852-1605
852-1605
    WAGO(万可电子)
    WAGO - 852-1605 - ENET SWITCH, 12-PORT, RJ45 X 8, SFP X 4
852-1605 数据手册
NEW PRODUCT RELEASE Ethernet Switches Five new ethernet switches expand WAGO’s portfolio of industrial switches. These devices’ features address the needs of factory, process and energy markets with extended temperature operation (-40 °C ... +70 °C) and application specific features. 852-602: Managed switch with 8 RJ45 ports at 100 Mb/s supports PROFINET conformance Class B for high speed communications and the PROFINET MRP protocol for media redundancy. 852-603: Managed switch with 8 RJ45 ports at 100 Mb/s and 2 100 Mb/s fiber optic ports supports PROFINET conformance Class B for high speed communications and the PROFINET MRP protocol for media redundancy. 852-1305/000-001: Managed switch with 8 RJ45 ports at 1 Gb/s and 4 100 Mb/s fiber optic ports and is approved for the energy market IEC 61850-3 standard. Configure the switch via a USB port. 852-1505/000-001: Managed switch with 8 Power over Ethernet RJ45 ports at 1 Gb/s and 4 1 Gb/s fiber optic ports. The switch can be powered with 24 VDC eliminating the need for a 48 VDC power supply in the control cabinet. Configure the switch via a USB port. Features/Benefits: 852-1605: Managed switch with 8 RJ45 ports at 1 Gb/s and 4 1 Gb/s fiber optic ports supports PROFINET conformance Class B for high speed communications and the PROFINET MRP protocol for media redundancy. Features: Benefits: IEC 61850 approved managed switch 61850-3 defines the design and environmental conditions for utility communication devices. WAGO’s extended temperature switch is ideal for energy applications Managed switch with PROFIBUS Class B conformance 24 VDC power for Power over Ethernet switch Managed switch with extended temperature Product Comparison: Switch Type 852-602 Managed Use with PROFIBUS networks requiring PROFIBUS features including SNMP, network topology support, alarms and diagnostics, real time data exchange of 1 ms Eliminate the need for 48 VDC power supply in a panel for PoE devices Engineer these switches into harsh environment applications 852-603 852-1305/000-001 852-1505/000-001 852-1605 PoE - 30 W per port PROFINET Class B Managed Managed Managed Managed Features PROFINET Class B PROFINET Class B IEC 61850-3 approved 8 x 10/100/1000 Mb/s 8 x 10/100/1000 Mb/s Fiber Optic SFP None 2 x Conf. 100 Mb/s or 1 Gb/s 8 x 10/100/1000 Mb/s 4 x 1 Gb/s 4 x 1 Gb/s 4 x 1 Gb/s Copper RJ45 USB Port Power Supply 8 x 10/100 Mb/s None Redundant 8 x 10/100 Mb/s None Redundant 1 x USB Redundant 1 x USB Redundant None Redundant Operating Voltage 12 ... 60 VDC 12 ... 60 VDC 12 ... 48 VDC 24 ... 57 VDC 12 ... 60 VDC LEDs per Port Yes Yes Yes Yes Yes Alarm Relay Mounting Type Yes DIN rail Yes DIN rail Yes DIN rail Yes DIN rail Yes DIN rail Operating Temp. -40 °C ... +70 °C -40 °C ... +70 °C -40 °C ... +70 °C -40 °C ... +70 °C -40 °C ... +70 °C List Price $727.00 $872.10 $1,102.00 $1,156.00 $1,172.00 None 852-1200 1 Gb/s MM 0.55 KM 852-1210 1 Gb/s SM 10 KM 852-1280 1 Gb/s SM 80 KM 852-201/107-002 MM 100 Mb/s 2 KM 852-201/107-030 SM 100 Mb/s 30 KM 852-1200 1 Gb/s MM 0.55 KM 852-1210 1 Gb/s SM 10 KM 852-1280 1 Gb/s SM 80 KM 852-1200 1 Gb/s MM 0.55 KM 852-1210 1 Gb/s SM 10 KM 852-1280 1 Gb/s SM 80 KM 852-1200 1 Gb/s MM 0.55 KM 852-1210 1 Gb/s SM 10 KM 852-1280 1 Gb/s SM 80 KM cULus 61010-2-201 Use with SFP Accessories MM=Multi-mode SM=Single-mode Yes Yes Yes Yes Yes CONFIDENTIAL: NOT FOR CUSTOMER USE NEW PRODUCT RELEASE Ethernet Switches Competitive Analysis: WAGO 852-602 Siemens Phoenix Contact Product Category Managed switch Managed Ethernet switch Managed switch Features PROFINET Class B PROFINET Class B PROFINET Class B Fiber Optic SFP Slots None None 2 single-mode Est. List Price Copper RJ45 Ports USB Port $727.00 $715.00 8 x 10/100 Mb/s 4 x 10/100 Mb/s None 6 x 10/100 Mb/s None None Power Supply Redundant Redundant Redundant Operating Voltage 12 ... 60 VDC 18 ... 32 VDC 9 ... 57 VDC Alarm Relay Yes Yes None Operating Temp. -40 °C ... +70 °C -40 °C ... +60 °C -40 °C ... +70 °C Only 4 ports High cost WAGO 852-1505/000-001 Moxa N-Tron (Red Lion) Product Category Managed switch Managed switch Managed switch Features PoE 30 W / channel PoE 36 W / channel PoE 30 W / channel Fiber Optic SFP Slots 4 x 1 Gb/s 2 x 1 Gb/s None Notes Est. List Price Copper RJ45 Ports USB Port Power Supply $1,156.00 $1,599.00 8 x 1 Gb/s PoE 8 x 10/100 Mb/s PoE None None $2,362.00 8 x 1 Gb/s PoE Yes Operating Voltage Redundant 24 ... 57 VDC Redundant 48 VDC 22 ... 49 VDC Alarm Relay Yes Yes Yes Operating Temp. -40 °C ... +70 °C Notes 852 Selling Features: • • • • • • $1,234.00 Wide offering of industrial switches Managed and unmanaged products Extended temperature operation PoE versions with 30 Watts per channel Support of copper and fiber optic ports Competitively priced -40 °C ... +75 °C -40 °C ... +80 °C Copper ports are not 1 Gb/s, requires 48 VDC supply voltage Large footprint, high cost Where to Sell: • • • • • Redundant Machine builders Factories Process plants Marine applications Energy market Cross Selling: • • • • • • I/O modules Ethernet RJ45 connectors Power supplies Terminal blocks 750 Series I/O Touch Panel 600 Important Links: 852-602, 852-603, 852-1305/000-001, 852-1505/000-001, 852-1605, www.mywago.us CONFIDENTIAL: NOT FOR CUSTOMER USE
852-1605 价格&库存
很抱歉,暂时无法提供与“852-1605”相匹配的价格&库存,您可以联系我们找货
  • 1+11811.553881+1532.92410
