713-1438/107-000
713-1438/107-000
    WAGO(万可电子)
    插件,P=3.5mm
    THT 针型插座,2排; 0.8 x 0.8 mm焊针; 弯角; 100% 防插错保护; 锁定螺纹; 焊针间距 3.5 mm; 36极; 黑色
713-1438/107-000 数据手册
Data sheet | Item number: 713-1438/107-000 THT male header, 2-row; 0.8 x 0.8 mm solder pin; angled; 100% protected against mismating; Threaded flange; Pin spacing 3.5 mm; 36-pole; black Dimensions in mm L = [(pole no./2) – 1] x pin spacing + 13.6 mm • • • • • Male headers may be mounted horizontally or vertically via straight or angled solder pins Header housing is molded of THT-compatible insulation material for lead-free reflow soldering Separated pin slots prevent damage and make the headers touch-proof when unplugged 100% protected against mismating Coding option available Notes Safety information 1 The MCS – MULTI CONNECTION SYSTEM includes connectors without breaking capaci­ ty in accordance with DIN EN 61984. When used as intended, these connectors must not be connected/disconnected when live or under load.When used as intended, these connectors must not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Variants: Other pole numbers Other solder pin lengths Gold-plated or partially gold-plated contact surfaces Other versions (or variants) can be requested from WAGO Sales or configured at https:// configurator.wago.com/. . Page 1/4 Version 30.05.2022 Continued on next page Data sheet | Item number: 713-1438/107-000 Electrical data Ratings per IEC/EN . Ratings per UL Ratings per IEC/EN 60664-1 Approvals per UL 1059 Nominal voltage (III/3) 80 V Rated voltage UL (Use Group B) 150 V Rated impulse voltage (III/3) 2.5 kV Rated current UL (Use Group B) 10 A Rated voltage (III/2) 160 V Rated voltage UL (Use Group C) 50 V Rated impulse voltage (III/2) 2.5 kV Rated current UL (Use Group C) 10 A Nominal voltage (II/2) 250 V Rated surge voltage (II/2) 2.5 kV Rated current 10 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Polluti­ on degree 2 . Ratings per CSA Approvals per CSA Rated voltage CSA (Use Group B) 150 V Rated current CSA (Use Group B) 12 A . Connection data Total number of potentials 36 Connection 1 Number of connection types 1 Pole number Number of levels 2 36 . . Physical data Pin spacing 3.5 mm / 0.138 inches Width 73.1 mm / 2.878 inches Height 17.1 mm / 0.673 inches Height from the surface 13.3 mm / 0.524 inches Depth 13.5 mm / 0.531 inches Solder pin length 3.8 mm Solder pin dimensions 0.8 x 0.8 mm Drilled hole diameter with tolerance 1.2 (+0.1) mm . Mechanical data Variable coding Yes Anti-rotation protection Yes . Plug-in connection Contact type (pluggable connector) Male connector/plug Connector (connection type) for PCB Mismating protection Yes Plugging without loss of pin spacing No Mating direction to the PCB 0° Locking of plug-in connection Threaded flange . Page 2/4 Version 30.05.2022 Continued on next page Data sheet | Item number: 713-1438/107-000 PCB contact PCB contact THT Solder pin arrangement over the entire male connector (in-line) Number of solder pins per potential 1 . Material data Note (material data) Information on material data can be found here Color black Material group I Insulation material Polyphthalamide (PPA GF) Flammability class per UL94 V0 Contact material Electrolytic copper (ECu) Contact plating Tin Fire load 0.193 MJ Weight 10.2 g . Environmental requirements Limit temperature range -60 … +100 °C . Commercial data Product Group 3 (Multi Conn. System) eCl@ss 10.0 27-44-04-02 eCl@ss 9.0 27-44-04-02 ETIM 8.0 EC002637 ETIM 7.0 EC002637 PU (SPU) 10 Stück Packaging type Box Country of origin VKOrg Germany PL GTIN 4045454809256 Customs tariff number VKOrg Germany 85366990990 . Approvals and certificates Country specific Approvals UL-Approvals Approval Standard Certificate name Approval Standard Certificate name CCA DEKRA Certification B.V. EN 61984 2169947.01 UL 1059 E45172 CCA DEKRA Certification B.V. IEC 61984 NL-30980 UR Underwriters Laboratories Inc. CSA DEKRA Certification B.V. C22.2 2315087 . . Page 3/4 Version 30.05.2022 Continued on next page Data sheet | Item number: 713-1438/107-000 Downloads Environmental Product Compliance Compliance Search Environmental Product Compliance 713-1438/107-000 . Documentation Additional Information Technical Section pdf 1949.09 KB 03.04.2019 . CAD/CAE-Data CAD data CAE data 2D/3D Models 713-1438/107-000 ZUKEN Portal 713-1438/107-000 . . 1 Compatible products 1.1 System counterpart 1.1.1 Female connector/socket Item no.: 713-1118/107-000 1-conductor female connector, 2-row; CAGE CLAMP®; 1.5 mm²; Pin spacing 3.5 mm; 36-pole; 100% protected against mismating; Screw flange; 1,50 mm²; black Item no.: 713-1118/107-047 1-conductor female connector, 2-row; CAGE CLAMP®; 1.5 mm²; Pin spacing 3.5 mm; 36-pole; 100% protected against mismating; Screw flange; direct marking; 1,50 mm²; black Item no.: 713-1118/107-9037 1-conductor female connector, 2-row; CAGE CLAMP®; 1.5 mm²; Pin spacing 3.5 mm; 36-pole; 100% protected against mismating; Screw flange; direct marking; 1,50 mm²; black Item no.: 713-1118/107-9037/035-000 1-conductor female connector, 2-row; CA­ GE CLAMP®; 1.5 mm²; Pin spacing 3.5 mm; 36-pole; 100% protected against misma­ ting; Screw flange; Strain relief plate; direct marking; 1,50 mm²; black . Installation notes Coding Coding a male header by inserting a co­ ding pin. . Subject to changes. Please also observe the further product documentation! Current addresses can be found at: w w w.wago.com Page 4/4 Version 30.05.2022 Item no.: 713-1118/107-047/035-000 1-conductor female connector, 2-row; CAGE CLAMP®; 1.5 mm²; Pin spacing 3.5 mm; 36-pole; 100% protected against mismating; Screw flange; Strain relief pla­ te; direct marking; 1,50 mm²; black
713-1438/107-000 价格&库存
很抱歉,暂时无法提供与“713-1438/107-000”相匹配的价格&库存,您可以联系我们找货
