830-600/000-024
830-600/000-024
    WAGO(万可电子)
830-600/000-024 数据手册
WAGO Wire-Way High Density Slotted Wall Duct with narrow fingers Specifications: PVC Material UL standard 94 V-0 Impact strength= 15 ft. lbs. /in. notch Tensile strength (+73° F)=6,600 psi Coefficient of linear expansion 4.0 x 10-5 (in./in. 1° F) Approvals: UL recognized, CSA certified ASTM test: D-792, D-2240, D-685, D-790, D-638, D-150, D-177, D-696, D-648, D-638, D-256, D-635 Recommended fill ratio = 50% # of wires = duct area (in2)/1.57 x (wire o.d.) Example: Duct size = 1 x 1, Duct Area = 0.731 in2, 12 AWG = 0.258 o.d., 0.73/1.57 x (0.158)2=19 wires Dimensions: Part Number Type Color WxH A B C D F K W Stick/Pkg Qty. 6’ Lengths/120’ Duct: 51017695 High Density White 1x1 .16 .75 1.00 .40 1.05 On Center 1.00 51017681 High Density Gray 1x1 .16 .75 1.00 .40 1.05 On Center 1.00 6’ Lengths/120’ 51017696 High Density White 1x2 .16 1.62 1.00 .40 2.06 On Center 1.00 6’ Lengths/120’ 51017682 High Density Gray On Center 1.00 6’ Lengths/120’ 51017697 High Density White 2x2 .16 1.62 2.00 .40 2.06 .50 2.03 6’ Lengths/120’ 51017683 High Density Gray .50 2.03 6’ Lengths/120’ 51017698 High Density White 3x2 .16 1.62 3.00 .40 2.06 1.00 3.03 6’ Lengths/120’ 51017684 High Density Gray 1.00 3.03 6’ Lengths/120’ 51017699 High Density White 2x3 .16 2.60 2.00 .40 3.06 .50 2.02 6’ Lengths/120’ 51017685 High Density Gray .50 2.02 6’ Lengths/120’ 51017700 High Density White 3x3 .16 2.60 3.00 .40 2.06 1.00 3.03 6’ Lengths/120’ 51017686 High Density Gray 3x3 .16 2.60 3.00 .40 2.06 1.00 3.03 6’ Lengths/120’ 51017701 High Density White 4x3 .16 2.60 4.00 .40 3.06 1.50 4.03 6’ Lengths/120’ 51017687 High Density Gray 51017702 High Density White 1x4 .16 3.60 1.00 .40 4.06 51017688 High Density Gray 51017703 High Density White 2x4 .16 3.60 2.00 .40 4.06 51017689 High Density Gray .50 2.02 6’ Lengths/120’ 51017704 High Density White 3x4 .16 3.60 3.00 .40 4.06 1.00 3.00 6’ Lengths/120’ 51017690 High Density Gray 3x4 .16 3.60 3.00 .40 4.06 1.00 3.00 6’ Lengths/120’ 51017705 High Density White 4x4 .16 3.60 4.00 .40 4.06 1.50 4.00 6’ Lengths/120’ 51017691 High Density Gray 1.50 4.00 6’ Lengths/120’ 6’ Lengths/120’ 1x2 .16 1.62 1.00 .40 2.06 2x2 .16 1.62 2.00 .40 2.06 3x2 .16 1.62 3.00 .40 2.06 2x3 .16 2.60 2.00 .40 3.06 4x3 .16 2.60 4.00 .40 3.06 1x4 .16 3.60 1.00 .40 4.06 2x4 .16 3.60 2.00 .40 4.06 4x4 .16 3.60 4.00 .40 4.06 1.50 4.03 6’ Lengths/120’ On Center 1.00 6’ Lengths/120’ On Center 1.00 6’ Lengths/120’ .50 2.02 6’ Lengths/120’ High density slotted wall duct comes with narrow fingers, equaling a 2 to 1 finger ratio compared to standard slotted wiring duct. • Narrow fingers reduce fanning of the wires to the terminal blocks. • Compact designs and components are more easily accommodated with the thigh density duct’s 2 to 1 finger ratio. • High density duct also incorporates the double scored design, similar to the standard wall duct. • With sizes 2” high and above, high density duct features a double restriction on each finger of the duct. • The double restriction helps keep wires in the bottom portion of the duct for easier installation. • Mounting holes are uniform in size to the solid and slotted wall duct, but are offered every 2 inches to accommodate compact designs and installations. • Smooth Edges • Cover is Flush with Side of Duct • Non-Slip Cover • Professional Appearance Note: Duct w/adhesive available on request Covers: 51017671 White 1.00 51017653 Gray 1.00 6’ Lengths/120’ 51017692 White 2.00 6’ Lengths/120’ 51017655 Gray 2.00 6’ Lengths/120’ 51017693 White 3.00 6’ Lengths/120’ 51017669 Gray 3.00 6’ Lengths/120’ 51017694 White 4.00 6’ Lengths/120’ 51017670 Gray 4.00 6’ Lengths/120’ Accessories: Description Pkg/Qty 51017715 Panel Rivet 1000 51017716 Panel Rivet Tool 1 Panel Mounting Rivets and Tool: WAGO Wire-Way panel rivets are one piece drive rivets that provide a fast, economical means of affixing wiring duct. The rivet is inserted into a 3/16” pre-punched hole and the pin is driven into the base, thereby expanding the rivet legs and locking the duct and sub-panel in place. The panel thickness (including the duct thickness) should be a maximum of 3/16”. A panel rivet tool is also available for quick and easy installation of the drive rivets. WAGO Corporation N120 W19129 Freistadt Road, Germantown, WI 53022 1-800 DIN Rail www.wago.com
830-600/000-024 价格&库存
很抱歉,暂时无法提供与“830-600/000-024”相匹配的价格&库存,您可以联系我们找货
