Data sheet | Item number: 859-304
Relay module; Nominal input voltage: 24 VDC; 1 changeover contact; Red
status indicator; Module width: 6 mm; 2,50 mm²; gray
www.wago.com/859-304
Similiar to
Color:
DC load limit curve
Item
description
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
29.12.2019 Page 1/13
Item description
Note:
Inductive loads have to be attenuated by an appropriate protective circuit in order to protect relay coils and contacts.
Data
Technical Data
Control circuit
Nominal input voltage UN
DC 24 V
Input voltage range
-15 … +20 %
Nominal input current at UN
10 mA
Load circuit:
Number of changeover/switchover contacts
1
Contact material (relay)
AgSnO2
Limiting continuous current
5 A
Max. make current (resistive)
(AC) 20 A / 0.02 s
Max. switching voltage
AC 250 V
Max. switching power (resistive)
AC 1250 VA; DC see load limit curve
Recommended minimum load
10 V / 10 mA; 24 V / 1 mA
Pull-in time (typ.)
15 ms
Drop-out time (typ.)
25 ms
Bounce time (typ)
3.5 ms
Electrical life (N.O.; resistive load; 23 °C)
50 x 103 switching operations
Mechanical life
5 x 106 switching operations
Max. switching load with load/without load
6 min-1 / 180 min-1
Signaling
Status indication
LED red
Safety and protection:
Rated voltage
Rated impulse voltage
Subject to changes.
Hansastr. 27
32423 Minden
250 V
4 kV
29.12.2019 Page 2/13
4 kV
Pollution degree
2
Dielectric strength, control/load circuit (AC, 1 min)
4 kVrms
Dielectric strength open contact (AC, 1 min)
1 kVrms
Connection data
Connection technology
CAGE CLAMP®
Solid conductor
0.08 … 2.5 mm² / 28 … 14 AWG
Fine-stranded conductor
Strip length
5 … 6 mm / 0.2 … 0.24 inch
Geometrical Data
Width
6 mm / 0.236 inch
Height from upper-edge of DIN-35 rail
56 mm / 2.205 inch
Depth
91 mm / 3.583 inch
Mechanical data
Type of mounting
DIN-35 rail
Material Data
Color
gray
Weight
22.9 g
Environmental Requirements
Surrounding air (operating) temperature at UN
-40 … 50 °C
Surrounding air (storage) temperature
-40 … 70 °C
Processing temperature
-25 … +50 °C
Standards and specifications
Standards/specifications
EN 61010-2-201; EN 61810-1; EN 61373; GL; UL 508
Commercial data
Product Group
6 (Interface Electronics)
Packaging type
BOX
Country of origin
CN
GTIN
Subject to changes.
Hansastr. 27
32423 Minden
4055143606769
29.12.2019 Page 3/13
GTIN
4055143606769
Customs Tariff No.
85364900990
Approvals / Certificates
Ship Approvals
Logo
Approval
Additional Approval Text
Certificate
name
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAA00001D1
NK
Nippon Kaiji Kyokai
TA17255M
PRS
Polski Rejestr Statków
TE/2186
/880590/18
UL-Approvals
Logo
Approval
UL
UL International Netherlands B.V. (ORDINARY
LOCATIONS)
UL 508
Certificate
name
E175199
Sec.4
Compatible products
Jumper
Item no.: 859-402
Push-in type jumper bar; 2-way; Nominal current 18 A; insulated; light gray
www.wago.com/859-402
Item no.: 859-402/000-005
Push-in type jumper bar; 2-way; Nominal current 18 A; insulated; red
/000-005
Item no.: 859-402/000-006
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 4/13
Push-in type jumper bar; 2-way; Nominal current 18 A; insulated; blue
/000-006
Item no.: 859-402/000-029
Push-in type jumper bar; 2-way; Nominal current 18 A; insulated; yellow
/000-029
Item no.: 859-403
Push-in type jumper bar; 3-way; Nominal current 18 A; insulated; light gray
www.wago.com/859-403
Item no.: 859-403/000-005
Push-in type jumper bar; 3-way; Nominal current 18 A; insulated; red
/000-005
Item no.: 859-403/000-006
Push-in type jumper bar; 3-way; Nominal current 18 A; insulated; blue
/000-006
Item no.: 859-403/000-029
Push-in type jumper bar; 3-way; Nominal current 18 A; insulated; yellow
/000-029
Item no.: 859-404
Push-in type jumper bar; 4-way; Nominal current 18 A; insulated; light gray
www.wago.com/859-404
Item no.: 859-404/000-005
Push-in type jumper bar; 4-way; Nominal current 18 A; insulated; red
/000-005
Item no.: 859-404/000-006
Push-in type jumper bar; 4-way; Nominal current 18 A; insulated; blue
/000-006
Item no.: 859-404/000-029
Push-in type jumper bar; 4-way; Nominal current 18 A; insulated; yellow
/000-029
