Printview: 2-conductor through terminal block - Item No.: 281-601
Item No.: 281-601
Marking
Business data
Supplier
WAGO
Item no.
281-601
GTIN / EAN
4044918500579
Content
1
Order amount
50
Customer item number
Notes
Technical data
Miscellaneous
Total number of connection points
2
Total number of potentials
1
Color
gray
Ratings according to 1
IEC/EN 60947-7-1
Pollution degree (1)
3
Rated voltage EN (1) [V]
800 [V]
Rated surge voltage (1) [kV]
8 [kV]
Nominal current [A]
32 [A]
Connection technology (1)
CAGE CLAMP®
Solid sizes 1
0.08 … 4 mm² / 28 … 12 AWG
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Fine-stranded wires 1
Strip length 1
9 … 10 mm / 0.35 … 0.39 in
Type of wiring
Front-entry wiring
Design
horizontal
Marking level
Side marking
Insulating material
Polyamide 66 (PA 66)
Fire load [MJ]
0.128 [MJ]
Weight [g]
7.03 [g]
Width
6 mm / 0.236 in
Height from upper-edge of DIN-rail [mm]
29 [mm]
29 mm / 1.142 in
Length
53 mm / 2.087 in
Type of mounting
DIN 35 rail
2
Images & drawings
3
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
4
很抱歉,暂时无法提供与“281-601”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+49.722141+6.45866
- 10+35.2652610+4.58078
- 25+30.9371425+4.01858
- 50+28.2613850+3.67101
- 100+26.06039100+3.38512
- 250+23.78920250+3.09010
- 500+22.47435500+2.91931
- 1000+21.440851000+2.78506
