231-563/001-000
231-563/001-000
    WAGO(万可电子)
    插件,P=5.08mm
    接线端子 间距:5.08mm 1x3P 直插
231-563/001-000 数据手册
Data sheet from 22.01.2013 Item no.: 231-563/001-000 Product description: HEADER RIGHT ANGLE SOLDER PIN, 1.2 X 1.2 MM/ 0.47 X 0.47 IN 3 POLE PIN SPACING 5.08 MM / 0.2 IN MATING DIRECTION PARALLEL TO PCB WITH CLOSED END Produkt kann von Bild abweichen / product may differ Packing unit 200 4*50 pieces RoHS compliant Product group 3 (Multi Conn. System) Weight 1.2 g Color orange pole count 3 Height 8.4 mm Height 0.331 in Width 18.44 mm Width 0.726 in Depth 12 mm Depth 0.472 in Pin spacing from 5.08 mm Pin spacing from 0.2 in Pollution degree 2 Measured voltage EN 320 V Measured shock voltage 4 kV Current intensity EN 16 A Pollution degree 2 Measured voltage EN 1 von 3 630 V Measured shock voltage 4 kV Current intensity EN 16 A Material group I Contact material Electrolytic copper (Ecu) Contact surface tin-plated 2 von 3 Data sheet from 22.01.2013 Item no. Admission office Approval no. Voltage [V] Current [A] Cross section [ mm² ] 231-563/001-000 ABS 04-HG469925/1-PDA 400 12 0,08-2,5 231-563/001-000 BV 11915/A0 400 16 2,5 231-563/001-000 CCA 5764 250 16 1,2x,21 231-563/001-000 CSA 154112-1466354 300 15 231-563/001-000 GL 17296-00HH 400 12 0,08-2,5 231-563/001-000 KEMA 2083746.02 250 16 1,2x,21 231-563/001-000 KR HMB05880-EL003 250/400 12/16 2,5 231-563/001-000 LR 96/20035 400 12 0,08-2,5 231-563/001-000 RMR 11130002 400 12 0,08-2,5 231-563/001-000 UR E45172 300 15 Sorting criteria: admission office - approval number © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 3 von 3
231-563/001-000 价格&库存
很抱歉,暂时无法提供与“231-563/001-000”相匹配的价格&库存,您可以联系我们找货
