Data sheet | Item number: 855-8001
Power tap; with fuse; 2,5 mm² (12 AWG) - 6 mm² (10 AWG); Phase
www.wago.com/855-8001
Item description
Short description:
These voltage taps (855 Series) easily and safely tap the measurement voltage.
This allows a fuse-protected measurement voltage to be tapped from an insulated conductor with just one turn – no tools required.
Features:
Safely tap the measurement voltage with just one turn
Tool-free assembly
Secure mounting
Voltage taps (855-8001 and 855-8003) include a (5 x 25) mm 2 A fuse
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
02.08.2021 Page 1/5
For insulated conductors up to 16 mm² (6 AWG)
Cable length: 3 m
Note:
Spare fuse: WAGO 855-8020
Data
Technical data
Output – voltage tap
Rated voltage
AC 400 V
Continuous current (max.)
2 A
Voltage drop at output (max.)
≤ AC 0.5 V
Fuse (voltage path)
2 A; 450 V; F; 70 kA; 5 x 25 mm (WAGO 855-8020)
Safety and protection
Rated surge voltage
6 kV
Overvoltage category
III
Pollution degree
2
Protection type
IP20
Test voltage
Test voltage
AC 3 kV; 50 Hz; 1 min
Connection data
Connection technology
IDC
Solid conductor
2.5 … 6 mm² / 14 … 10 AWG
Fine-stranded conductor
Feedthrough for measurement conductor
Ø 3 … 5 mm
Cable type
Secondary side: 1 x 1.0 mm²; flexible; with ferrule
Physical data
Width
23 mm / 0.906 inch
Height
59 mm / 2.323 inch
Depth
23 mm / 0.906 inch
Cable length
3 m
Hansastr. 27
32423 Minden
02.08.2021 Page 2/5
Cable length
3 m
Mechanical data
Mounting type
Insulation displacement connection (IDC)
Mounting type
Mounting on insulated round cable
Usability
Can be reused several times (max. 24 times)
Material data
Flammability class per UL94
V2
Housing material
PA 66
Weight
25.9 g
Environmental requirements
Pollution degree
2
Surrounding air temperature (operation)
-5 … 55 °C
Surrounding air temperature (storage)
-20 … 70 °C
Relative humidity
5 … 85 % (without condensation)
Operating altitude (max.)
2000 m
Standards and specifications
Conformity marking
CE
Standards/Specifications
EN 60947-7-1
Commercial data
Packaging type
box
Country of origin
NL
GTIN
4055143371780
Customs tariff number
85366990990
Optional accessories
General accessories
Item no.: 2007-8873
Compact terminal block; for current and voltage transformers; 6,00 mm²; multicoloured
www.wago.com/2007-8873
Item no.: 2007-8874
www.wago.com/2007-8874
Item no.: 2007-8875
Compact terminal block; for current transformer circuit; 6,00 mm²; multicoloured
Hansastr. 27
32423 Minden
www.wago.com/2007-8875
02.08.2021 Page 3/5
Item no.: 2007-8875
Item no.: 2007-8876
Compact terminal block; for 3-phase current transformer circuit; 6,00 mm²; multicoloured
www.wago.com/2007-8876
Item no.: 2007-8877
www.wago.com/2007-8877
Item no.: 2857-570/024-000
www.wago.com/2857-570
3-Phase Power Measurement Module; 3x400/690 V/RC; Modbus RTU; Digital output; Configuration via
/024-000
software; Supply voltage: 24 VDC
Item no.: 2857-570/024-001
3-Phase Power Measurement Module; 3x400/690 V/1 A; Modbus RTU; Digital output; Configuration via
/024-001
Item no.: 2857-570/024-005
3-Phase Power Measurement Module; 3x400/690 V/5 A; Modbus RTU; Digital output; Configuration via
/024-005
Item no.: 855-8020
Miniature fuse; 5 x 25 mm; with indicator
www.wago.com/855-8020
Item no.: 857-560
Voltage signal conditioner; Voltage input signal; Current and voltage output signal; Digital output;
Configuration via software; Supply voltage: 24 VDC; 6 mm module width
www.wago.com/857-560
Item no.: 857-569
Power signal conditioner; Current and voltage input signal; Current and voltage output signal; Digital
output; Configuration via software; Supply voltage: 24 VDC; 6 mm module width
www.wago.com/857-569
Downloads
Documentation
Bid Text
855-8001
Feb 20, 2019
docx
17.6 kB
Download
Feb 19, 2019
xml
5.1 kB
Download
pdf
79.6 kB
Download
pdf
Download
docx - Datei
855-8001
X81 - Datei
Instruction Leaflet
Potentialabgriffe
Additional Information
Disposal; Electrical and electronic equipment, Packaging
V 1.0.0
Hansastr. 27
32423 Minden
265.8 kB
02.08.2021 Page 4/5
265.8 kB
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 855-8001
URL
Download
Installation Notes
Installation
Installation on an insulated conductor with
insulation displacement connection (IDC)
Integrated SIBA fuse to protect equipment
and conductor
Hansastr. 27
32423 Minden
02.08.2021 Page 5/5
很抱歉,暂时无法提供与“855-8001”相匹配的价格&库存,您可以联系我们找货
