2002-408
2002-408
    WAGO(万可电子)
    8 位置 接线板 - 交叉连接 跳接器 扁平引脚
2002-408 数据手册
Data sheet | Item number: 2002-408 TOPJOB®S jumper; for 2002 series; insulated; 8-way; light-gray www.wago.com/2002-408 i Picture differs from the item. Color: Data Electrical data IEC Approvals Rated voltage (III / 3) 800 V Rated current 25 A Ex information Rated current (Ex e II) 20 A Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 02.08.2021    Page 1/5 Data sheet | Item number: 2002-408 www.wago.com/2002-408 Connection data Jumper assignment 8-way Physical data Width 39.9 mm / 1.571 inch Height 4.1 mm / 0.161 inch Depth 19 mm / 0.748 inch Jumper assignment 8-way Material data Color light gray Fire load 0.028 MJ Weight 3.9 g Commercial data Product Group 22 (TOPJOB S) Packaging type bag Country of origin DE GTIN 4055143690300 Customs tariff number 8536698000 Downloads Documentation Bid Text 2002-408 19 Feb 2019 xml 2.6 kB Download 27 Apr 2017 doc 24.1 kB Download 3 Apr 2019 pdf 2.2 MB Download X81 - Datei 2002-408 doc - Datei Additional Information Technical explanations Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 02.08.2021    Page 2/5 Data sheet | Item number: 2002-408 www.wago.com/2002-408 CAD files CAD data 2D/3D Models 2002-408 URL Download EPLAN Data Portal 2002-408 URL Download WSCAD Universe 2002-408 URL Download ZUKEN Portal 2002-408 URL Download URL Download CAE data Environmental Product Compliance Compliance Search Environmental Product Compliance 2002-408 Jumper; 8-way; insulated; light gray Installation Notes Commoning Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 02.08.2021    Page 3/5 Data sheet | Item number: 2002-408 www.wago.com/2002-408 The push-in type jumper bar system is based on the common plug and socket principle. Each terminal block is spring-loaded with a double socket and a resilient CrNi steel spring. The jumper contact material is pure electrolytic copper, which allows for an extremely small design capable of carrying the full-rated current of the terminal block. Ground terminal blocks can also be commoned using the same jumper system. Custom jumpers are created by breaking and removing jumper contacts (2000, 2001, 2002, 2004 Series). Removing a push-in type jumper bar: Insert the operating tool between the jumper and partition wall of the dual jumper slots, then lift up the jumper. Place the operating tool in the center of jumpers for up to five contacts (see above), or alternately on both sides for jumpers with more than five contacts. Commoning Push-in type jumper bars Push-in type jumper bars Custom push-in type jumper bars are created by breaking off jumper contacts. Marking with a felt-tip pen. 500 V 300 V Commoning Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 02.08.2021    Page 4/5 Data sheet | Item number: 2002-408 www.wago.com/2002-408 Stepping down via push-in type jumper bar. Stepping down via push-in type jumper bar: Stepping down via push-in type jumper bar: Commoning via closed terminal side with end plate allows jumpering over two crosssection sizes, e.g., from 16 mm² (6 AWG) to 6 mm² (10 AWG) or from 6 mm² (10 AWG) to 2.5 mm² (14 AWG) (see illustration above). Commoning via open terminal side with end plate allows jumpering over two crosssection sizes for 16 mm² (6 AWG) and 10 mm² (8 AWG) and one cross-section size for 6/4/2.5 mm² (10/12/14 AWG). An example: from 16 mm² (6 AWG) to 6 mm² (10 AWG) (see illustration above) or from 10 mm² (8 AWG) to 4 mm² (12 AWG). Note: The total current of the outgoing circuits must not exceed the nominal current of the step-down jumper/push-in type jumper bar. Product family TOPJOB® S TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections. Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 02.08.2021    Page 5/5
2002-408 价格&库存
很抱歉,暂时无法提供与“2002-408”相匹配的价格&库存,您可以联系我们找货
    • 41+21.66708
    库存:90
    2002-408
      库存:50
      2002-408
        • 1+943.34785
        库存:200
