790-116
790-116
    WAGO(万可电子)
790-116 数据手册
Data sheet | Item number: 790-116 Shield clamping saddle; 19 mm wide; diameter of compatible conductor; 7 ... 16 mm www.wago.com/790-116 Item description Safety information 1: Note: Cannot be used for connecting ground conductors! Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 1/7 Data sheet | Item number: 790-116 www.wago.com/790-116 Data Technical data Main product function Shield clamping saddle Safety information 1 Note: Cannot be used for connecting ground conductors! Physical data Width 19 mm / 0.748 inch Material data Weight 16.6 g Material Steel V2A Commercial data Product Group 2 (Terminal Block Accessories) Packaging type BOX Country of origin DE GTIN 4017332611756 Customs tariff number 85369010000 Compatible products N-busbar Item no.: 210-133 Busbar; tin-plated; 1000 mm long; Cu 10 mm x 3 mm; white www.wago.com/210-133 Item no.: 790-133 Busbar; tin-plated; 30 mm long; Cu 10 mm x 3 mm www.wago.com/790-133 Item no.: 790-134 Busbar; tin-plated; 50 mm long; Cu 10 mm x 3 mm www.wago.com/790-134 Item no.: 790-190 U-shaped busbar; Cu 10 mm x 3 mm; for 5 I/O; suitable for 750 Series I/O modules www.wago.com/790-190 Item no.: 790-191 U-shaped busbar; Cu 10 mm x 3 mm; for 8 I/O; suitable for 750 Series I/O modules www.wago.com/790-191 Item no.: 790-192 U-shaped busbar; Cu 10 mm x 3 mm; for 5 I/O; suitable for 750 Series I/O modules www.wago.com/790-192 Item no.: 790-193 www.wago.com/790-193 U-shaped busbar; Cu 10 mm x 3 mm; for 8 I/O; suitable for 750 Series I/O modules; silver-colored Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 2/7 Data sheet | Item number: 790-116 www.wago.com/790-116 U-shaped busbar; Cu 10 mm x 3 mm; for 8 I/O; suitable for 750 Series I/O modules; silver-colored assembling Item no.: 790-100 Isolated mounting carrier; for busbar with screw M4 x 8 mm; gray www.wago.com/790-100 Item no.: 790-101 Isolated mounting carrier; for busbar with sheet metal screw (3.5 x 9) mm; gray www.wago.com/790-101 shield connection Item no.: 790-112 Carrier with grounding foot; parallel to carrier rail; 25 mm long; Cu 10 mm x 3 mm; suitable for 790-108 and 790-116; gray www.wago.com/790-112 Item no.: 790-113 Carrier with grounding foot; 90° to carrier rail; 45 mm long; Cu 10 mm x 3 mm; suitable for 790 Series shield clamping saddles; gray www.wago.com/790-113 Item no.: 790-114 Carrier with grounding foot; parallel to carrier rail; 45 mm long; Cu 10 mm x 3 mm; suitable for 790 Series shield clamping saddles and 791 Series shield clamps; gray www.wago.com/790-114 Item no.: 790-115 Carrier with 2 grounding feet; parallel to carrier rail; 125 mm long; Cu 10 mm x 3 mm; silver-colored www.wago.com/790-115 Item no.: 790-145 Carrier rail; with special perforations; 1000 mm long; tin-plated; silver-colored www.wago.com/790-145 Carrier rail Downloads Documentation Bid Text 790-116 2019 Feb 19 xml 2.8 kB Download 2018 Nov 28 doc 24.1 kB Download URL Download ZUKEN Portal 790-116 URL Download EPLAN Data Portal 790-116 Subject to changes. Please also observe the further product documentation! URL Download X81 - Datei 790-116 doc - Datei CAD/CAE-Data CAD data 2D/3D Models 790-116 CAE data WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 3/7 Data sheet | Item number: 790-116 www.wago.com/790-116 EPLAN Data Portal 790-116 URL Download WSCAD Universe 790-116 URL Download URL Download Environmental Product Compliance Compliance Search Environmental Product Compliance 790-116 Shield clamping saddle; 19 mm wide; diameter of compatible conductor; 7 ... 16 mm Installation Notes WAGO's shield connection system is highly effective because the clamping unit can be brought very close to the unshielded part of the cable. Additionally, the spring material is part of the clamping saddle, providing a good electrical connection (the system also acts as a partial strain relief). The spring element integrated in the shield clamping saddle compensates for deformation and settling that results from a connected shield. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 4/7 Data sheet | Item number: 790-116 www.wago.com/790-116 Installation Removal The shield clamping saddle is shipped ready for direct connection to the (10 x 3) mm busbar or to a drilled mounting plate. After connection, tighten the knurled screw to complete the installation. To remove the clamping saddle, unscrew until ratcheted mechanism is released, then slightly tip saddle and remove the clamping saddle. Maximum tightening torque: 0.5 Nm Carrier with grounding foot* (790-113), 45 mm long, busbar 90° to the DIN-rail Carrier with grounding foot* (790-114), 45 mm long, busbar parallel to the DIN-rail Carrier with grounding foot* (790-1145), 125 mm long, busbar parallel to the rail *for all shield clamping saddle sizes *for all shield clamping saddle sizes *for all shield clamping saddle sizes Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 5/7 Data sheet | Item number: 790-116 www.wago.com/790-116 Securing an additional shield clamping saddle. Tightening/removing a shield clamping saddle. After connection, tighten the knurled screw to complete the installation. Recommended tightening torque: 0.5 Nm To remove the clamping saddle, unscrew until ratcheted mechanism is released, then slightly tip saddle and remove the clamping saddle. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 6/7 Data sheet | Item number: 790-116 www.wago.com/790-116 Carrier with grounding foot – busbar parallel to the rail Insulated mounting carriers for a common shield reference potential, independent of housing potential U-shaped (10 x 3) mm copper busbar Snap shield clamping saddles into any metal plate (max. thickness: 3 mm). Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 7/7
790-116 价格&库存
很抱歉,暂时无法提供与“790-116”相匹配的价格&库存,您可以联系我们找货
    库存:16
    790-116
      • 1+62.95165
      库存:101
      790-116
