2001-1402
    WAGO(万可电子)
    端子块连接器 4 位置 馈通式 橙色 14-22 AWG
2001-1402 数据手册
Data sheet  |  Item number: 2001-1402 4-conductor through terminal block; 1.5 mm²; suitable for Ex e II applications; side and center marking; for DIN-rail 35 x 15 and 35 x 7.5; Pushin CAGE CLAMP®; 1,50 mm²; orange www.wago.com/2001-1402 Color: Data Electrical data Ratings per IEC/EN 60664-1 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 1/19 Data sheet  |  Item number: 2001-1402 www.wago.com/2001-1402 Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 800 V Rated impulse voltage (III / 3) 8 kV Rated current 18 A Rated current (2) 24 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Approvals per UL 1059 Rated voltage UL (Use Group B) 600 V Rated current UL (Use Group B) 15 A Rated voltage UL (Use Group C) 600 V Rated current UL (Use Group C) 15 A Approvals per CSA Rated voltage CSA (Use Group B) 600 V Rated current CSA (Use Group B) 15 A Rated voltage CSA (Use Group C) 600 V Rated current CSA (Use Group C) 15 A Approvals Ex Rated voltage EN (Ex e II) 550 V Rated current (Ex e II) 17 A Rated current (Ex e II) with jumper 16 A Connection data Connection technology Push-in CAGE CLAMP® Actuation type Push-in Open Tool Slot Connectable conductor materials Copper Nominal cross section 1.5 mm² Solid conductor 0.25 … 2.5 mm² / 22 … 14 AWG Solid conductor, push-in termination 0.75 … 2.5 mm² / 18 … 14 AWG Fine-stranded conductor 0.25 … 2.5 mm² / 22 … 14 AWG Fine-stranded conductor with ferrule with plastic collar 0.75 … 1.5 mm² / 18 … 16 AWG Fine-stranded conductor with ferrule, push-in termination, from 0.75 … 1.5 mm² / 18 … 16 AWG Strip length 9 … 11 mm / 0.35 … 0.43 inch Total number of connection points Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com 4 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 2/19 Data sheet  |  Item number: 2001-1402 www.wago.com/2001-1402 Total number of connection points 4 Total number of potentials 1 Number of levels 1 Type of wiring Front-entry wiring Note (conductor cross-section) Depending on the conductor characteristic, a conductor with a smaller cross section can also be inserted via push-in termination. Number of jumper slots 2 Geometrical Data Width 4.2 mm / 0.165 inch Height from upper-edge of DIN-35 rail 32.9 mm / 1.295 inch Depth 69.9 mm / 2.752 inch Mechanical data Design horizontal Type of mounting DIN-35 rail Marking level Center/side marking Material Data Color orange Insulating material Polyamide 66 (PA 66) Weight 5.1 g Commercial data Product Group 22 (TOPJOB S) Packaging type BOX Country of origin DE GTIN 4017332998680 Customs Tariff No. 85369010000 Approvals / Certificates Ex-Approvals Logo Approval Additional Approval Text ATEx Physikalisch Technische Bundesanstalt (PTB) EN 60079 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Certificate name PTB 05 ATEX 1094 U (II 2 G Ex e II Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 3/19 Data sheet  |  Item number: 2001-1402 www.wago.com/2001-1402 2 G Ex e II bzw.I M 2 Ex e I) IECEx Physikalisch Technische Bundesanstalt (PTB) IEC 60079 IECEx PTB 11.0093U (Ex e IIC Gb or Ex e I Mb) Country specific Approvals Logo Approval Additional Approval Text Certificate name CCA DEKRA Certification B.V. EN 60947 2160584.07 CCA DEKRA Certification B.V. EN 60947 NTR NL7084 CSA DEKRA Certification B.V. C22.2 No. 158 1645434 Approval Additional Approval Text ABS American Bureau of Shipping EN 60947 14HG1293677PDA DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001V2 LR Lloyds Register EN 60947 91/20112 (E9) Ship Approvals Logo Certificate name UL-Approvals Logo Approval UL Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Additional Approval Text Certificate name UL 1059 20190731- Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 4/19 Data sheet  |  Item number: 2001-1402 www.wago.com/2001-1402 UL UL International Germany GmbH UL 1059 20190731E45172 Compatible products tools Item no.: 210-647 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-647 Item no.: 210-648 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; angled; short www.wago.com/210-648 Item no.: 210-719 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-719 Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm www.wago.com/210-112 Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-113 Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715 