280-637
280-637
    WAGO(万可电子)
    端子块连接器 3 位置 接地,地面 绿色,黄色 12-28 AWG
280-637 数据手册
Printview: 3-conductor ground terminal block - Item No.: 280-637 . 3-conductor ground terminal block Item No.: 280-637 . 3-conductor ground terminal block . Marking . Business data Supplier WAGO Item no. 280-637 GTIN / EAN 4044918473064 Content 1 Order amount 100 Customer item number . Notes Technical data Miscellaneous Total number of connection points 3 Total number of potentials 1 Color green-yellow Ratings according to 1 IEC/EN 60947-7-2 Connection technology (1) CAGE CLAMP® Solid sizes 1 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded wires 1 0.08 … 2.5 mm² / 28 … 12 AWG Strip length 1 8 … 9 mm / 0.31 … 0.35 in Note (conductor cross-section) 12 AWG: THHN, THWN Type of wiring Front-entry wiring WAGO Kontakttechnik GmbH & Co. KG 1 Printview: 3-conductor ground terminal block - Item No.: 280-637 Technical data Design angled Marking level Center marking Insulating material Polyamide 66 (PA 66) Fire load [MJ] 0.109 [MJ] Weight [g] 11.13 [g] Width 5 mm / 0.197 in Height from upper-edge of DIN-rail [mm] 36.5 [mm] Height from upper-edge of DIN-rail 36.5 mm / 1.437 in Length 50.5 mm / 1.988 in Type of mounting DIN 35 rail WAGO Kontakttechnik GmbH & Co. KG 2 Printview: 3-conductor ground terminal block - Item No.: 280-637 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 3 Printview: 3-conductor ground terminal block - Item No.: 280-637 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
280-637 价格&库存
很抱歉,暂时无法提供与“280-637”相匹配的价格&库存,您可以联系我们找货
    库存:25
    280-637
    • 1+149.837051+19.40914
    • 10+106.7394510+13.82649
    • 25+94.9671525+12.30157
    • 50+87.9244450+11.38929
    • 100+82.26319100+10.65596
    • 250+76.53985250+9.91459
    • 500+73.28055500+9.49240
    • 1000+70.745791000+9.16406
    库存:391
