811-317
811-317
    WAGO(万可电子)
811-317 数据手册
Fuse Terminal Blocks for Class CC and 10 x 38 mm (¹³⁄₃₂” x 1½“) Fuses 811 Series 2.5 - 16 mm² 1000 VDC, 32 A 2.5 - 16 mm² 690 VAC, 32 A 1000 VDC, 32 A AWG 16 - 6 1000 VDC, 30 Au Terminal block width 17.5 mm / 0.689 in L 12 - 13 mm / 0.49 in 55 mm/2.16 in Terminal block width 17.5 mm / 0.689 in L 12 - 13 mm / 0.49 in 105 mm/4.13 in Item No. 2.5 - 16 mm² – – AWG 16 - 6 600 VAC, 30 A2 750 VAC, 30 Au 1000 VDC, 30 Au2 AWG 16 - 6 600 V, 30 Au 600 V, 30 A2 Terminal block width 17.5 mm / 0.689 in L 12 - 13 mm / 0.49 in 55 mm/2.16 in 252 55 mm/2.16 in 5 105 mm/4.13 in Pack. Unit 105 mm/4.13 in Pack. Unit Item No. Item No. Pack. Unit Fuse terminal block for cylindrical fuses 10 x 38 mm; ¹³⁄₃₂“ x 1½“, for photovoltaic applications, light gray, without blown fuse indication, suitable for DIN 35 rail acc. to EN 60715 12 1-pole 811-316 Fuse terminal block for 10 x 38 mm; ¹³⁄₃₂“ x 1½“, light gray, without blown fuse indication, suitable for DIN 35 rail acc. to EN 60715 12 1-pole 811-310 6 2-pole 811-320 4 3-pole 811-330 Fuse terminal block for class CC fuses, light gray, without blown fuse indication, suitable for DIN 35 rail acc. to EN 60715 Fuse terminal block for cylindrical fuses 10 x 38 mm; ¹³⁄₃₂“ x 1½“, for photovoltaic applications, light gray, with blown fuse indication, 230 - 1000 VDC, suitable for DIN 35 rail acc. to EN 60715 1-pole 12 811-317 Fuse terminal block for 10 x 38 mm; ¹³⁄₃₂“ x 1½“, light gray, with blown fuse indication, 90 - 600 VAC, 115 - 600 VDC, suitable for DIN 35 rail acc. to EN 60715 1-pole 12 811-311 2-pole 6 811-321 3-pole 4 811-331 Fuse terminal block for class CC fuses, light gray, with blown fuse indication, 90 - 600 VAC, 115 - 600 VDC, suitable for DIN 35 rail acc. to EN 60715 811-411 12 1-pole 811-421 6 2-pole 811-431 4 3-pole Fuse terminal block for 10 x 38 mm; ¹³⁄₃₂“ x 1½“, light gray, with blown fuse indication, 24 VDC, suitable for DIN 35 rail acc. to EN 60715 1-pole 12 811-314 Fuse terminal block for class CC fuses, light gray, with blown fuse indication, 24 VDC, suitable for DIN 35 rail acc. to EN 60715 Cylindrical fuses are not offered by WAGO. Temperature scale handling from -35°C to +85°C. Nominal voltage and current are given by the LED or fuse. Cylindrical fuses are not offered by WAGO. Temperature scale handling from -35°C to +85°C. Nominal voltage and current are given by the LED or fuse. Cylindrical fuses are not offered by WAGO. Temperature scale handling from -35°C to +85°C. Nominal voltage and current are given by the LED or fuse. 1-pole 2-pole 3-pole 1-pole 811-410 811-420 811-430 811-414   Dimension Certification organizations can be found in the overview on pages 622 and 623. Abmessungen mmA A 17,3 B (0.68) B 34,6 C (1.36) C 51,9 D (2.04) D 87E(3.43) E 104,9 F (4.13) F 78,3 G (3.08) G 59,7 H (2.35) H 39I (1.54) I 55,2 J (2.17) J 5 (0.2) K K 47,4 L (1.87) L 2,5 (0.1) (in.) mm (in.) 17.3 (0.68) 34.6 (1.36) 51.9 (2.04) 87 (3.43) 104.9 (4.13) 78.3 (3.08) 59.7 (2.35) 39 (1.54) 55.2 (2.17) 5 (0.2) 47.4 (1.87) 2.5 (0.1) 12 6 4 12
811-317 价格&库存
很抱歉,暂时无法提供与“811-317”相匹配的价格&库存,您可以联系我们找货
