721-142/001-000
721-142/001-000
    WAGO(万可电子)
    插件,P=5mm
    接线端子 间距:5.00mm 1x12P 直插
721-142/001-000 数据手册
Printview: Male connector; with straight solder pins; 12-pole; pin spacing 5 mm / 0.197 in; 100% protected against mismating; without preceding ground contact; with closed end; Vertical PCB mounting - Item No.: 721-142/001-000 . Male connector; with straight solder pins; 12-pole; pin spacing 5 mm / 0.197 in; 100% protected against mismating; without preceding ground contact; with closed end; Vertical PCB mounting Item No.: 721-142/001-000 . Male connector; with straight solder pins; 12-pole; pin spacing 5 mm / 0.197 in; 100% protected against mismating; without preceding ground contact; with closed end; Vertical PCB mounting . Marking . Business data Supplier WAGO Item no. 721-142/001-000 GTIN / EAN 4044918869072 Content 1 Order amount 100 Customer item number . Notes Version with press-in pins provides solder-free connection to PCB100% protected against mismating Coding option available Technical data Miscellaneous No. of poles 12 Pin Spacing 5 mm / 0.197 in % Color light gray Ratings according to 1 IEC/EN 60664-1 Overvoltage category EN 1 III Pollution degree (1) 2 WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Male connector; with straight solder pins; 12-pole; pin spacing 5 mm / 0.197 in; 100% protected against mismating; without preceding ground contact; with closed end; Vertical PCB mounting - Item No.: 721-142/001-000 Technical data Rated voltage EN (1) [V] 320 [V] Rated surge voltage (1) [kV] 4 [kV] Nominal current [A] 12 [A] Overvoltage category EN 2 II Degree of pollution (2) 2 Rated voltage EN (2) [V] 630 [V] Rated surge voltage (2) [kV] 4 [kV] Nominal current (2) [A] 12 [A] Overvoltage category EN 3 III Degree of pollution (3) 3 Rated voltage EN (3) [V] 320 [V] Rated surge voltage (3) [kV] 4 [kV] Nominal current (3) [A] 12 [A] Solder pin length [mm] 5 [mm] Solder pin width A [mm] 1 [mm] Solder pin width B [mm] 1 [mm] Tolerance of drilled hole [mm] 1.4(+ 0.1) [mm] Material group I Insulating material Polyamide 66 (PA 66) Flammability rating per UL 94 V0 Limit temperature range -60 C … 100 C Contact material Electrolytic copper (Ecu) Contact plating tin-plated Fire load [MJ] 0.071 [MJ] Weight [g] 3.96 [g] Width 63.2 mm / 2.488 in Height 17 mm / 0.669 in Height from the surface 12 mm / 0.472 in Length 11.4 mm / 0.449 in WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Male connector; with straight solder pins; 12-pole; pin spacing 5 mm / 0.197 in; 100% protected against mismating; without preceding ground contact; with closed end; Vertical PCB mounting - Item No.: 721-142/001-000 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 3 Printview: Male connector; with straight solder pins; 12-pole; pin spacing 5 mm / 0.197 in; 100% protected against mismating; without preceding ground contact; with closed end; Vertical PCB mounting - Item No.: 721-142/001-000 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
721-142/001-000 价格&库存
很抱歉,暂时无法提供与“721-142/001-000”相匹配的价格&库存,您可以联系我们找货
库存:431
