Printview: 3-conductor through terminal block; suitable for Ex e II applications - Item No.: 2006-1301
Item No.: 2006-1301
Marking
Business data
Supplier
WAGO
Item no.
2006-1301
GTIN / EAN
4017332999687
Content
1
Order amount
25
Customer item number
Notes
Technical data
Miscellaneous
Total number of connection points
3
Total number of potentials
1
Color
gray
Ratings according to 1
IEC/EN 60947-7-1
Pollution degree (1)
3
Rated voltage EN (1) [V]
800 [V]
Rated surge voltage (1) [kV]
8 [kV]
Nominal current [A]
41 [A]
Nominal current (2) [A]
57 [A]
Rated voltage EN (Ex e II) [V]
550 [V]
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Nominal current (Ex e II) [A]
36 [A]
Nominal current (Ex e II) with jumper [A]
33 [A]
Connection technology (1)
Push-in CAGE CLAMP®
Nominal cross section 1
6 mm²
Solid sizes 1
0.5 … 10 mm² / 20 … 8 AWG
solid, directly pluggable 1
1 … 10 mm² / 14 … 8 AWG
Fine-stranded wires 1
min. fine-stranded with insulated ferrule, push-in terminati 1.5 mm² / 16 AWG
Strip length 1
13 … 15 mm / 0.51 … 0.59 in
Type of wiring
Front-entry wiring
Design
horizontal
Marking level
Center/Side marking
Insulating material
Polyamide 66 (PA 66)
Fire load [MJ]
0.196 [MJ]
Weight [g]
11.89 [g]
Width
7.5 mm / 0.295 in
Height from upper-edge of DIN-rail [mm]
32.9 [mm]
32.9 mm / 1.295 in
Length
73.5 mm / 2.894 in
Type of mounting
DIN 35 rail
2
Images & drawings
3
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
4
很抱歉,暂时无法提供与“2006-1301”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 15+75.0174015+9.75202
- 25+64.9128625+8.43847
- 50+45.9811550+5.97740
- 100+41.26711100+5.36459
- 250+37.70810250+4.90193
- 500+37.54140500+4.88026
- 1000+33.766611000+4.38955
- 国内价格 香港价格
- 15+74.9219915+9.73962
- 25+64.8298025+8.42767
- 50+45.9227650+5.96981
- 100+41.21465100+5.35777
- 250+37.65986250+4.89566
- 500+37.49401500+4.87410
- 1000+33.724311000+4.38405
- 国内价格 香港价格
- 25+60.2366225+7.83057
- 50+43.0618550+5.59790
- 100+39.19652100+5.09542
- 250+36.19937250+4.70580
- 500+36.07244500+4.68930
- 1000+32.812971000+4.26558
- 国内价格 香港价格
- 5+13.312585+1.73060
