Data sheet | Item number: 753-454
2-channel analog input; 4 … 20 mA; Differential input
https://www.wago.com/753-454
Color:
light gray
This analog input module processes standard 4–20 V signals.
The input signal is electrically isolated and is transmitted with a resolution of 12 bits.
The internal system supply powers the module.
The input channels of the module are differential inputs.
The shield directly connects to the DIN-rail.
Notes
Note
Pluggable connectors and coding fingers (753 Series) are not included.
Technical data
Number of analog inputs
2
Total number of channels (module)
2
Signal type
Current
Signal type (current)
4 … 20 mADC
Sensor connection
2 x (2-wire)
Input voltage (max.)
35 V
Signal characteristics
Differential
Resolution [bit]
12 bits
Input resistance (max.)
220 Ω
Data width
2 x 16-bit data; 2 x 8-bit control/status (optional)
Conversion time (typ.)
2 ms
Measurement error (reference temperature)
25 °C
Measurement error, deviation (max.) from the upper-range value
0.2 %
Page 1/7
Version 30.03.2022
Continued on next page
Technical data
Temperature error (max.) of the upper-range value
0.01 %/K
Supply voltage (system)
5 VDC; via data contacts
Current consumption (5 V system supply)
70 mA
Isolation
500 V system/field
Connection data
Connection technology: inputs/outputs
8 x CAGE CLAMP®
Connection type 1
Inputs/outputs
Solid conductor
0.08 … 2.5 mm² / 28 … 14 AWG
Fine-stranded conductor
Strip length
9 … 10 mm / 0.35 … 0.39 inch
Physical data
Width
12 mm / 0.472 inch
Height
100 mm / 3.937 inch
Depth
69.8 mm / 2.748 inch
Depth from upper-edge of DIN-rail
62.6 mm / 2.465 inch
Mechanical data
Mounting type
DIN-35 rail
Pluggable connector
pluggable
Material data
Color
light gray
Housing material
Polycarbonate; polyamide 6.6
Fire load
0.869 MJ
Weight
41.5 g
Conformity marking
CE
Environmental requirements
Ambient temperature (operation)
0 … +55 °C
Surrounding air temperature (storage)
-40 … +85 °C
Protection type
IP20
Pollution degree (5)
2 per IEC 61131-2
Operating altitude
0 … 2000 m / 0 … 6562 ft
Mounting position
horizontal (standing/lying); vertical
Relative humidity (without condensation)
95 %
Vibration resistance
4g per IEC 60068-2-6
Shock resistance
15g per IEC 60068-2-27
EMC immunity to interference
per EN 61000-6-2, marine applications
EMC emission of interference
per EN 61000-6-4, marine applications
Exposure to pollutants
per IEC 60068-2-42 and IEC 60068-2-43
Permissible H2S contaminant concentration at a relative humidity 75 %
10 ppm
Permissible SO2 contaminant concentration at a relative humidity 75 %
25 ppm
Page 2/7
Version 30.03.2022
Commercial data
Product Group
15 (Remote I/O)
eCl@ss 10.0
27-24-26-01
eCl@ss 9.0
27-24-26-01
ETIM 7.0
EC001596
ETIM 6.0
EC001596
PU (SPU)
1 Stück
Packaging type
Box
Country of origin VKOrg Germany
DE
GTIN
4045454483289
Customs tariff number VKOrg Germany
85389099990
Approvals and certificates
Ex-Approvals
Country specific Approvals
Approval
Standard
ATEX
TUEV Nord Cert GmbH
EN 60079-0
Certificate name
CCCEx
CQST/CNEx
CNCA-C23-01
EAC
Brjansker Zertifizierungs
stelle
TP TC 012/2011
EAC RU C-DE.AM02.
B.00163/19 (2Ex nA IIC T4
Gc X)
IECEx
TUEV Nord Cert GmbH
IEC 60079-0
IECEx_TUN_14.0035_X
(Ex ec IIC T4 Gc)
INMETRO
TÜV Rheinland do Brasil
Ltda.
