0283-0671
    WAGO(万可电子)
0283-0671 数据手册
Printview: 3-conductor through terminal block - Item No.: 283-671 . 3-conductor through terminal block Item No.: 283-671 . 3-conductor through terminal block . Marking . Business data Supplier WAGO Item no. 283-671 GTIN / EAN 4044918543637 Content 1 Order amount 20 Customer item number . Notes Safety information 1: Notice: This terminal block cannot be commoned with adjacent jumpers! Technical data Miscellaneous Total number of connection points 3 Total number of potentials 1 Color gray Ratings according to 1 IEC/EN 60947-7-1 Pollution degree (1) 3 Rated voltage EN (1) [V] 800 [V] Rated surge voltage (1) [kV] 8 [kV] Nominal current [A] 76 [A] Connection technology (1) CAGE CLAMP® WAGO Kontakttechnik GmbH & Co. KG 1 Printview: 3-conductor through terminal block - Item No.: 283-671 Technical data Solid sizes 1 0.2 … 16 mm² / 24 … 6 AWG Fine-stranded wires 1 0.2 … 16 mm² / 24 … 6 AWG Strip length 1 16 … 17 mm / 0.63 … 0.67 in Type of wiring Front-entry wiring Design horizontal Marking level Center marking Insulating material Polyamide 66 (PA 66) Fire load [MJ] 0.619 [MJ] Weight [g] 45.331 [g] Width 12 mm / 0.472 in Height from upper-edge of DIN-rail [mm] 37.5 [mm] Height from upper-edge of DIN-rail 37.5 mm / 1.476 in Length 104.5 mm / 4.114 in Type of mounting DIN 35 rail WAGO Kontakttechnik GmbH & Co. KG 2 Printview: 3-conductor through terminal block - Item No.: 283-671 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 3 Printview: 3-conductor through terminal block - Item No.: 283-671 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
0283-0671 价格&库存
很抱歉,暂时无法提供与“0283-0671”相匹配的价格&库存,您可以联系我们找货
