Data sheet | Item number: 232-134
THT female header; 0.6 x 1.0 mm solder pin; straight; Pin spacing 5 mm; 4pole; gray
www.wago.com/232-134
Color:
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
29.12.2019 Page 1/7
L = (pole no. x pin spacing) + 1.5 mm
2- to 3-pole female connectors – one latch only
Item description
Horizontal or vertical PCB mounting via straight or angled solder pins
For board-to-board and board-to-wire connections
Touch-proof PCB outputs
Easy-to-identify PCB inputs and outputs
With coding fingers
Safety information 1:
The MULTI CONNECTION SYSTEM (MCS) is designed without breaking capacity for compliance with DIN EN 61984. When used as intended, MCS
Connectors shall not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are
not live when unmated.
Data
Electrical data
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
320 V
Rated impulse voltage (III / 3)
4 kV
Rated voltage (III / 2)
320 V
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 2/7
320 V
Rated impulse voltage (III / 2)
4 kV
Rated voltage (II / 2)
630 V
Rated impulse voltage (II / 2)
4 kV
Rated current
12 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Approvals per UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
15 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Approvals per UL 1977
Rated voltage per UL 1977 (factory wiring only)
600 V
Rated current per UL 1977 (factory wiring only)
15 A
Approvals per CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
15 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Connection data
No. of poles
4
Total number of potentials
4
Number of connection types
1
Number of levels
1
Geometrical Data
Pin spacing
5 mm / 0.197 inch
Width
21.5 mm / 0.846 inch
Height
23.25 mm / 0.915 inch
Height from the surface
18.25 mm / 0.719 inch
Depth
11.6 mm / 0.457 inch
Solder pin length
5 mm
Solder pin dimensions
0.6 x 1 mm
Drilled hole diameter (tolerance)
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 3/7
1.3(- … +0.1) mm
Plug connection
Contact type (pluggable connector)
Female connector/socket
Connector connection type
for PCBs
Mismating protection
No
Mating direction to the PCB
90 °
PCB contact
PCB contact
THT
Solder pin arrangement
over the entire female connector, in line
Number of solder pins per potential
1
Material Data
Color
gray
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability class per UL94
V0
Contact material
Copper alloy
Contact plating
tin-plated
Fire load
0.067 MJ
Weight
3.8 g
Environmental Requirements
Limit temperature range
-60 … +85 °C
Commercial data
Product Group
3 (Multi Conn. System)
Packaging type
BOX
Country of origin
DE
GTIN
4044918578301
Customs Tariff No.
85366990990
Approvals / Certificates
Country specific Approvals
Certificate
Logo
Approval
Subject to changes.
Hansastr. 27
32423 Minden
Additional Approval Text
name
29.12.2019 Page 4/7
Logo
Approval
name
CB
DEKRA Certification B.V.
IEC 61984
NL-39756
CSA
C22.2
1466354
KEMA/KEUR
EN 61984
2190761.01
Ship Approvals
Logo
Certificate
name
Approval
ABS
American Bureau of Shipping
19HG15869876PDA
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE 000016Z
LR
Lloyds Register
IEC 61984
96/20035 (E5)
UL-Approvals
Logo
Certificate
name
Approval
UL
Underwriters Laboratories Inc.
UL 1059
E4517219911118
UR
UL International Germany GmbH
UL 1977
E45171
Compatible products
check
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 5/7
check
Item no.: 231-661
Test plugs for female connectors; for 5 mm and 5.08 mm pin spacing; 2,50 mm²; light gray
www.wago.com/231-661
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
3.6 MB
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 232-134
CAE data
EPLAN Data Portal 232-134
Download
PCB Design
Symbol and Footprint 232-134
URL
Download
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 6/7
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
Installation Notes
Product family
MCS MIDI Classic
Show all products from the family
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 7/7