www.wago.com/210-114 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm www.wago.com/210-115 Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-118 Item no.: 210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silvercolored www.wago.com/210-196 Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715 www.wago.com/210-197 Carrier rail Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; copperSubject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/210-198 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 5/19 Data sheet  |  Item number: 2001-1402 www.wago.com/2001-1402 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored www.wago.com/210-198 End plate Item no.: 2002-1491 End and intermediate plate; 0.8 mm thick; gray www.wago.com/2002-1491 Item no.: 2002-1492 End and intermediate plate; 0.8 mm thick; orange www.wago.com/2002-1492 Item no.: 2002-1493 Separator plate; 2 mm thick; oversized; gray www.wago.com/2002-1493 Item no.: 2002-1494 Separator plate; 2 mm thick; oversized; orange www.wago.com/2002-1494 Item no.: 209-191 Separator for Ex e/Ex i applications; 3 mm thick; 120 mm wide; orange www.wago.com/209-191 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; red www.wago.com/216-243 Item no.: 216-244 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-244 Item no.: 2001-511 Modular TOPJOB®S connector; modular; for jumper contact slot; 1-pole; 1,50 mm²; gray www.wago.com/2001-511 Item no.: 2001-549 Spacer module; modular; e.g., for bridging commoned terminal blocks; gray www.wago.com/2001-549 Item no.: 2001-552 Modular TOPJOB®S connector; modular; for jumper contact slot; 2-pole; 1,50 mm²; gray www.wago.com/2001-552 Item no.: 2001-553 Modular TOPJOB®S connector; modular; for jumper contact slot; 3-pole; 1,50 mm²; gray www.wago.com/2001-553 Item no.: 2001-554 Modular TOPJOB®S connector; modular; for jumper contact slot; 4-pole; 1,50 mm²; gray www.wago.com/2001-554 Item no.: 2001-555 Modular TOPJOB®S connector; modular; for jumper contact slot; 5-pole; 1,50 mm²; gray www.wago.com/2001-555 ferrule check Item no.: 2001-556 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2001-556 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 6/19 Data sheet  |  Item number: 2001-1402 www.wago.com/2001-1402 Item no.: 2001-556 Modular TOPJOB®S connector; modular; for jumper contact slot; 6-pole; 1,50 mm²; gray www.wago.com/2001-556 Item no.: 2001-557 Modular TOPJOB®S connector; modular; for jumper contact slot; 7-pole; 1,50 mm²; gray www.wago.com/2001-557 Item no.: 2001-558 Modular TOPJOB®S connector; modular; for jumper contact slot; 8-pole; 1,50 mm²; gray www.wago.com/2001-558 Item no.: 2001-559 Modular TOPJOB®S connector; modular; for jumper contact slot; 9-pole; 1,50 mm²; gray www.wago.com/2001-559 Item no.: 2001-560 Modular TOPJOB®S connector; modular; for jumper contact slot; 10-pole; 1,50 mm²; gray www.wago.com/2001-560 Item no.: 2009-174 Test plug adapter; for 4 mm Ø test plugs; for testing TOPJOB®S rail-mounted terminal blocks; gray www.wago.com/2009-174 Item no.: 2009-182 Testing tap; for max. 2.5 mm²; tool-free connection for individual test wires 0.08 - 2.5 mm; gray www.wago.com/2009-182 Item no.: 2001-402 Push-in type jumper bar; insulated; 2-way; Nominal current 18 A; light gray www.wago.com/2001-402 Item no.: 2001-403 Push-in type jumper bar; insulated; 3-way; Nominal current 18 A; light gray www.wago.com/2001-403 Item no.: 2001-404 Push-in type jumper bar; insulated; 4-way; Nominal current 18 A; light gray www.wago.com/2001-404 Item no.: 2001-405 Push-in type jumper bar; insulated; 5-way; Nominal current 18 A; light gray www.wago.com/2001-405 Item no.: 2001-405/011-000 Star point jumper; insulated; 3-way (1-3-5); IN = IN terminal block; light gray www.wago.com/2001-405 /011-000 Item no.: 2001-406 Push-in type jumper bar; insulated; 6-way; Nominal current 18 A; light gray www.wago.com/2001-406 Item no.: 2001-406/020-000 Delta jumper; insulated; 1-2 3-4 5-6; IN = IN terminal block; light gray www.wago.com/2001-406 /020-000 Item no.: 2001-407 Push-in type jumper bar; insulated; 7-way; Nominal current 18 A; light gray www.wago.com/2001-407 Item no.: 2001-408 Push-in type jumper bar; insulated; 8-way; Nominal current 18 A; light gray www.wago.com/2001-408 Item no.: 2001-409 Push-in type jumper bar; insulated; 9-way; Nominal current 18 A; light