2000-5311
2000-5311
    WAGO(万可电子)
    端子块连接器 8 位置 断连 灰色 16-20 AWG
2000-5311 数据手册
Printview: 3-conductor sensor terminal block - Item No.: 2000-5311 . 3-conductor sensor terminal block Item No.: 2000-5311 . 3-conductor sensor terminal block . Marking . Business data Supplier WAGO Item no. 2000-5311 GTIN / EAN 4055143393447 Content 1 Order amount 50 Customer item number . Notes Item description:3.5 mm spacing per signal (2 x 3.5 mm = 7 mm)The double spacing per pole of this terminal block series maximizes connectivity. For example, ten sensors may be connected using only five sensor terminal blocks plus a power supply terminal block. Technical data Miscellaneous Packaging type BOX Ratings per IEC/EN 60947-7-1 Rated voltage (III / 3) [V] 250 [V] Rated impulse voltage (III / 3) [kV] 4 [kV] WAGO Kontakttechnik GmbH & Co. KG 1 Printview: 3-conductor sensor terminal block - Item No.: 2000-5311 Technical data Rated current [A] 13.5 [A] Legend (ratings) (III / 3) Overvoltage category III / Pollution degree 3 Type of wiring Front-entry wiring Total number of connection points 8 Total number of potentials 4 Connection technology Push-in CAGE CLAMP® Number of connection points (connection type) 8 Actuation type Push-in Connectable conductor materials Copper Nominal cross section 1 mm² Solid conductor 0.14 … 1.5 mm² / 24 … 16 AWG Solid conductor, push-in termination 0.5 … 1.5 mm² / 20 … 16 AWG Fine-stranded conductor 0.14 … 1.5 mm² / 24 … 16 AWG Fine-stranded conductor with ferrule, push-in termination, 0.5 mm² / 20 AWG f Strip length 9 … 11 mm / 0.35 … 0.43 Inch Width 7 mm / 0.276 Inch Height from upper-edge of DIN-35 rail 52.4 mm / 2.063 Inch Design horizontal Type of mounting Carrier rail 35 x 15 Marking level Center/side marking Color gray Insulating material Polyamide 66 (PA 66) Weight [g] 14.7 [g] WAGO Kontakttechnik GmbH & Co. KG 2 Printview: 3-conductor sensor terminal block - Item No.: 2000-5311 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 3 Printview: 3-conductor sensor terminal block - Item No.: 2000-5311 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
2000-5311 价格&库存
很抱歉,暂时无法提供与“2000-5311”相匹配的价格&库存,您可以联系我们找货
    • 50+81.82777
    库存:800
