852-1106
852-1106
    WAGO(万可电子)
    网络 开关 16 个端口 IP30
852-1106 数据手册
Data sheet  |  Item number: 852-1106 Industrial-Switch; 16 Ports 1000Base-T; Extended temperature range; metallic black www.wago.com/852-1106 Color: 06.11.2019    Page 1/7 Data sheet  |  Item number: 852-1106 www.wago.com/852-1106 Item description The 852‐1106 Industrial Switch is a 16-port 10/100/1000Base‐T ETHERNET switch. The switch has a rugged metal housing, redundant power supply and function monitoring with a relay. These functions and an operating range of −40 to +70°C make it ideal for a wide range of industrial applications. Features: Redundant DC power supply Wide supply voltage range: 12 … 60 VDC DIP switches to set alarm functions Full compliance with IEEE 802.3, 802.3u and 802.3ab standards Non-blocking, store-and-forward switching Auto-Negotiation on all 10/100/1000Base-T ports Auto-MDI/MDIX (crossover) at all 10/100/1000Base-T ports Integrated address look-up table, supports up to 8000 absolute MAC addresses Overvoltage protection Prioritization of Profinet Ethernet Frame (EtherType=0x8892) according to IEEE802.1p Data 06.11.2019    Page 2/7 Data sheet  |  Item number: 852-1106 www.wago.com/852-1106 Data Technical Data Switchingmodus Store‐and‐forward, non-blocking Number of 1000Base-T ports 16 Communication standards IEEE 802.3 10BASE-T IEEE 802.3u 100BASE-TX/FX IEEE 802.3ab 1000BASE-T IEEE 802.3x Flow Control IEEE 802.3az Energy Efficient Ethernet IEEE 802.1p Prioritization Redundancy function Redundant DC power supply Configuration options DIP switch for signal contact Diagnostics Signal contact MAC table (large) 8000 addresses Jumbo frame size 10000 Byte Supply voltage DC 12 … 60 V Energy consumption max. 12 W Baud rate Copper cable: 10/1000 Mbit/s Transmission medium (communication/fieldbus) Copper cable: Cat. 5e or higher, max. line length: 100 m Panel 2 x DIP switch: Alarm function power supplies Indicators Device: LED (PWR, RPS) green: Power supply (primary), redundant power supply (secondary); LED (ALM) red: Alarm; per port: LED (1000, LNK/ACT) green: Status 1000 Mbps, LNK/ACT Port 1 … 16 Connection data Connection technology: communication/fieldbus Copper cable: 16 x RJ-45 Anschlusstechnik: Versorgung 1 x im Gerät verbaute Stiftleiste: 231-436/001-000; mitgelieferte Federleiste (Steckverbinder MCS): 2231-106/026-000 Geometrical Data Width 50 mm / 1.969 inch Height from upper-edge of DIN-35 rail 120 mm / 4.724 inch Depth 162 mm / 6.378 inch Mechanical data Weight 840 Color metallic black Housing material Aluminum Conformity marking CE 06.11.2019    Page 3/7 Data sheet  |  Item number: 852-1106 www.wago.com/852-1106 Environmental Requirements Surrounding air (operating) temperature -40 … 70 °C Surrounding air (storage) temperature -40 … 80 °C Protection class IP30 Relative air humidity (no condensation) 95 % Type of mounting DIN-35 rail Vibration resistance acc. to IEC 60068-2-6 Shock resistance acc. to IEC 60068-2-27 EMC immunity to interference acc. to EN 61000-6-2 EMC emission of interference acc. to EN 61000-6-4 Commercial data Packaging type BOX Country of origin TW GTIN 4055143604659 Customs Tariff No. 85176200000 Compatible products transfer module Item no.: 289-195 Interface module; RJ-45; IDC technology; Cat. 6; in mounting carrier; with shield connection www.wago.com/289-195 wiring and connectors Item no.: 750-976 PROFINET RJ-45 connector, IP20; ETHERNET 10/100 Mbit/s; for field assembly www.wago.com/750-976 Item no.: 750-977/000-011 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 22 www.wago.com/750-977 /000-011 Item no.: 750-977/000-012 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568B; AWG 22 www.wago.com/750-977 /000-012 Item no.: 750-977/000-013 Connector PROFINET; RJ-45; Cat. 6A; straight; AWG 22 www.wago.com/750-977 /000-013 Item no.: 750-977/000-021 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 24 www.wago.com/750-977 /000-021 Item no.: 750-977/000-022 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568B; AWG 24 www.wago.com/750-977 /000-022 06.11.2019    Page 4/7 Data sheet  |  Item number: 852-1106 www.wago.com/852-1106 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568B; AWG 24 /000-022 Item no.: 750-978/000-011 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 22; Strain relief www.wago.com/750-978 /000-011 Item no.: 750-978/000-012 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568B; AWG 22; Strain relief www.wago.com/750-978 /000-012 Item no.: 750-978/000-013 Connector PROFINET; RJ-45; Cat. 6A; straight; AWG 22; Strain relief www.wago.com/750-978 /000-013 Item no.: 750-978/000-021 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 24; Strain relief www.wago.com/750-978 /000-021 Item no.: 750-978/000-022 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568B; AWG 24; Strain relief www.wago.com/750-978 /000-022 Item no.: 750-979/000-011 Connector ETHERNET; RJ-45; Cat. 6A; angled; Code T568A; AWG 22; Strain relief www.wago.com/750-979 /000-011 Item no.: 750-979/000-012 Connector ETHERNET; RJ-45; Cat. 6A; angled; Code T568B; AWG 22; Strain relief www.wago.com/750-979 /000-012 Item no.: 750-979/000-013 Connector PROFINET; RJ-45; Cat. 6A; angled; AWG 22; Strain relief www.wago.com/750-979 /000-013 Item no.: 750-979/000-021 Connector ETHERNET; RJ-45; Cat. 6A; angled; Code T568A; AWG 24; Strain relief www.wago.com/750-979 /000-021 Item no.: 750-979/000-022 Connector ETHERNET; RJ-45; Cat. 6A; angled; Code T568B; AWG 24; Strain relief www.wago.com/750-979 /000-022 power supply Item no.: 787-1102 Switched-mode power supply; Compact; 1-phase; 24 VDC output voltage; 1.3 A output current; DC OK www.wago.com/787-1102 signal Item no.: 787-1112 Switched-mode power supply; Compact; 1-phase; 24 VDC output voltage; 2.5 A output current; DC OK www.wago.com/787-1112 signal Item no.: 787-1122 Switched-mode power supply; Compact; 1-phase; 24 VDC output voltage; 4 A output current; DC OK signal www.wago.com/787-1122 Item no.: 787-1602 Switched-mode power supply; Classic; 1-phase; 24 VDC output voltage; 1 A output current; NEC Class www.wago.com/787-1602 2; DC OK signal Item no.: 787-1606 Switched-mode power supply; Classic; 1-phase; 24 VDC output voltage; 2 A output current; NEC Class www.wago.com/787-1606 06.11.2019    Page 5/7 Data sheet  |  Item number: 852-1106 www.wago.com/852-1106 Switched-mode power supply; Classic; 1-phase; 24 VDC output voltage; 2 A output current; NEC Class www.wago.com/787-1606 2; DC OK signal Item no.: 787-1622 Switched-mode power supply; Classic; 1-phase; 24 VDC output voltage; 5 A output current; TopBoost; www.wago.com/787-1622 DC OK contact Item no.: 787-1632 Switched-mode power supply; Classic; 1-phase; 24 VDC output voltage; 10 A output current; TopBoost; DC OK contact www.wago.com/787-1632 Item no.: 787-1702 Switched-mode power supply; Eco; 1-phase; 24 VDC output voltage; 1.25 A output current www.wago.com/787-1702 Item no.: 787-1712 Switched-mode power supply; Eco; 1-phase; 24 VDC output voltage; 2.5 A output current www.wago.com/787-1712 Item no.: 787-1722 Switched-mode power supply; Eco; 1-phase; 24 VDC output voltage; 5 A output current www.wago.com/787-1722 Downloads Documentation Manual 16-Port 1000BASE-T Industrial Switch V 1.0.0 pdf 1.3 MB Download V 1.0.0 pdf 265.8 kB Download pdf 2.0 MB Download URL Download Additional Information Disposal; Electrical and electronic equipment, Packaging System Description Industrial Switches ‒ General Product Information CAD/CAE-Data CAD data 2D/3D Models 852-1106 CAE data EPLAN Data Portal 852-1106 Download 06.11.2019    Page 6/7 Data sheet  |  Item number: 852-1106 www.wago.com/852-1106 Installation Notes   Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 06.11.2019    Page 7/7
852-1106 价格&库存
很抱歉,暂时无法提供与“852-1106”相匹配的价格&库存,您可以联系我们找货
库存:23
852-1106
    • 1+4462.66242
    库存:3
