 – pole no.” via factory direct printing
100 (4 x 25)
Two standard marking orientations are available:
1. Marking perpendicular to conductor entry
2. Marking parallel to conductor entry
Other custom marking options are available upon
request.
WAGO recommends pole marking on the PCB for 713
Series male headers.
Marking Perpendicular to Conductor Entry
Item No. Suffix: /. . . - 047
Ordering examples:
3.5 mm pin spacing, 16-pole,
black: 713-1108/000-0047
Female connector with levers and
strain relief plate, double-row,
black: 713-1108/037-047/033-000
The marking type is always defined by the second 4-digit
block of the item no. suffix for items with standard colors
and materials.
Example: 713-1110/. . . - xxxx
xxxx = Item no. suffix for direct pole marking
Marking parallel with Conductor Connection
Additional Item No.: /. . . - 9037
Ordering examples:
black: 713-1108/000-9037
black: 713-1108/037-9037
Coding a male header.
Coding a female connector.
Female connector with strain relief plate,
double-row,
3.5 mm pin spacing , 16-pole,
black: 713-1108/033-9037
4
4
300
Female Connectors with Push-Buttons
Pin Spacing: 3.5 mm
MCS MINI SL
F emale connectors terminate both solid and ferruled, fine-stranded
conductors via simple push-in terminations.
Integrated push-buttons provide convenient, tool-free operation
Ultra-low profile at just 7.8 mm, for conductor size up to 1.5 mm2
Coding and testing options available
Technical data:
Pin Spacing
Rating per
Pollution degree
Rated voltage
Rated surge voltage
Nominal current
Approvals per
Use group UL 1059
Rated voltage
Nominal current UL
Nominal current CSA
3.5 mm
0.138 in.
IEC/EN 60664-1
III
III
II
3
2
2
160 V 160 V 320 V
8A
8A
8A
UL/CSA
B
C
D
150 V
8A
Conductor data:
AWG
Strip length
CAGE CLAMP® S
0.2–1.5 mm2
0.2–1.5 mm2
0.25–0.75 mm2 (with insulated ferrule)
0.25–1.5 mm2
24–16
9–10 mm / 0.35–0.39 in.
Material data:
Material group
Insulating material
Temperature stability
Contact material
Contact plating
MCS MINI SL accessories:
I
Polyamide 6.6 (PA 6.6)
-60 °C to +100 °C
0V
Copper alloy
tin-plated
Marking accessories
Operating tool
Direct marking
Test pin
DIN EN 61984.
*CSA approval pending For additional technical information, see Section 13.
Pages:
570 – 573
301
301
568
!4
MCS MINI SL
301
0.2–1.5 mm2
160 V/2.5 kV/2 8 A
Pole No.
24–16 AWG
Item No.
Pack. Unit
714-102
714-103
714-104
714-105
714-106
714-108
714-110
714-112
714-114
714-115
714-116
> 3,5
2,1
Direct marking
1 – pole no.
150 V/8 A
Female connector with push-buttons,
black
2
3
4
5
6
8
10
12
14
15
16
Operating tool (screwdriver),
210-719
Ordering example:
1
3.5 mm pin spacing, 6-pole,
black: 714-106/000-047
4
4
302
Pin Spacing: 3.5 mm
MCS MINI SL
M
angled solder pins
H
reflow soldering
S
when unplugged
Technical data:
Pin Spacing
Rating per
Pollution degree
Rated voltage
Rated surge voltage
Nominal current
Approvals per
Use group UL 1059
Rated voltage
Nominal current UL
Nominal current CSA
3.5 mm
0.138 in.
IEC/EN 60664-1
III
III
II
3
2
2
160 V 160 V 320 V
8A
8A
8A
UL/CSA
B
C
D
150 V
8A
Solder pin data:
3.4 mm / 0.8 x 0.8 mm
1.2+0.1 mm
Material data:
Material group
Insulating material
Contact material
Contact plating
MCS MINI SL accessory:
I
-60 °C to +115 °C
0V
tin-plated
Coding pin carrier
DIN EN 61984.
Page:
303
MCS MINI SL
4
303
< 6,9 >
> 3
> 3,4
> 3,5
> 3,4
0,8
__>
0,8
4
2,45
> 3,5
0,8
_>
< 6,9 >
> 3
2,45
160 V/2.5 kV/2 8 A
150 V/8 A
160 V/2.5 kV/2 8 A
Coding pin carrier
L = (No. of poles -1) x pin spacing + 4.9 mm
Pole No.
Item No.
Pack. Unit
black
2
3
4
5
6
8
10
12
14
15
16
714-132
714-133
714-134
714-135
714-136
714-138
714-140
714-142
714-144
714-145
714-146
For other lengths, please contact factory.
Pole No.
Item No.
Pack. Unit
black
200
200
200
200
200
200
100
100
100
100
100
2
3
4
5
6
8
10
12
14
15
16
714-162
714-163
714-164
714-165
714-166
714-168
714-170
714-172
714-174
714-175
714-176
Item No.
Pack. Unit
200
200
200
200
200
200
100
100
100
100
100
714-101
100 (4 x 25)
