2086-1130/300-000
2086-1130/300-000
    WAGO(万可电子)
    插件,P=3.5mm
    接线端子 脚间距:3.50mm 每排Pin数:10 排数:1
2086-1130/300-000 数据手册
Data sheet | Item number: 2086-1130/300-000 THR PCB terminal block; push-button; 1.5 mm²; Pin spacing 3.5 mm; 10-pole; Push-in CAGE CLAMP®; Solder pin length 1.5 mm; 1,50 mm²; black www.wago.com/2086-1130/300-000 Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 13.09.2021    Page 1/9 Data sheet | Item number: 2086-1130/300-000 www.wago.com/2086-1130/300-000 Dimensions in mm L = (pole no. – 1) x pin spacing + 4.2 mm Dimensions in mm A = even number of poles B = odd number of poles Item description Ideal for compact device connection, panel feedthrough and tight spaces Push-in CAGE CLAMP® allows push-in termination of solid and fine-stranded conductors with ferrules SMD and THR variants available Delivery in tape-and-reel packaging for full integration into SMT soldering process Push-button moves in direction of conductor connection Conductor connection and mating direction both parallel and perpendicular to the PCB Choice of double pin spacing or alternating pin spacing, 3.5 and 5 mm pin spacing Data Electrical data Ratings per IEC/EN Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 250 V Rated surge voltage (III/3) 4 kV Rated voltage (III/2) 320 V Rated surge voltage (III/2) 4 kV Nominal voltage (II/2) 630 V Rated surge voltage (II/2) 4 kV Rated current 17.5 A Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 13.09.2021    Page 2/9 Data sheet | Item number: 2086-1130/300-000 www.wago.com/2086-1130/300-000 Rated current 17.5 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Ratings per UL Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 10 A Rated voltage UL (Use Group C) 300 V Rated current UL (Use Group C) 10 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Ratings per CSA Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 10 A Rated voltage CSA (Use Group D) 300 V Rated current CSA (Use Group D) 10 A Connection data Total number of potentials 10 Number of connection types 1 Number of levels 1 Connection 1 Connection technology Push-in CAGE CLAMP® Actuation type Push-button Solid conductor 0.14 … 1.5 mm² / 24 … 16 AWG Fine-stranded conductor 0.14 … 1.5 mm² / 24 … 16 AWG Fine-stranded conductor; with insulated ferrule 0.25 … 0.75 mm² Fine-stranded conductor; with uninsulated ferrule 0.25 … 1.5 mm² Conductor diameter 24 … 16 AWG Strip length 8 … 9 mm / 0.31 … 0.35 inch Conductor connection direction to PCB 90 ° Pole No. 10 Physical data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 13.09.2021    Page 3/9 Data sheet | Item number: 2086-1130/300-000 www.wago.com/2086-1130/300-000 Physical data Pin spacing 3.5 mm / 0.138 inch Width 37.7 mm / 1.406 inch Height 15.1 mm / 0.594 inch Height from the surface 13.6 mm / 0.535 inch Depth 7.8 mm / 0.307 inch Solder pin length 1.5 mm Solder pin dimensions 0.3 x 0.8 mm Plated through-hole diameter (THR) 1 (+0.1) mm PCB contact PCB Contact THR Solder pin arrangement over the entire terminal strip (staggered) Number of solder pins per potential 1 Material data Color black Insulation material Polyphthalamide (PPA GF) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Electrolytic copper (ECu) Contact plating tin-plated Weight 4.7 g Environmental requirements Limit temperature range -60 … +105 °C Commercial data PU (SPU) 84 Stück Packaging type BOX Country of origin CH GTIN 4055144090192 Customs tariff number 85369010000 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 13.09.2021    Page 4/9 Data sheet | Item number: 2086-1130/300-000 www.wago.com/2086-1130/300-000 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CB DEKRA Certification B.V. IEC 60947-7-4 NL-74022 CSA DEKRA Certification B.V. C22.2 80060692 KEMA/KEUR DEKRA Certification B.V. EN 60947-7-4 71119449 Optional accessories Testing and measuring     Testing accessories Item no.: 735-500 Test pin; 1 mm Ø; with solder connection for test wire www.wago.com/735-500 Item no.: 859-500 Test pin; 1 mm Ø; with solder connection for test wire www.wago.com/859-500 Item no.: 216-101 