BULKHEAD INTERFACE PORT
Through Panel Power and Programming Ports
BIP SERIES - BULKHEAD INTERFACE PORT
For Convenient Power Supply and Programming
Safely access high voltage panels with the Bulkhead Interface Ports. The BIP Series provide a secure gateway to your
control cabinet, enabling you to plug-in to power and program without putting you or your operation at risk.
Ten different models feature a variety of connection options such as D-Sub, USB, RJ45, duplex, simplex, and GFI’s to
support all your power and communication needs. Push-in CAGE CLAMP® connections provide simple, reliable and toolfree wiring on the duplex models for power connections. A metal on metal spring roller latch ensures a water tight seal.
All bulkhead interface ports are encased in an all metal housing designed to withstand tough conditions and meet
the safety requirements of cULus.
Bulkhead
WAGO
information
Interface displayed
Port purpose
on label
and
information clearly identified on the cover
Push-in
CAGE CLAMP®
CAGE CLAMP®
connections
connections
on backsidefor
of product
power wiring
Metal on metal rolling
spring clamp ensures
water tight seal
Approval:
Rugged all metal housing
Description
Item No.
Dimensional Drawing
Dimensions
Duplex outlet with one RJ45 and
one USB interface connection with
3 A circuit breaker
8000-0100/
1000-0357
5.0 x 3.6 in
Duplex GFI outlet with one
RJ45 interface connection
8000-0100/
1000-0362
5.0 x 3.6 in
Duplex outlet with one RJ45 interface
connection with 3 A circuit breaker
8000-0100/
1000-0359
5.0 x 3.6 in
Duplex GFI outlet with one RJ45 interface
8000-0100/
1000-0361
5.0 x 3.6 in
Simplex outlet with one
8000-0100/
1000-0354
4.5 x 1.8 in
Simplex outlet with 9 pin D-Sub
8000-0100/
1000-0363
4.5 x 1.8 in
Simplex outlet with one RJ45
and two USB interface connections
8000-0100/
1000-0355
4.5 x 1.8 in
and one USB interface connection
8000-0100/
1000-0356
4.5 x 1.8 in
One RJ45 interface connection
8000-0100/
1000-0358
3.2 x 1.8 in
One 9 pin D-Sub interface connection
8000-0100/
1000-0360
3.2 x 1.8 in
WAGO SA DE CV
Carretera estatal 431 Km. 2+200. Lote 99 6
Parque Industrial Tecnologico Innovacion Queretaro
El Marques, Qro. 76246
Lada sin Costo: 01 800 288 WAGO (288-9246)
Telefono: 422 / 221-5946
info.mx@wago.com
www.wago.mx
5/2018 - Printed in the United States
0888-0832/0000-0374
WAGO Canada Inc.
4145 North Service Rd., Unit 224
Burlington, ON
L7L 6A3
Telephone: 888 / WAGO 221 (924-6221)
info.ca@wago.com
www.wago.ca
60373585
WAGO Corporation
N120 W19129 Freistadt Road
Germantown, Wisconsin 53022
Telephone: 800 / DIN-Rail (346-7245)
Fax: 262 / 255-3232
info.us@wago.com
www.wago.us
8000-0100/1000-0361 价格&库存
很抱歉,暂时无法提供与“8000-0100/1000-0361”相匹配的价格&库存,您可以联系我们找货
