857-451
JUMPFLEX® Signal Conditioners
Passive Isolator, 1 Channel
Short description:
The 1-channel passive isolator filters and electrically isolates 0(4)–20 mA analog standard signals, while drawing power for signal transmission from the input
circuit. The connected sensor supplies the passive isolator with the required
power, while powering the connected load.
5 OUT+
IN
OUT
GND 1 2
_>
_>
____________
IN+ 1
6 GND 2
N.C. 3
7 N.C.
N.C. 4
8 N.C.
6 mm/0.23 in
Description
Item No.
Pack.
Unit
JUMPFLEX® Signal Conditioner, for DIN 35 rail
857-451
1
Characteristics:
• No additional supply voltage required
• Safe 3-way isolation with 2.5kV test voltage to EN 61140
Technical Data
Input:
Input signal
Responce current
Voltage drop intput
Max. input voltage
Max. input signal
Output:
Output signal
Load impedance
General specifications:
Max. operating frequency
Response time (T10-90)
Transmission error
Load error
Temperature coefficient
WAGO Kontakttechnik GmbH & Co. KG
Subject to design changes
Technical Data
Environmental requirements:
Ambient operating temperature
Storage temperature
Connection and type of mounting:
Wire connection
Cross sections
0(4) ... 20 mA
< 200 μA
< 2.0 V at 20 mA (output)
< 20 V
40mA
0(4) ... 20 mA
≤ 600 Ω
(Temperature range restrictions may occur)
100 Hz
< 3.5 ms
≤ 0.1 % of the full scale value
≤ 0.05 % of upper range value
per 100 Ω load
≤ 0.01 % /K
08.07.2015
Strip lengths
Dimensions and weight:
Dimensions (mm) W x H x L
Weight
Standards and approvals:
Conformity marking
r UL 508
r ANSI/ISA 12.12.01
Shipbuilding
EMC immunity of interference
EMC emission of interference
Accessories
Postfach 2880 - D-32385 Minden
Hansastr. 27 - D-32423 Minden
-25 °C ... +70 °C
-40 °C ... +85 °C
Push-in CAGE CLAMP®
solid:
0.08 mm² ... 2.5 mm² / AWG 28 ... 14
fine-stranded:
0.34 mm² ... 2.5 mm² / AWG 22 ... 14
9 ... 10 mm / 0.35 … 0.39 in
6 x 96 x 94
Height from upper-edge of DIN 35 rail
33.8 g
1
Class I, Div. 2, Grp. ABCD, T4
GL, PRS, NKK, DNV, BV
EN 61000-6-2
EN 61000-6-4
see pages 226 … 236
Tel.: +49(0)571/887-0
E-Mail: info@wago.com
Fax: +49(0)571/887-169
www.wago.com
很抱歉,暂时无法提供与“857-451”相匹配的价格&库存,您可以联系我们找货