gray www.wago.com/2001-409 Jumper Item no.: 2001-410 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2001-410 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 7/19 Data sheet  |  Item number: 2001-1402 www.wago.com/2001-1402 Item no.: 2001-410 Push-in type jumper bar; insulated; 10-way; Nominal current 18 A; light gray www.wago.com/2001-410 Item no.: 2001-433 Push-in type jumper bar; insulated; from 1 to 3; Nominal current 18 A; light gray www.wago.com/2001-433 Item no.: 2001-434 Push-in type jumper bar; insulated; from 1 to 4; Nominal current 18 A; light gray www.wago.com/2001-434 Item no.: 2001-435 Push-in type jumper bar; insulated; from 1 to 5; Nominal current 18 A; light gray www.wago.com/2001-435 Item no.: 2001-436 Push-in type jumper bar; insulated; from 1 to 6; Nominal current 18 A; light gray www.wago.com/2001-436 Item no.: 2001-437 Push-in type jumper bar; insulated; from 1 to 7; Nominal current 18 A; light gray www.wago.com/2001-437 Item no.: 2001-438 Push-in type jumper bar; insulated; from 1 to 8; Nominal current 18 A; light gray www.wago.com/2001-438 Item no.: 2001-439 Push-in type jumper bar; insulated; from 1 to 9; Nominal current 18 A; light gray www.wago.com/2001-439 Item no.: 2001-440 Push-in type jumper bar; insulated; from 1 to 10; Nominal current 18 A; light gray www.wago.com/2001-440 Item no.: 2006-499 Step-down jumper; insulated; from 6/4 mm² to 4/2.5/1.5 mm²; Nominal current 32 A; light gray www.wago.com/2006-499 Item no.: 2009-412 Push-in type wire jumper; insulated; wire length 60 mm; Conductor cross section 1.5 mm²; suitable for 2001, 2002, 2003 and 2022 Series rail-mounted terminal blocks; black www.wago.com/2009-412 Item no.: 2009-414 Push-in type wire jumper; insulated; wire length 110 mm; Conductor cross section 1.5 mm²; suitable for 2001, 2002, 2003 and 2022 Series rail-mounted terminal blocks; black www.wago.com/2009-414 Item no.: 2009-416 Push-in type wire jumper; insulated; wire length 250 mm; Conductor cross section 1.5 mm²; suitable for 2001, 2002, 2003 and 2022 Series rail-mounted terminal blocks; black www.wago.com/2009-416 Item no.: 210-103 Wire commoning chain; insulated; 50 connections; black www.wago.com/210-103 Item no.: 210-123 Wire commoning chain; insulated; 50 connections www.wago.com/210-123 Marking accessories Item no.: 2009-110 Marking strips; on reel; not stretchable; plain; snap-on type; white www.wago.com/2009-110 Item no.: 2009-114 WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; white www.wago.com/2009-114 Item no.: 2009-114/000-002 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2009-114 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 8/19 Data sheet  |  Item number: 2001-1402 www.wago.com/2001-1402 Item no.: 2009-114/000-002 WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; yellow www.wago.com/2009-114 /000-002 Item no.: 2009-114/000-005 WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; red www.wago.com/2009-114 /000-005 Item no.: 2009-114/000-006 WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; blue www.wago.com/2009-114 /000-006 Item no.: 2009-114/000-007 WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; gray www.wago.com/2009-114 /000-007 Item no.: 2009-114/000-012 WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; orange www.wago.com/2009-114 /000-012 Item no.: 2009-114/000-023 WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; green www.wago.com/2009-114 /000-023 Item no.: 2009-114/000-024 WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; violet www.wago.com/2009-114 /000-024 Item no.: 793-4501 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; white www.wago.com/793-4501 Item no.: 793-4501/000-002 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; yellow www.wago.com/793-4501 /000-002 Item no.: 793-4501/000-005 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; red www.wago.com/793-4501 /000-005 Item no.: 793-4501/000-006 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; blue www.wago.com/793-4501 /000-006 Item no.: 793-4501/000-007 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; gray www.wago.com/793-4501 /000-007 Item no.: 793-4501/000-012 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; orange www.wago.com/793-4501 /000-012 Item no.: 793-4501/000-017 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; light green