2001-1407
    WAGO(万可电子)
    端子块连接器 4 位置 接地,地面 绿色,黄色 14-18 AWG
2001-1407 数据手册
Printview: 4-conductor ground terminal block; suitable for Ex e II applications - Item No.: 2001-1407 . 4-conductor ground terminal block; suitable for Ex e II applications Item No.: 2001-1407 . 4-conductor ground terminal block; suitable for Ex e II applications . Marking . Business data Supplier WAGO Item no. 2001-1407 GTIN / EAN 4017332998697 Content 1 Order amount 100 Customer item number . Notes Technical data Miscellaneous Total number of connection points 4 Total number of potentials 1 Color green-yellow Ratings according to 1 IEC/EN 60947-7-2 Connection technology (1) Push-in CAGE CLAMP® Nominal cross section 1 1.5 mm² Solid sizes 1 0.25 … 2.5 mm² / 22 … 14 AWG solid, directly pluggable 1 0.5 … 2.5 mm² / 20 … 14 AWG Fine-stranded wires 1 0.25 … 2.5 mm² / 22 … 14 AWG min. fine-stranded with insulated ferrule, push-in terminati 0.75 mm² / 18 AWG WAGO Kontakttechnik GmbH & Co. KG 1 Printview: 4-conductor ground terminal block; suitable for Ex e II applications - Item No.: 2001-1407 Technical data Strip length 1 9 … 11 mm / 0.35 … 0.43 in Type of wiring Front-entry wiring Design horizontal Marking level Center/Side marking Insulating material Polyamide 66 (PA 66) Fire load [MJ] 0.102 [MJ] Weight [g] 8.4 [g] Width 4.2 mm / 0.165 in Height from upper-edge of DIN-rail [mm] 32.9 [mm] Height from upper-edge of DIN-rail 32.9 mm / 1.295 in Length 69.9 mm / 2.752 in Type of mounting DIN 35 rail WAGO Kontakttechnik GmbH & Co. KG 2 Printview: 4-conductor ground terminal block; suitable for Ex e II applications - Item No.: 2001-1407 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 3 Printview: 4-conductor ground terminal block; suitable for Ex e II applications - Item No.: 2001-1407 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
2001-1407
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路。
3. 引脚分配:共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光敏三极管集电极,6脚光敏三极管发射极。
4. 参数特性:工作温度范围为-20℃至+70℃,隔离电压为2500Vrms。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,具有抗干扰能力强、响应速度快等特点。
6. 应用信息:广泛应用于工业控制系统、医疗设备等领域。
7. 封装信息:采用DIP6封装形式。
2001-1407 价格&库存
很抱歉,暂时无法提供与“2001-1407”相匹配的价格&库存,您可以联系我们找货
  • 100+23.80083
库存:300
2001-1407
  • 100+61.01279100+7.59240
  • 200+60.65599200+7.54800
  • 300+60.29919300+7.50360
    • 25+36.32137
    库存:144
