Data sheet | Item number: 793-5501/000-002
WMB marking card; as card; for terminal block width 5 - 17.5 mm;
stretchable 5 - 5.2 mm; plain; snap-on type; yellow
www.wago.com/793-5501_000-002
Color:
Item description
Custom Labeling
Markers can also be customized using our Smart Designer Configuration Software.
Simply click on the "Configure" button on the right and label the markers as needed. To place an order, you must first register with the WAGO
For re-orders, simply use the provided item number; this number can also be found in your software projects.
Have questions about the WAGO Configuration Software Smart Designer?
Please email them to smart.designer@wago.com.
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
29.12.2019 Page 1/3
Data
Technical Data
Marking
plain
Marking
plain
Packing
10 strips with 10 markers per card
Geometrical Data
Marker/Strip width
5 … 5.2 mm
Marker width
5 mm
Material Data
Color
yellow
Weight
8.8 g
Fire load
0.264 MJ
Commercial data
Packaging type
BOX
Country of origin
DE
GTIN
4045454001940
Customs Tariff No.
49119900000
Downloads
Documentation
Bid Text
793-5501/000-002
Jan 4, 2018
doc
24.1 kB
Download
Feb 19, 2019
xml
2.7 kB
Download
doc - Datei
793-5501/000-002
X81 - Datei
Installation Notes
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 2/3
Separating a strip from the WMB marker
card.
Stretching a WMB marker strip.
Separating an individual marker from the
WMB marker strip – for larger terminal
blocks.
Snapping a marking strip into the marker slot.
Snapping a WMB marker strip into the
marker slot of the double marker carrier.
Product family
WMB Multi marking system
Show all products from the family
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 3/3
很抱歉,暂时无法提供与“793-5501/000-002”相匹配的价格&库存,您可以联系我们找货