IEC 60079-0
BR-Ex_TÜV 12.1297 X
UL
Underwriters Laboratories
Inc. (HAZARDOUS LOCA
TIONS)
UL 121201
E198726 Sec.1
2020312310000215 (Ex
nA IIC T4 Gc)
Approval
Standard
Certificate name
EAC
stelle
TP TC 020/2011
EAC RU C-DE.AM02.
B.00087/19
KC
National Radio Research
Agency
Article 58-2, Clause 3
MSIP-REM-W43-AIM750
ELE066419XG
Ship Approvals
Ship Approvals
RINA
RINA Germany GmbH
Approval
Standard
Certificate name
ABS
American Bureau of Ship
ping
22-2219060
BSH
Bundesamt fuer See
schifffahrt und Hydrogra
phie
1104
BV
Bureau Veritas S.A.
13453/E0 BV
DNV
DNV Germany GmbH
DNV-CG-0339,Aug.2021
TAA0000194
KR
Korean Register of Ship
ping
KR HMB05880-AC001
LR
Lloyds Register EMEA
02/20026 (E6)
PRS
Polski Rejestr Statków
TE/2236/880590/19
Page 3/7
Version 30.03.2022
UL-Approvals
Approval
Standard
Certificate name
UL
UL International Nether
lands B.V. (ORDINARY LO
CATIONS)
UL 508
E175199 Sec.1
Downloads
Environmental Product Compliance
Compliance Search
Compliance 753-454
Documentation
Manual
System Description
2-channel, 4-20mA, diff.
V 1.1.0
pdf
2138.78 KB
750/753 Series I/OSystem ‒ General Pro
duct Information
pdf
953.35 KB
System Manual WAGO
I/O System 750 / 753
V 3.0.5
15.03.2022
pdf
8401.72 KB
Overview on WAGO-I/
O-SYSTEM 750 appro
vals
pdf
770.48 KB
System Manual Series
750/753
Additional Information
Disposal; Electrical and
electronic equipment,
Packaging
Bid Text
V 1.0.0
pdf
259.56 KB
753-454
17.10.2017
doc
28.00 KB
19.02.2019
xml
4.57 KB
753-454
CAD/CAE-Data
CAD data
CAE data
2D/3D Models 753-454
EPLAN Data Portal
753-454
WSCAD Universe
753-454
ZUKEN Portal 753-454
Page 4/7
Version 30.03.2022
1 Compatible products
1.1 Required accessories
1.1.1 Pluggable connector
1.1.1.1 Male connector/plug
Item no.: 753-110
Plug
1.2 Optional accessories
1.2.1 DIN-rail
1.2.1.1 Mounting accessories
Item no.: 210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm
thick; 2 m long; unslotted; similar to EN
60715; silver-colored
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm
thick; 2 m long; unslotted; according to
EN 60715; copper-colored
Item no.: 210-508
Steel carrier rail; 35 x 15 mm; 1.5 mm
thick; 2 m long; slotted; galvanized; simi
lar to EN 60715; silver-colored
Item no.: 210-197
thick; 2 m long; slotted; similar to EN
Item no.: 210-506
thick; 2 m long; unslotted; galvanized; si
milar to EN 60715; silver-colored
Item no.: 210-114
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm
Item no.: 210-115
Steel carrier rail; 35 x 7.5 mm; 1 mm thick;
2 m long; slotted; according to EN 60715;
"Hole width 18 mm; silver-colored
Item no.: 210-112
"Hole width 25 mm; silver-colored
Item no.: 210-504
2 m long; slotted; galvanized; according
Item no.: 210-113
2 m long; unslotted; according to EN
Item no.: 210-505
2 m long; unslotted; galvanized; according
Item no.: 750-100
Marker card; as a DIN A4 sheet; plain
Item no.: 2009-145/000-006
Mini-WSB Inline; for Smart Printer; 1700
pieces on roll; stretchable 5 - 5.2 mm;
plain; snap-on type; blue
Item no.: 2009-145/000-007