Item no.: 859-405
Push-in type jumper bar; 5-way; Nominal current 18 A; insulated; light gray
www.wago.com/859-405
Item no.: 859-405/000-005
Push-in type jumper bar; 5-way; Nominal current 18 A; insulated; red
/000-005
Item no.: 859-405/000-006
Push-in type jumper bar; 5-way; Nominal current 18 A; insulated; blue
/000-006
Item no.: 859-405/000-029
Push-in type jumper bar; 5-way; Nominal current 18 A; insulated; yellow
/000-029
Item no.: 859-406
Push-in type jumper bar; 6-way; Nominal current 18 A; insulated; light gray
Subject to changes.
Hansastr. 27
32423 Minden
www.wago.com/859-406
29.12.2019 Page 5/13
Item no.: 859-406
Item no.: 859-406/000-005
Push-in type jumper bar; 6-way; Nominal current 18 A; insulated; red
/000-005
Item no.: 859-406/000-006
Push-in type jumper bar; 6-way; Nominal current 18 A; insulated; blue
/000-006
Item no.: 859-406/000-029
Push-in type jumper bar; 6-way; Nominal current 18 A; insulated; yellow
/000-029
Item no.: 859-407
Push-in type jumper bar; 7-way; Nominal current 18 A; insulated; light gray
www.wago.com/859-407
Item no.: 859-407/000-005
Push-in type jumper bar; 7-way; Nominal current 18 A; insulated; red
/000-005
Item no.: 859-407/000-006
Push-in type jumper bar; 7-way; Nominal current 18 A; insulated; blue
/000-006
Item no.: 859-407/000-029
Push-in type jumper bar; 7-way; Nominal current 18 A; insulated; yellow
/000-029
Item no.: 859-408
Push-in type jumper bar; 8-way; Nominal current 18 A; insulated; light gray
www.wago.com/859-408
Item no.: 859-408/000-005
Push-in type jumper bar; 8-way; Nominal current 18 A; insulated; red
/000-005
Item no.: 859-408/000-006
Push-in type jumper bar; 8-way; Nominal current 18 A; insulated; blue
/000-006
Item no.: 859-408/000-029
Push-in type jumper bar; 8-way; Nominal current 18 A; insulated; yellow
/000-029
Item no.: 859-409
Push-in type jumper bar; 9-way; Nominal current 18 A; insulated; light gray
www.wago.com/859-409
Item no.: 859-409/000-005
Push-in type jumper bar; 9-way; Nominal current 18 A; insulated; red
/000-005
Item no.: 859-409/000-006
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 6/13
Push-in type jumper bar; 9-way; Nominal current 18 A; insulated; blue
/000-006
Item no.: 859-409/000-029
Push-in type jumper bar; 9-way; Nominal current 18 A; insulated; yellow
/000-029
Item no.: 859-410
Push-in type jumper bar; 10-way; Nominal current 18 A; insulated; light gray
www.wago.com/859-410
Item no.: 859-410/000-005
Push-in type jumper bar; 10-way; Nominal current 18 A; insulated; red
/000-005
Item no.: 859-410/000-006
Push-in type jumper bar; 10-way; Nominal current 18 A; insulated; blue
/000-006
Item no.: 859-410/000-029
Push-in type jumper bar; 10-way; Nominal current 18 A; insulated; yellow
/000-029
Item no.: 216-221
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-221
Item no.: 216-222
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-222
Item no.: 216-223
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-223
Item no.: 216-224
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-224
Item no.: 216-321
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-321
Item no.: 216-322
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-322
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft
www.wago.com/210-720
Item no.: 859-525
End and intermediate plate; 1 mm thick; gray
www.wago.com/859-525
Item no.: 859-500
Test pin; 1 mm Ø; with solder connection for test wire
www.wago.com/859-500
ferrule
tools
End plate
check
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 7/13
Marking accessories
Item no.: 2009-145
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-145
Item no.: 2009-145/000-002
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; yellow
/000-002
Item no.: 2009-145/000-005
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; red
/000-005
Item no.: 2009-145/000-006
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 2009-145/000-007
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-145/000-012
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-145/000-023
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 2009-145/000-024
