LEVER-NUTS™
222 Series Compact Lever-Operated Connectors with
CAGE CLAMP®, for Solid and Stranded Wire
222 Series
2, 3 or 5 Conductor Compact Connector
Cross section:
28 – 12 AWG
(stranded and solid)
Electrical specs:
600 V (1000 V signs and fixtures)
20 A maximum
Strip length: l 9 - 10 mm / 0.37 in
Maximum operating temperature: 105° C
For all connections requiring...
• Stranded / solid wires
• Wide range of wire sizes
• Combination of different wire sizes
and types in one connector
• Small space consumption
• Built-in test point
• Protection against electrical shock,
touch safe
• Low installed cost and safe operation
• Maintenance-free connection
• A reusable connector
Item
No.
222-412
Pack.-unit
pcs
222-412/K194-4045
Item
No.
222-413
Pack.-unit
pcs
100 pc box (1=100) 222-413/K194-4045
222-412/PW05-0005 5 pc blister pack
Technical Data
Pack.-unit
pcs
50 pc box (1=50) 222-415/K194-4045
222-413/PW05-0005 5 pc blister pack
222-413/VE00-2500
Item
No.
222-415
40 pc box (1=40)
222-415/PW05-0005 5 pc blister pack
2,500 pc bulk bag
r
r
r
2
3
5
1
1
1
Height
CAGE CLAMP®
Spring pressure connection technology
14.5 mm/0.571 in
CAGE CLAMP®
14.5 mm/0.571 in
CAGE CLAMP®
14.5 mm/0.571 in
Width
12.4 mm/0.488 in
17 mm/0.669 in
26.6 mm/1.047 in
Depth
20.5 mm/0.807 in
20.5 mm/0.807 in
20.5 mm/0.807 in
Gray (w/orange levers)
Pack.-unit
pcs
1
Approvals
Number of connection points
per connector
Potentials per connector
Connection type
Color
Accessories
Item
No.
206-130
Wire cutting and
stripping tool (22-10 AWG)
Operating tool for Series 222 210-101
1
Operating Tool
Easy as 1, 2, 3...
1) Strip wire
2) Push up lever
3) Insert conductor and push down lever
222 Series
Mounting Carrier
Mounting carrier for 222 Series
compact connectors
Accomodates:
2 x 222-415
3 x 222-413
4 x 222-412
Universal right angled adapter for
222-500 mounting carrier
773-332 mounting carrier
273-150 mounting carrier
Strain relief plate for
1 x 222-415 + 1 x 222-413
1 x 222-415 + 2 x 222-412
3 x 222-412 + 1 x 222-413
Item
Pack.-unit
No.
pcs
Mounting carrier, orange,
for 2-, 3- or 5-pole compact connectors
222-500
Self-adhesive marker strips,
plain
210-334
50 (5x10)
Item
No.
Strain relief plate, orange,
for snap-on fixing to 222-500
mounting carrier
222-505
Pack.-unit
pcs
50 (5x10)
Item
Pack.-unit
No.
pcs
Universal right angled adapter, gray,
in combination with mounting carriers for
DIN 35 rail mounting
50 (5x10)
222-510
1 card
Assembly
Snapping of lateral connector safety lock.
Mounting of strain relief plate to the
mounting carrier.
Snapping the universal right angled carrier
on the mounting carrier.
Strain relief by cable tie on the carrier,
transverse to the connectors wiring direction.
Molded marking of clamping units.
Horizontal mounting with strain relief plate
on level surfaces. Testing connectors via
test slots in the carrier.
Mounting
Horizontal mounting with strain relief plate on
DIN 35 rail using universal right angled adapter.
Germany
WAGO Kontakttechnik
Minden
Tel. ++0571/887-443
Fax ++0571/887-541
Austria
WAGO Kontakttechnik
GmbH Vienna
Tel. ++43/1/615 07 80
Fax ++43/1/615 07 75
Belgium
WAGO Kontakttechnik
Zaventem
Tel. ++32/2/7 17 90 90
Fax ++32/2/7 17 90 99
China
WAGO ELECTRONIC Co. Ltd.
Tianjin
Tel.
++86/22/82125854/64/74
Fax ++86/22/82125984
51011212 0888-0832/0000-0042 Printed in the United States
WAGO Service Worldwide
England
WAGO, Ltd.
Rugby
Tel. ++44/1788/568008
Fax ++44/1788/568050
France
WAGO CONTACT SA.
Paris
Tel. ++33/148172590
Fax ++33/148632520
Italy
WAGO ELETTRONICA SRL
San Lazzaro di Savena (BO)
Tel. ++39/051/625-91-25
Fax ++39/051/625-91-27
Japan
WAGO Co. of JAPAN Ltd.
Tokyo
Tel. ++81/3/3254/8881
Fax ++81/3/3254/8885
Poland
WAGO ELWAG sp. z o. o.
Wroclaw
Tel. ++48/71/33-66-626
Fax ++48/71/33-60-952
Singapore
WAGO Electronic Pte. Ltd.
Singapur
Tel. ++65/2866776
Fax ++65/2842425
Switzerland
WAGO CONTACT SA
Domdidier
Tel. ++65/2866776
Fax ++65/2842425
Mexico
WAGO Corporation
Tel. 001-800-309-5975
+ 52-(55)-26-44-69-16
Fax + 52-(55)-26-44-69-15
Canada
WAGO Corporation
Tel. 800 / DIN Rail (346-7245)
Fax 262 / 255-3232
WAGO Corporation
N120 W19129 Freistadt Road
Germantown, Wisconsin 53022
Telephone: 800 / DIN Rail (346-7245)
Fax: 262 / 255-3232
info.us@wago.com
www.wago.us
很抱歉,暂时无法提供与“222-413/VE00-2500”相匹配的价格&库存,您可以联系我们找货