plain; snap-on type; gray
Item no.: 2009-145/000-023
plain; snap-on type; green
Item no.: 2009-145/000-012
plain; snap-on type; orange
Item no.: 2009-145/000-005
plain; snap-on type; red
Item no.: 2009-145/000-024
plain; snap-on type; violet
Item no.: 2009-145
plain; snap-on type; white
1.2.2 Marking
1.2.2.1 Group marker carrier
Item no.: 750-106
1.2.2.2 Marker
Page 5/7
Version 30.03.2022
1.2.2.2 Marker
Item no.: 2009-145/000-002
plain; snap-on type; yellow
Item no.: 248-501/000-006
Mini-WSB marking card; as card; not
stretchable; plain; snap-on type; blue
Item no.: 248-501/000-007
stretchable; plain; snap-on type; gray
Item no.: 248-501/000-023
Mini-WSB marking card; as card; not stret
chable; plain; snap-on type; green
Item no.: 248-501/000-017
chable; plain; snap-on type; light green
Item no.: 248-501/000-012
stretchable; plain; snap-on type; orange
Item no.: 248-501/000-005
stretchable; plain; snap-on type; red
Item no.: 248-501/000-024
chable; plain; snap-on type; violet
Item no.: 790-108
Shield clamping saddle; 11 mm wide; dia
meter of compatible conductor; 3 ... 8 mm
Item no.: 790-208
Shield clamping saddle; 12.4 mm wide;
3 ... 8 mm
Item no.: 790-116
Shield clamping saddle; 19 mm wide; dia
meter of compatible conductor; 7 ... 16
mm
Item no.: 790-216
Shield clamping saddle; 21.8 mm wide;
6 ... 16 mm
Item no.: 790-124
Shield clamping saddle; 27 mm wide; dia
meter of compatible conductor; 6 ... 24
mm
Item no.: 790-220
Shield clamping saddle; 30 mm wide; 6 ...
20 mm
Item no.: 790-140
Shield clamping saddle; diameter of com
patible conductor
Item no.: 850-825
IP65 enclosure; Aluminium (RAL 7032);
WxHxD (160x100x160 mm); 9 x M12, 4 x
M20
Item no.: 850-826
WxHxD (240x100x160 mm); 4 x M20, 4 x
M16, 14 x M12 cable grip
Item no.: 850-827
WxHxD (320x100x160 mm); 4 x M20, 8 x
M16, 17 x M12 cable grip
Item no.: 850-828
WxHxD (480x100x160 mm); 4 x M20, 10 x
M16, 35 x M12 cable grip
Item no.: 850-826/002-000
IP65 enclosure; Aluminium (RAL 7035);
Item no.: 850-827/002-000
Item no.: 850-828/002-000
Item no.: 850-834
IP65 enclosure; Polyester (RAL 7032); Wx
HxD (164x100x164 mm); 9 x M12, 4 x M20
1.2.2.3 Marker carrier
Item no.: 750-103
1.2.3 Pluggable connector
1.2.3.1 Coding
Item no.: 753-150
753 Series coding elements
1.2.4 Shield termination
1.2.4.1 Shield clamping saddles
1.2.5 System enclosure
1.2.5.1 System enclosure
Page 6/7
Version 30.03.2022
Item no.: 850-835
HxD (244x100x164 mm); 4 x M20, 4 x
Item no.: 850-836
WxHxD (324x100x164 mm); 4 x M20, 8 x
Item no.: 850-816/002-000
IP65 enclosure; Sheet steel (RAL 7035);
WxHxD (400x120x200 mm); without flan
ge plate
Item no.: 850-817/002-000
WxHxD (600x120x200 mm); without flan
ge plate
Item no.: 850-814/002-000
WxHxD (200x120x200 mm); without flan
ge plate
Subject to changes. Please also observe the further product documentation!
Current addresses can be found at: w w w.wago.com
Page 7/7
Version 30.03.2022
Item no.: 850-815/002-000
WxHxD (300x120x200 mm); without flan
ge plate
很抱歉,暂时无法提供与“753-454”相匹配的价格&库存,您可以联系我们找货