www.wago.com/793-4501 /000-017 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 9/19 Data sheet  |  Item number: 2001-1402 www.wago.com/2001-1402 Item no.: 793-4501/000-023 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; green www.wago.com/793-4501 /000-023 Item no.: 793-4501/000-024 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; violet www.wago.com/793-4501 /000-024 Item no.: 793-501 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 Item no.: 793-501/000-002 WMB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/793-501 /000-002 Item no.: 793-501/000-005 WMB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/793-501 /000-005 Item no.: 793-501/000-006 WMB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/793-501 /000-006 Item no.: 793-501/000-007 WMB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/793-501 /000-007 Item no.: 793-501/000-012 WMB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/793-501 /000-012 Item no.: 793-501/000-017 WMB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/793-501 /000-017 Item no.: 793-501/000-023 WMB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/793-501 /000-023 Item no.: 793-501/000-024 WMB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/793-501 /000-024 Protective Warning Marker Item no.: 2001-115 Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow www.wago.com/2001-115 Item no.: 2001-171 Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray www.wago.com/2001-171 Insulation stop Downloads Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 10/19 Data sheet  |  Item number: 2001-1402 www.wago.com/2001-1402 Downloads Documentation Bid Text 2001-1402 Feb 19, 2019 xml 4.0 kB Download Aug 2, 2018 docx 15.1 kB Download Apr 3, 2019 pdf 2.1 MB Download URL Download X81 - Datei 2001-1402 docx - Datei Additional Information Technical explanations CAD/CAE-Data CAD data 2D/3D Models 2001-1402 CAE data EPLAN Data Portal 2001-1402 Download WSCAD Universe 2001-1402 Download Installation Notes Inserting a conductor All conductor types at a glance Terminating solid and ferruled conductors via push-in connection. Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 11/19 Data sheet  |  Item number: 2001-1402 www.wago.com/2001-1402 Inserting conductors via push-in termination. Solid conductors with cross-sections from either one size above, or up to two sizes below, the rated cross-section can be simply pushed in – no tools needed. Inserting a conductor via operating tool. Conductor termination – Insulation stop. Connecting fine-stranded conductors without ferrules, or small cross-sectional conductors that cannot be pushed in, is performed similarly to the original CAGE CLAMP® – just use an operating tool. The smart feature: To open the clamp, the operating tool is inserted vertically. The conductor entry is less than 15 degrees for easier wiring. Jumpered Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 12/19 Data sheet  |  Item number: 2001-1402 www.wago.com/2001-1402 The push-in type jumper bar system is based on the common plug and socket principle. Each terminal block is spring-loaded with a double socket and a resilient CrNi steel spring. The jumper contact material is pure electrolytic copper, which allows for an extremely small design capable of carrying the full-rated current of the terminal block. Ground terminal blocks can also be commoned using the same jumper system. Custom jumpers are created by breaking and removing jumper contacts (2000, 2001, 2002, 2004 Series). Removing a push-in type jumper bar. Insert the operating tool between the jumper and and partition wall of the dual jumper slots, then lift up the jumper. Place the operating tool in the center of jumpers up to five contacts (see above), or alternately on both sides for jumpers with more than five contacts. Jumpered This star point jumper has been specially developed to create a “star point” and is used on motor terminal boards equipped with TOPJOB® S rail-mount terminal blocks. This delta jumper has been specially developed to create a delta configuration and is used on motor terminal boards equipped with TOPJOB® S rail-mount terminal blocks. Push down the wire jumper until fully inserted. Lift the jumper with an operating tool for rewiring. Jumpered Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 13/19 Data sheet  |  Item number: 