280-523
280-523
    WAGO(万可电子)
280-523 数据手册
Data sheet from 20.03.2012 Item no.: 280-523 Product description: DOUBLE DECK TERMINAL BLOCK THROUGH/THROUGH Produkt kann von Bild abweichen / product may differ Packing unit 50 pieces RoHS compliant Product group 1 (Rail Mounted Terminal Blocks) Number of levels 2 Cross section [mm²] 0.08 - 2.5 mm² Cross section [AWG] 28 - 12 AWG Connection method CAGE CLAMP® CONNECTION Measured voltage EN 500 V Measured shock voltage 6 kV Pollution degree 3 Current intensity EN 20 A Weight 10.057 g Color blue/gray Wiring type Front-entry No. of connection Points 4 No. of potentials 2 Height 58.5 mm Height 2.3 in Width 5 mm Width 0.197 in Depth 64 mm 1 von 3 Depth 2.52 in Strip length from 8 mm Strip length to 9 mm Strip length 0.33 in Mounting TS 35 2 von 3 Data sheet from 20.03.2012 Item no. Admission office Approval no. Voltage [V] Current [A] Cross section [ mm² ] 280-523 ABS 05-HG476175/3-PDA 500 20 2,5 280-523 BV 07436/Co 500 20 2,5 280-523 CCA NL5855 500 20 2,5 280-523 CSA 154112-1536071 300 20 28-12 280-523 GL 17295-00HH 500 20 2,5 280-523 KEMA 2082859.07 500 20 2,5 280-523 LR 91/20112(E6) 500 20 2,5 280-523 PRS TE/1718/880590/08 500 20 2,5 280-523 RMR 11130002 500 20 2,5 280-523 UR E45172 300 15 28-12 Sorting criteria: admission office - approval number © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 3 von 3
280-523 价格&库存
很抱歉,暂时无法提供与“280-523”相匹配的价格&库存,您可以联系我们找货
  • 1+105.437211+13.66667
  • 10+74.8849410+9.70652
  • 25+66.2909025+8.59257
  • 50+61.0981550+7.91949
  • 100+56.89622100+7.37484
  • 250+52.62253250+6.82089
  • 500+50.17762500+6.50398
  • 1000+48.270491000+6.25678
库存:40
280-523
