| : 210-133
Busbar; tin-plated; 1000 mm long; Cu 10 mm x 3 mm; white
https://www.wago.com/210-133
white
Technical data
Main product function
Mounting accessories
Electrical data
Rated current
140 A
Material data
Color
white
Fire load
0 MJ
Weight
300 g
Commercial data
eCl@ss 10.0
27-14-11-39
eCl@ss 9.0
27-14-11-39
ETIM 8.0
EC000485
ETIM 7.0
EC000485
PU (SPU)
1 Stück
Packaging type
Box
Country of origin VKOrg Germany
DE
GTIN
4045454229443
Customs tariff number VKOrg Germany
74071000000
Seite 1/3
Stand: 19.07.2022
Fortsetzung nächste Seite ››
| : 210-133
Downloads
Environmental Product Compliance
Compliance Search
Compliance 210-133
Documentation
Bid Text
210-133
19.02.2019
xml
2.54 KB
23.11.2018
docx
13.39 KB
210-133
CAD/CAE-Data
CAD data
CAE data
2D/3D Models 210-133
EPLAN Data Portal
210-133
WSCAD Universe
210-133
ZUKEN Portal 210-133
1 Compatible products
1.1 Optional accessories
1.1.1 N-busbar
1.1.1.1 Busbar terminal block
: 210-281
Connector; blue
: 209-105
Connector; silver-colored
1.1.2 Shield termination
1.1.2.1 Shield clamping saddles
: 790-108
Shield clamping saddle; 11 mm wide; dia
meter of compatible conductor; 3 ... 8 mm
: 790-208
Shield clamping saddle; 12.4 mm wide;
3 ... 8 mm
: 790-116
Shield clamping saddle; 19 mm wide; dia
meter of compatible conductor; 7 ... 16
mm
: 790-124
Shield clamping saddle; 27 mm wide; dia
meter of compatible conductor; 6 ... 24
mm
: 790-220
Shield clamping saddle; 30 mm wide; 6 ...
20 mm
: 790-140
Shield clamping saddle; diameter of com
patible conductor
: 790-216
Shield clamping saddle; 21.8 mm wide;
6 ... 16 mm
Seite 2/3
Stand: 19.07.2022
| : 210-133
1.1.2.2 Shield termination
: 791-107
Shield clamp; diameter of compatible
conductor; 1.5 mm to 6.5 mm; H max. 40
mm; 10 mm wide
: 791-117
conductor; 10 mm to 17 mm; H max. 63
mm; 23 mm wide
: 791-124
conductor; 16 mm to 24 mm; H max. 78
mm; 30 mm wide
: 791-111
conductor; 5 mm to 11 mm; H max. 47
mm; 17 mm wide
: 790-398
T-connector; for busbars Cu 10 mm x 3
mm; gray
1.1.3 Terminal blocks
1.1.3.1 Common potential terminal block
: 812-104
Busbar terminal block; for (10 x 3) mm
busbars; 12-pole; without push-buttons;
Push-in CAGE CLAMP®; 4,00 mm²; blue
: 812-102
Push-in CAGE CLAMP®; 4,00 mm²; dark
gray
: 812-101
Push-in CAGE CLAMP®; 4,00 mm²; light
gray
: 812-103
Push-in CAGE CLAMP®; 4,00 mm²; red
: 812-114
busbars; 3-pole; without push-buttons;
CAGE CLAMP®; 16,00 mm²; blue
: 812-112
CAGE CLAMP®; 16,00 mm²; dark gray
: 812-111
CAGE CLAMP®; 16,00 mm²; light gray
: 812-113
CAGE CLAMP®; 16,00 mm²; red
: 812-100
Ground busbar terminal block; for (10 x 3)
mm busbars; 12-pole; Push-in CAGE
CLAMP®; 4,00 mm²; green-yellow
: 812-110
mm busbars; 3-pole; CAGE CLAMP®;
16,00 mm²; green-yellow
Änderungen vorbehalten. Bitte beachten Sie auch die weitere Produktdokumentation!
Adressen finden Sie unter: w w w.wago.com
Seite 3/3
Stand: 19.07.2022
很抱歉,暂时无法提供与“210-133”相匹配的价格&库存,您可以联系我们找货