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored www.wago.com/216-101 Item no.: 216-104 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored www.wago.com/216-104 Item no.: 216-102 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored www.wago.com/216-102 Item no.: 216-103 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated www.wago.com/216-103 Item no.: 216-142 Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-142 Item no.: 216-132 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-132 Ferrule     Ferrule Item no.: 216-121 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/216-121 Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 13.09.2021    Page 5/9 Data sheet | Item number: 2086-1130/300-000 www.wago.com/2086-1130/300-000 Item no.: 216-121 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored www.wago.com/216-121 Item no.: 216-143 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-143 Item no.: 216-131 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored www.wago.com/216-131 Item no.: 216-141 Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-141 Item no.: 216-152 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-152 Item no.: 216-202 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-202 Item no.: 216-151 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-151 Item no.: 216-144 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92; silver-colored www.wago.com/216-144 Item no.: 216-201 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-201 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-302 Tool     Operating tool Item no.: 210-719 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-719 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 THR Soldering Process Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com pdf 2.0 MB Download pdf Download Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 13.09.2021    Page 6/9 Data sheet | Item number: 2086-1130/300-000 www.wago.com/2086-1130/300-000 THR Soldering Process pdf 548.2 kB Download URL Download URL Download URL Download CAD/CAE-Data CAD data 2D/3D Models 2086-1130/300-000 CAE data ZUKEN Portal 2086-1130/300-000 Environmental Product Compliance Compliance Search Environmental Product Compliance 2086-1130/300-000 THR PCB terminal block; push-button; 1.5 mm²; Pin spacing 3.5 mm; 10-pole; Push-in CAGE CLAMP®; Solder pin length 1.5 mm; 1,50 mm²; black Installation Notes Conductor termination Inserting solid conductor via push-in termination. Conductor removal Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 13.09.2021    Page 7/9 Data sheet | Item number: 2086-1130/300-000 www.wago.com/2086-1130/300-000 Removing fine-stranded conductors via push-buttons. Conductor termination Inserting and removing fine-stranded conductors via push-buttons. Testing Testing via 1 mm Ø test pin. Touch contact with current bar. Marking Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 13.09.2021    Page 8/9 Data sheet | Item number: 2086-1130/300-000 www.wago.com/2086-1130/300-000 Pole marking via direct marking perpendicular to conductor entry. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 13.09.2021    Page 9/9
2086-1130/300-000
物料型号:2086-1130/300-000
器件简介:WAGO的这款PCB端子块适用于紧凑设备连接、面板通孔和狭窄空间。其Push-in CAGE CLAMP®技术允许插入实心和细股导线。提供SMD和THR变体,可使用胶带和卷轴包装,以便完全集成到SMT焊接过程中。
引脚分配:端子块有10个引脚,引脚间距为3.5毫米。
参数特性: - 额定电压(ll/3):250V - 额定冲击电压(l/3):4kV - 额定电流(IEC/EN):17.5A
功能详解: - 端子块支持实心和细股导线的插入式连接。 - 推钮操作,可在导线连接方向移动。 - 导线连接和配对方向可以与PCB平行或垂直。 - 提供3.5毫米和5毫米的引脚间距选择。
应用信息:适用于需要紧凑连接的设备,面板通孔和狭窄空间。
封装信息: - 引脚间距:3.5 mm/0.138 inch - 宽度:37.7mm/1.406inch - 高度:15.1 mm/0.594inch - 从表面高度:13.6 mm/0.535inch - 深度:7.8 mm/0.307inch - 焊接针长度:1.5mm - 焊接针尺寸:0.3x0.8 mm
材料数据: - 颜色:黑色 - 绝缘材料:聚邻苯二甲酰胺(PPA GF) - 阻燃等级:UL94 VO - 夹持弹簧材料:铬镍弹簧钢(CrNi) - 接触材料:电解铜(E) - 接触镀层:镀锡 - 重量:4.7g
温度范围:-60 … +105 °C
商业数据: - 包装单位:84个/包 - 包装类型:盒装 - 原产国:中国 - GTIN:4055144090192 - 海关关税编号:85369010000
认证/证书:包括NL-74022、IEC 60947-7-4、CB DEKRA Certification、CSA C22.2 No.80060692、KEMA/KEUR EN 60947-7-4、NEUR TEMA等。
可选配件:包括测试和测量配件、测试针、套管、工具等。
2086-1130/300-000 价格&库存
很抱歉,暂时无法提供与“2086-1130/300-000”相匹配的价格&库存,您可以联系我们找货