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 210-110
Fiber-tip pen
www.wago.com/210-110
Item no.: 248-501
Miniature WSB Quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers per card
www.wago.com/248-501
Item no.: 248-501/000-002
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 248-501/000-005
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 248-501/000-006
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 248-501/000-007
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 8/13
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 248-501/000-012
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 248-501/000-017
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 248-501/000-023
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 248-501/000-024
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 248-502
Mini-WSB marking card; as card; MARKED; 1 ... 10 (10x); not stretchable; Horizontal marking; snap-on
type; white
www.wago.com/248-502
Item no.: 248-502/000-024
type; violet
/000-024
Item no.: 248-503
Mini-WSB marking card; as card; MARKED; 11 ... 20 (10x); not stretchable; Horizontal marking; snap-on
type; white
www.wago.com/248-503
Item no.: 248-503/000-024
type; violet
/000-024
Item no.: 248-504
Mini-WSB marking card; as card; MARKED; 21 ... 30 (10x); not stretchable; Horizontal marking; snap-on
type; white
www.wago.com/248-504
Item no.: 248-504/000-024
type; violet
/000-024
Item no.: 248-505/000-024
Mini-WSB marking card; as card; MARKED; 31 ... 40 (10x); not stretchable; Horizontal marking; snap-on
type; violet
www.wago.com/248-505
/000-024
Item no.: 248-506
Mini-WSB marking card; as card; MARKED; 41 ... 50 (10x); not stretchable; Horizontal marking; snap-on
type; white
www.wago.com/248-506
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type; white
www.wago.com/793-501
Item no.: 793-501/000-002
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 9/13
WMB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 793-501/000-005
WMB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 793-501/000-006
WMB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 793-501/000-007
WMB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 793-501/000-012
WMB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 793-501/000-017
WMB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 793-501/000-023
WMB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 793-501/000-024
WMB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501
type; white
Item no.: 793-5501/000-002
/000-002
type; yellow
Item no.: 793-5501/000-005
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; red
/000-005
Item no.: 793-5501/000-006
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 793-5501/000-007
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 793-5501/000-012
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 10/13
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 793-5501/000-017
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; light green
/000-017
Item no.: 793-5501/000-023
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 793-5501/000-024
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Downloads
Documentation
Bid Text
859-304
Feb 19, 2019
xml
4.6 kB
Download
Feb 20, 2019
docx
17.2 kB
Download
V 1.2.0
Aug 30, 2019
pdf
2.2 MB
Download
V 1.0.0
pdf
265.8 kB
Download
URL
Download
X81 - Datei
859-304
docx - Datei
Instruction Leaflet
Relay modules, Optocoupler modules
Additional Information
Disposal; Electrical and electronic equipment, Packaging
CAD/CAE-Data
CAD data
2D/3D Models 859-304
CAE data
EPLAN Data Portal 859-304
Subject to changes.
Hansastr. 27
32423 Minden
Download
Download
29.12.2019 Page 11/13
WSCAD Universe 859-304
Download
Installation Notes
Inserting a conductor
Connection of conductor
Jumpered
Easy commoning using adjacent jumpers
Marking
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 12/13
Marking using miniature WSB quick marking
card
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 13/13
很抱歉,暂时无法提供与“859-304”相匹配的价格&库存,您可以联系我们找货