2001-1402 www.wago.com/2001-1402 Step-down jumpers may common terminal blocks of different sizes, without losing a conductor clamping point. This can be beneficial on long conductor runs where voltage drops may be problematic. A large conductor can be easily connected to smaller conductors at the distribution point. Using step-down jumpers, an end plate must be inserted between the terminal blocks to be commoned. Step-down jumper (2006‑499) commons 6 /4 mm² (10/12 AWG) terminal blocks (2006 /2004 Series) with 4/2.5/1.5 mm² (12/14/16 AWG) terminal blocks (2004/2002/2001 Series). Commoning may be made in either direction using the special thin end plate to cover the open side. Additional through terminal blocks having a smaller cross-section may be commoned using push-in type jumper bars. Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 14/19 Data sheet  |  Item number: 2001-1402 www.wago.com/2001-1402 Step-down jumper (2016‑499) commons 16 /10 mm² (16/8 AWG) terminal blocks (2016 /2010 Series) with 10/6/4/2.5 mm² (8/10/12 /14 AWG) terminal blocks (2010/2006/2004 /2002 Series). Stepping down via push-in type jumper bar. Stepping down via push-in type jumper bar. Commoning via open terminal side with end plate allows jumpering over two crosssection sizes for 16 mm² (6 AWG) and 10 mm² (8 AWG) and one cross-section size for 6/4/2.5 mm² (10/12/14 AWG). An example: from 16 mm² (6 AWG) to 6 mm² (10 AWG) (see illustration above) or from 10 mm² (8 AWG) to 4 mm² (12 AWG). Commoning via closed terminal side with end plate allows jumpering over two crosssection sizes, e.g., from 16 mm² (6 AWG) to 6 mm² (10 AWG) or from 6 mm² (10 AWG) to 2.5 mm² (14 AWG) (see illustration above). Note: The total current of the outgoing circuits shall not exceed the nominal current of the step-down jumper/push-in type jumper bar. Testing Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 15/19 Data sheet  |  Item number: 2001-1402 www.wago.com/2001-1402 The modular TOPJOB® S connectors also connect conductors of the same size as the terminal blocks being used. TOPJOB® S Connectors with a 2 mm Ø test socket for testing voltage via 2-pole voltage tester Test plug adapter (2009‑174, CAT I) for 4 mm Ø plugs – compatible with 2000 to 2016 Series Testing tap (2009‑182) for tool-free connection of test cables up to 2.5 mm² (12 AWG) – compatible with 2000 to 2016 Series Rail-mount terminal block assembly for electric motor wiring Marking Snapping WMB Inline markers into marker slots. Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 16/19 Data sheet  |  Item number: 2001-1402 www.wago.com/2001-1402 TOPJOB® S 2009‑193 Group Marker Carrier (equipped with a marking strip) for all 2001 to 2016 Series TOPJOB® S Rail-Mount Terminal Blocks Do not use on an end plate! Through terminal blocks with a blue insulated housing are suitable for Ex i applications. All through and ground conductor terminal blocks are suitable for Ex e II applications. Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 17/19 Data sheet  |  Item number: 2001-1402 www.wago.com/2001-1402 Separator for Ex e/Ex applications Ex e II/Ex i terminal strip An end plate must be applied to the terminal block located directly behind an Ex e/Ex i separator plate. Notice: Separator located between Ex e II and Ex i terminal strip The movable feet of terminal blocks and separator plates must face the same direction. End plate Ex e II terminal blocks Separator for Ex e/Ex i applications End plate Ex i terminal blocks According to EN 50020, a minimum distance of 50 mm must be kept between live parts of Ex e and Ex i circuits. The use of Ex e/Ex i separators is a space-saving solution when Ex e and Ex i terminal blocks are mounted on a common carrier rail. Product family Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 18/19 Data sheet  |  Item number: 2001-1402 www.wago.com/2001-1402 TOPJOB® S TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections. Show all products from the family Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 19/19
2001-1402 价格&库存
很抱歉,暂时无法提供与“2001-1402”相匹配的价格&库存,您可以联系我们找货
    • 1+671.85912
    库存:286
    2001-1402
      • 1+67.19008
      库存:286
      2001-1402
        • 10+15.1640010+1.88700
        • 30+14.9856030+1.86480
        • 100+14.71800100+1.83150
        • 250+14.53960250+1.80930
        • 750+14.18280750+1.76490
        库存:25
